Cucci
Lokacija: Velika Gorica
Postovi: 63
Windows password problem
Dečki pomagajte.Stavio sam šifru na WinXP i pritom slučajno stisnuo jedno slovo i kliknuo na Create password.Kak da sad vidim koji je password i promijenim bez onog backupa passworda na disketi(nemogu ga napravit kad neznam šifru)
DFI Lan Party SLI-D, s 939 nForce 4 AMD Athlon64 3200+ Box Leadtek 6600 GT 512 DDR brand name Seagate Barracuda 120GB CD-RW LG 48*16*48 DVD-Rom Pioneer |
Datum registracije: Nov 2002
Postovi: 1,950
http://home.eunet.no/~pnordahl/ntpasswd/cd040116.zip Change any password, account on all xp machines. Boot this cd in dos-mode and make your changes. This bootable ISO is only 2.14 MB. - This is a utility to (re)set the password of any user that has a valid (local) account on your NT system, by modifying the crypted password in the registrys SAM file. - You do not need to know the old password to set a new one. - It works offline, that is, you have to shutdown your computer and boot off a floppydisk or CD. The bootdisk includes stuff to access NTFS partitions and scripts to glue the whole thing together. - Works with syskey (no need to turn it off, but you can if you have lost the key) - Will detect and offer to unlock locked or disabled out user accounts! |
Sannin
Datum registracije: Jun 2003
Postovi: 1,568
pa ako si slucajno nadodao samo 1 slovo - sta nisi isprobao jedno po jedno da saznas koje je? ![]()
YES - BUT / your evaluation is superb - behold the underlying truth |
#6 | |
doktor, trekkie, amd-ovac
Postovi: 1,043
Svijet je monitor s beskonačnom rezolucijom! 1.a64 3500+,abit av8,1.5gb corsair, leadtek geforce 6800 ultra,2x200gb seagate@raid 0,tagan 480w... 2.mobilac 2600+ na 2332mhz,epox 8rda3i,r9800pro,120gb,512ddr,ener 350w... 3.MSI centrino 1.5(dothan), ati9600,40gb... -->HDD u externom kućištu USB 2.0+firewire-hitachi 200 giga |
#7 | |
hmhm...zzz svima...
Lokacija: 21000 Split
Postovi: 1,070
moj zivot se mijenja... iz dana u dan ja kune neman pozzz svima koju me znaju, a i onima koj ne
#8 | |
Postovi: 1,043
