Staro 12.08.2004., 22:26   #1
tomelhajd
Postovi: 33
Exclamation molim odgovor brzo
kupujem konf i molio bih misljenja i preporuke brzo
konf:
mbo abit ic7 i875
p4 2.8. prescott 512 kb fsb 800 mhz
zalman cnps7000b cu
zalman zm-47j pasivni northbridge
hdd sata 120 gb
vga sapphire ati radeon x800 pro 256 mb
ram pc-3200 512 mb geil x2
kuc. chieftec bx-03bbb midi
dvd+rw nec nd-2510
dvd rom sony ddu-1612
logitech mx 700 mis
logitech internet navigator se tipk.
molim pomoc brzo
tomelhajd je offline   Reply With Quote
Staro 12.08.2004., 22:42   #2
tomelhajd
Postovi: 33
promjenio maticnu mbo abit ic7 max3 i875
Staro 12.08.2004., 23:56   #3
Raven_1
Night shift
Raven_1's Avatar
Datum registracije: Jul 2002
Postovi: 884
S-ATA disk bi preporučio Seagate ili Hitachi. Problem je jedino što integ. kontroler nije baš nešto, ali poslužit će.
Pošto uzimaš P4 preporučio bih ti da uzmeš RAM koji radi na 500MHz jer su kod Intela manje važne latencije, a više megaherci.
Sony-jevi dvd čitači baš i nisu najbolji, ali svatko ima svoj ukus.
Napajanje Chieftec 360W je solidno, ali ja bih uzeo jače ili eventualno Enermax 350. Ima bolje 12v railove.
Proc: AMD X2 3800+ cooled by TT BigTyphoon
Matična: ABIT AN8 SLI
RAM: 2x512MB OCZ Platinum EL rev2 PC3200
Grafička: SAPPHIRE ATI RADEON HD3450 256MB
HDD: WD 40GB i Samsung 160GB @ 7200
RW:DVD-ROM Pioneer DVD-106
PSU: 420W Xilence RedWing
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again."
--uoɥʇʎd ʎʇuoɯ--
Raven_1 je offline   Reply With Quote
Staro 13.08.2004., 00:09   #4
Chozen
Chozen's Avatar
Datum registracije: Dec 2003
Lokacija: Okolica Čakovca, točnije Pretetinec
Postovi: 313
Preporučio bi ti da uzmeš AMD...te pare koje buš dal za Prescott i tu ploču možeš dobit AMD 64 i ploču za njega...soc. 754...a i brži je...a Prescott se tak i tak dosta grije...
Chozen je offline   Reply With Quote
Staro 13.08.2004., 00:22   #5
tomelhajd
Postovi: 33
samo me zanima hoce li chieftek biti dovoljan (s tim da ne namjerevam overcloacking)
Staro 13.08.2004., 00:25   #6
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Ja imam max3 staru par mjeseci,malo je radila,pa ako si zainteresiran za kupnju...Prodajem jer prelazim na Athlon64.
I bolje uzmi Northwooda 3.0C i HardCore RAM DDR500(www.ve-mil.hr)
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 13.08.2004., 00:46   #7
tomelhajd
Postovi: 33
ok module cu prihvatiti ove sa 500 mhz ali me jos brine chieftec posto mi ponestaje sredstava
Staro 13.08.2004., 00:47   #8
tomelhajd
Postovi: 33
a sto se pregrijavanja tice mislim da ce to zalman rijesiti valjda jel ko imao iskustva sa tim hladnjakom?
Staro 13.08.2004., 01:47   #9
BladeRunner
Type R
Postovi: 1,485
Zalman je odličan,mislim da će ti taj Chieftec ipak biti preslab,uzmi neko preko 400w(Zalman,Fortron,Levicom,Enhance,Enermax,Chieftec,Tagan...)
btw,bili uzea moju matičnu?
Staro 13.08.2004., 10:54   #10
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
*sigh* Prescott
Šteta novaca za jadne performanse
Nu - tvoji su da ih bacaš, a na meni je da te ponizim krajem godine kad se pikne A 64
( da ne spominjem dr. fiksi-a koji TRENUTNO ima najbržu pilu - A 64 )
HA - živili rođo
Staro 13.08.2004., 15:12   #11
tomelhajd
Postovi: 33
um sto se tice maticne ne hvala ipak kupujem cijelu konfiguraciju pa cu sve na jednom mijestu a uzet cu northwood na 3.0 ghz taj je ja mislim bolji od amd 64 valjda
Staro 13.08.2004., 16:31   #12
LuXor
Datum registracije: Jul 2004
Lokacija: Bjelovar
Postovi: 752
Eeeeeeeej gringo , ne vrijeđaj A64. Evo ti par razloga:
- A64 ima 10*10 bolju aritekturu od P4 Northwooda ili nedajboze
Prescotta, pa s 2000MHz ima PerformansE poput P4 na 3,2GHz
-Podržava 64BITne instrukcije
-S matičnom manje kosta + može alocirati vise memorije
-Grafulje s A64 imaju bolje benchmarke
-Jednostavno je bolji
LuXor je offline   Reply With Quote
Staro 13.08.2004., 16:54   #13
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Kad bi ga OC-ao na 3.6 Ghz MOZDA bi bio brzo od A64 na 2.2 Ghz (ali i on se da klockati) .
Staro 13.08.2004., 21:26   #14
tomelhajd
Postovi: 33
a ako bi uzeo prescotta socket 775 na 3 ghz i 1mb c. samo me brine maticna abit as8 i856 fakat sam zbunjen a trebam kupit komp u pon!!!!
Staro 13.08.2004., 22:01   #15
dr.fiksi
doktor, trekkie, amd-ovac
dr.fiksi's Avatar
Postovi: 1,043
Mani se p4...
razlozi:
zastarjela arhitektura
pregrijavanje
prevelika cijena za ono što nudi
ja bi uzeo a 64, s754, bilo koji s 1Mb cachea.
Možda se čini slabašan, ali stari moj, u doomu 3 a 64 na 3000+ briše svoju guzicu gotovo svim pentiumima, čak i puno skupljim!
Jednostavno je brži, a nek te ne zavaraju silni megahertzi, jer to ne garantira brzinu!Kao što ti kažu i svi, i ja ti kažem...
no pogledaj ovu tablicu, i cijene amd-ovih cpua, pa razmisli...
http://www.anandtech.com/cpuchipsets...spx?i=2149&p=7
+ to da daje 64 bita, za budućnost...
još uvijek mi nije jasno zašto bi ljudi danas htjeli kupiti p4...
više para za sporiji proc?Your call, though!
Svijet je monitor s beskonačnom rezolucijom!
1.a64 3500+,abit av8,1.5gb corsair, leadtek geforce 6800 ultra,2x200gb seagate@raid 0,tagan 480w...
2.mobilac 2600+ na 2332mhz,epox 8rda3i,r9800pro,120gb,512ddr,ener 350w...
3.MSI centrino 1.5(dothan), ati9600,40gb...
-->HDD u externom kućištu USB 2.0+firewire-hitachi 200 giga
dr.fiksi je offline   Reply With Quote
Staro 13.08.2004., 22:21   #16
mitzek
Prigorec po defaultu
mitzek's Avatar
Lokacija: Pušća Gornja
Postovi: 1,410
Talking dotureee.....
Originally posted by dr.fiksi
Mani se p4...
razlozi:
pregrijavanje
nebi ulazil u prepirku,al brate pusti i nas budale da se veselimo!!!!
nit smo najbrži, nit smo najjači u benchmarku, nit smo ultra gameri niti...,al to je naš izbor i cijeni to,kako i mi drugi cijenimo Tvoj izbor.
možda smo stari debili,al ak hočemo voziti te Pente,pustite nas da živimo u zabludi...kad se prosvjetlimo..bumo se vrnuli na Tulce!!(već jesmo,khem!!!)...
jer kad se okrene, našlo bu se par Intelaša koji buju jahali po tebi i Amdu---a to brate,već i piceki popevaju kad se iz jajčeka ispile!!!
Pametni imaju i jedno i drugo i nije ih puno briga za trenutnog championa,ne????
slikce:http://my.opera.com/Mitzek/blog/
sig na dijeti..,bolje on nege JA......
mitzek je offline   Reply With Quote
Staro 13.08.2004., 22:25   #17
dr.fiksi
dr.fiksi's Avatar
Postovi: 1,043
Pokušavam ga samo "prosvijetliti", dati dobar savjet...
on će odlučiti.Još uvijek vlada reklama, i broj Mhz, što je dokaz da se ljudi malo razumiju, a još manje razmišljaju ili uoće ne kad kupuju...
još da ga je kupovao prije dosta vremena, možda i da-ali danas kad ima bolji i JEFTINIJI izbor...
Staro 13.08.2004., 22:34   #18
mitzek
mitzek's Avatar
Postovi: 1,410
Unhappy tjah....
imaš potpuno pravo,ALI... ma ....nebi sad u polemiku ko stra baba.....nisam baš pri volji,buju rekli da se sam hoću svadit i da trabunjam,pa bolje da se držim Žderonja,tam me bar i počaste nakon kaj me probaju zaje... ,a ja im vratim!!! ovak ,mislim da bi se samo nastavila trakavica najgnusnije teme svakog hjebenog foruma o PCu na ovom globusu,right? i zato, pis brader i wlcome tudu whatju wiš.....
svako ima pravo da kaže svoje mišljenje,a o ovoj temi mam je trakavica,pa da ne trošimo resurse, odoh ja na Žderonje!!
Staro 13.08.2004., 22:44   #19
dr.fiksi
dr.fiksi's Avatar
Postovi: 1,043
Re: tjah....
Niti se svađam, niti pokušavam
ovo nije AMD vs intel tema, već stvar savjeta(ne samo mog!)
postoje moderni benchmarci, postoji budućnost i postoje neki faktori, kao i činjenice!Ovo dakle nije stvar nasumičnog mišljenja ili privrženosti.Ja uostalom uvijek kupujem proizvod po svojoj potrebi, bio to intel ili amd, ati ili nvidija...ja nisam rob imena!Uvijek savjetujem svakom da potraži nove podatke, da bude siguran
da je to ono što želi...jer ima ljudi koji prospu pare i onda:"Kako je to tvoj na 2000Mhz brži od mog na 3200?", onda je kasno...
Staro 13.08.2004., 22:53   #20
mitzek
mitzek's Avatar
Postovi: 1,410
Re: Re: tjah....
pusti faktore i činjenice, jer ljudska je glupost nemjerljiva ikojim benchmarkom, neko jednostavno mora prvo popušiti da bi nešto usvojio,al opet, ovo je (uvjetno)slobodna zemlja, pa svako radi kak smatra da je za njega najbolje..kad se malo zaje..., onda kuka i plače ...a zato smo mi ovdje,ne?
ne sporim tvoje faktore i činjenice, samo naglašavam naš Balkanjero mentalitet, koji, htjeli-ne htjeli stalno izranja po malo, pa čak i ovdje...eto,svakom za pravo, i svi sretni!(prije ili kasnije,)
Staro 13.08.2004., 23:00   #21
dr.fiksi
dr.fiksi's Avatar
Postovi: 1,043
Re: Re: Re: tjah....
Ah, pravo kažeš
Balkanjero mentalitet, pravo kažeš!Kažem ti to jer sam čuo hrpu ljudi kako tako kukaju!Idu glavom kroz zid, dok ga ne probiju!...
taj "mentalitet" mi ne pogoduje , ali kad je takvo opće okruženje, onda katkad niti nema izbora...
no, stanimo!Možda smo već potpuno zbunili čovjeka koji želi konfu!
Ovo je i tako neki offtopic
Staro 13.08.2004., 23:22   #22
tomelhajd
Postovi: 33
ok uzeo budem athlona ali me jos przi ati x800 pro jel hocu vrhunske preformanse a to mi se cini kao dobar izbor i medu skupljim karticama jos uvijek nekak povoljno za dane preformanse iako cijena od cirka 3000 kn :confused: nije za prijeci lagano preko nje ali opet nadam se da ce uz 1 gb rama(geil) i amd 3000+ hladen zalmanom 7000b-cu nesto i dati samo jedva cekam da ga upiknem u struju :clap:
Staro 13.08.2004., 23:33   #23
dr.fiksi
dr.fiksi's Avatar
Postovi: 1,043
Imaš pare?
Dobar izbor...
ali ovako-ako možeš iscijediti još dosta stotina kuna, najbolji izbor ti je gf 6800gt!Inače, cijela 6800 serija, pa i obična 6800, ne ultra ili GT najbolji je izbor!Zasada...Dakle, odluči se između 6800, 6800gt, ili ultre!To su sada top kartice!Moja preporuka je da pokušaš iscijediti lovu za 6800gt, pa OC na ultru!Ako ne, onda obična 6800...
Imaš leadteka, gainwarda...
leadtek je najtiši ako je to bitno!(Meni je!)
x800 je odličan, ali više nije top...
Staro 13.08.2004., 23:36   #24
tomelhajd
Postovi: 33
jos se samo dvoumim izmedu abit kv8-max3 mbo i chaintech vnf3-250 nforce3 250 a s parama sam onak na granici pa cu ostat pri x800 to bi trebalo bibit dostatno valjda
Staro 13.08.2004., 23:38   #25
tomelhajd
Postovi: 33
a ako i iscijedim ponesto kunica vise dali je gainwardova 6800gt puno brza od x800 pro?
Staro 13.08.2004., 23:40   #26
mitzek
mitzek's Avatar
Postovi: 1,410
Talking hinc!vidla žaba da se konji potkivaju....
tako je dete!!!sam razvali kasicu Starcima!! ili si dovoljno lud da za tak finu konfu daješ vlastite ,teškom mukom zarađene pare?normalno ,nisi..pa još bi si mogel i Corsaira piknut i Antec tp,pa i reseratora da te ne hjebe grijanje, jer nekom ni Zalman nije dost..pa ...hijao.....fakat sam il za ludaru il za Miroševac kad se tu upličem,ja sam stari konj,raga koja nemre više pratit ovo brže,bolje,više,jače.....Kapituliram!!!živel AMD!Živjela kp,Žderonje,ma živili mi svi,rođo!!!!!
jes da je offtopic al moro sam prosr.t ,rođo!!!
bah!!sad sam fakat ogladnil i ožednil!!!
btw,a ziher sam da sutra Intel objavi neki Ultra uradak ,da bi mali drukčije cvrkutal,ali..ma bahhh!to je tak još od Durona i Celića...ma i odranije...
Staro 13.08.2004., 23:40   #27
dr.fiksi
dr.fiksi's Avatar
Postovi: 1,043
Odi na ovaj link...
http://www.anandtech.com/video/showdoc.aspx?i=2146&p=3
pogledaj!
gf 6800 je jeftinija, čak i manje od 2500kn mislim, a bolja je i brža definitivno od ati x800 pro!
Ostatak love možeš sačuvati, ili usmjeriti prema a64 3200+, jer tada dobivaš 1Mb L2 cache!
update:
P U N O je brža...(gt od x800 pro)
pogledaj link!Ako uspiješ...a čak ti je i 6800 bolja opcija!
Odi na chaintech.Odličan OC!
Staro 13.08.2004., 23:46   #28
tomelhajd
Postovi: 33
a sto se stabilnosti tice? neznam puno o 6800 gt nisam citao a x800 pro je prilicno stabilan i dosta dobar
Staro 13.08.2004., 23:51   #29
dr.fiksi
dr.fiksi's Avatar
Postovi: 1,043
Stabilan kao 1 000 stijena!
Bez brige!To te ne treba brinuti...
Osim toga, opremljen je za budućnost, shaderi 3.0 itd, što garantira da neće odmah zastarjeti!
Ja sam imam ultru, nema frke!Ista kartica je GT,samo s manjom frekvencijom...no možeš OCati!
Garantiram ti 100% da ti komp neće biti nestabilan od te kartice, ako uzmeš dobro napajanje-OK si!
I sjeti me se kad budeš prašio doom 3, Far cry ili tak nešt...!
Samo uzeti brand name napajanje od cirka 400w, i super!
Imaš još kakvo pitanje?
Staro 13.08.2004., 23:52   #30
mitzek
mitzek's Avatar
Postovi: 1,410
Talking e sad,dobro ga futraš..
Odi na ovaj link...
pogledaj!
update:
sve to stoji,al kaj če mu sve to???ja sam nakon 3 2krilna ormara hw napokon shvatil da nemrem imat uvjek naj....
več bu preksutra Ati izbacil neku zver kaj bu jela gtejku za gablec,Corsair izbacil ddr sa 15000mhz cas0.0005 latencijama i ....kud sve to ide rođo..samo dajete putra trulom potrošačkom duhu kojem još uvijek nije mjesto na balkanskom poluotoku,al ak vas veseli, nabijajte postove i dalje...
ja preferiram ovakvo prijateljsko uvjeravanje...
Zadnje izmijenjeno od: mitzek. 12.07.2007. u 16:37.
Oglas Oglasni prostor
