Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Karajan???
Zbunj:confused: Baš gledam novosti na siteu svog omiljenog proizvođača matičnih i vidim da za sljedeću generaciju (Intel LGA 775 ) ploča, za zvuk piše 8-channel Karajan... Može me netko prosvjetliti?...to je nekaj baš novo ili... |
Lokacija: Zd
Postovi: 218
8-channel high definition audio... kao, toliko je high da su mu dali ime po slavnom dirigentu (Herbert von Karajan)
#3 | |
Super Moderators
Postovi: 17,485
Piše: Audio: Azalia audio codec with independent variable sampling rate S/PDIF-in/out interface 8-channel audio output A pod Rear Panel I/O Ports: Karajan audio card (6 audio jacks) Newly introduced in these soon-to-be-released LANPARTY motherboards is DFI’s Karajan audio technology. Motherboards such as the DFI LANPARTY nF3 ULTRA-D are equipped with this. On normal motherboards, analog audio signals from onboard audio codecs are always subjected to noise from the high-speed busses on the motherboard. On a quality sound card, analog audio signals are still prone to noise, but it is far less than that induced for onboard sound. Karjan audio was introduced to reduce signal noise to produce much more clearer audio by placing the audio codec on a tiny riser located right at the ATX rear I/O deck with all the required ports on this riser as well. The idea sounds swell and when we do receive DFI’s latest LANPARTY motherboards in the near future, we’ll evaluate if this extra effort by DFI paid off. Baš me zanima na kaj bu to ličilo. |
#4 | |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,158
drugima za implementiranje u sire tokove proizvodnje odnosno sireg usvajanja nekog standardiziranog rjesenja. Samo interna rjesenja (gledajuci obecanje te tehnologije) bas ne gutaju takve novotarije. Drugim rjecima kao i brdo tehnologije sa vlastitim rjesenjima nije imalo nikakvih opipljivijih ucinaka. Razno konektori, standardi komunikacije, puno ih je ostalo samo u proizvodima vlastitih kreatora proizvodjaca. Tako da samo vrijeme moze pokzati hoce li ista biti od tog Karajana. Samo po specifikacijama, rekao bih bas nista posebno ni revolucionarno za predvidjeni segment. Ono sto je blesavo je Bastrardizacija imena za ovakve gluparije. Kad High End zvucnik dobije ime po kompozitoru moze se probaviti ali koja je relacija Karajana i ove tehnologije....samo nebo zna ![]() |
