8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,162
Kao sto sam spominjao u nekim proslim post-ovima, polako se razdanjuju problemi oko kvalitete izrade + pojedinost sa kojima ce se DL imati za nosit (za sada) na stetu korisnika. Prvo mali quote : *** Low Yields, High Prices Part of the reason for the low supply is that double-layer discs are difficult to make, Clatterbuck claims. Each disc has two dye layers that hold the data sandwiched together. The manufacturing process is far more complicated than that of single-layer discs, so the yields (the percentage of usable discs that are produced out of the total) are still low. "A typical single-layer DVD yield is typically 90 to 92 percent; the double-layer (yield) right now is probably around 50 percent," says Clatterbuck. In other words, manufacturers end up throwing away around half of the discs they produce because they aren't up to snuff. "And the thing that you are throwing away is more expensive than a single [layer disc] because you have more dye and have had to put more technology into producing it." *** Link : http://www.pcworld.com/news/article/0,aid,116915,00.asp Link : http://www.pcworld.com/news/article/0,aid,116265,00.asp |
(°_°)
Postovi: 3,249
to mi vise zvuci kao marketinski trik da bi opravdali visoku cijenu medija. slicna galama se dizala i oko DVDa (u pocetcima), isto je proizvodni proces bio jako "skup", puno skuplji od obicnih cda jel je dye trebao biti drugacije konzistencije... i gle na sta je sad pao dvd-r, na cijenu CD-Ra pred 1.5godine. mislim, ako ih prodaju po recimo 6.5 kn, uzevsi u obzir pdv, marzu jednog preprodavaca, drugog, proizvodjaca i stoznacega, kolko ih kosta izrada, 1kn? a DL 2-3kn? ![]()
Toshiba m200 TabletPC + Samsung 205BW |
#3 | |
Junior Member
Datum registracije: May 2003
Postovi: 3,205
RIGHT Citiraj:
__________________ |
8-bit Gen.
Postovi: 3,162
Ono sto je jako vazno za znati kad se bira DL drive je sljedece : Tehnologija pisanja koja je ce biti poptuno ostavljena od svih proizvodjaca u novim modelima firmware-ima je * Z-CLV * Novija adoptacija se zove * P-CAV = Partial CAV. Dok se * Z-CLV koristi/o da se "dohvati" maksimalna brzina pisanja. Vec se duze P-CAV smatra daleko pouzdaniji za pisanje jer ne skace izmedju zona vec polagano ubrzava brzinu pisanja do svog maksimuma. Takodjer za DL je jako vazno (neki kazu presudno) nesto sto se zove : Bitsetting Mnogi testovi su vec potvrdili da P-CAV daje bolje performanse u pisanju i Z-CLV ce brzo ispariti. (Osim mozda u jeftilenima) Dakle, ovo treba imati na umu kad se uzima novi DL jer je samo pitanje vremena kad ce ga svi preuzeti. Sve je ovo samo jedan od problema i stvari sa kojima ce se susretati nestrpljivi vlasnici ovih uredjaja. |
Postovi: 1,116
tocno tako, odokativno bar jos pola godine.
SS |
