Staro 26.07.2004., 09:38   #1
Bit
Datum registracije: Aug 2003
Postovi: 27
Valjaju li ovi monitori
Code:
Model:                    Flatron T710PH
Zaslon:                   17" (16" vidljivo)
Premaz:                   AGARAS
Razmak točaka:            0,25 mm
Horizontalna frekvencija: 30 - 85 KHz
Vertikalna frekvencija:   50 - 160 Hz
Sučelje:                  15-pin D-sub
Maksimalna razlučivost:   1280 × 1024 @ 75 Hz
                          1024 × 768 @ 85 Hz
                          Max. 1600 × 1200 @ 68 Hz
Potrošnja:                Max. 73 W
Napajanje:                240 V 50 Hz 2,0 A
Masa:                     15,7 kg
Standardi:                TCO99
Ostale karakteristike:    BrightView
Code:
Model:                    Microscan P920
Zaslon:                   19" (vidljivo 17.7")
                          Anti-Static, Anti-Glare, TCO treatment coated
Razmak točaka:            H 0.22 mm
Horizontalna frekvencija: 30 - 96 KHz
Vertikalna frekvencija:   50 - 150 Hz
Sučelje:                  15-pin D-sub VGA
Maksimalna razlučivost:   1600×1200@75
Potrošnja:                < 90W
Napajanje:                240 VAC, 2.5A
Dimenzije:                446 (Š) × 461 (V) × 457 (D) mm
Masa:                     19 kg
Standardi:                VESA DPMS, VESA DDC 1 & 2B, cTULus, CB, TUV-GS,
                          SEMKO, FIMKO, TCO, FCC class B, CE, VCCI
Bit je offline   Reply With Quote
Staro 26.07.2004., 13:27   #2
Raven_1
Night shift
Raven_1's Avatar
Datum registracije: Jul 2002
Postovi: 884
Microscan P92 je srednja žalost, po specifikacijama 17" monitor s većom dijagonalom. Što se tiče Flatrona T710PH to je srednja klasa za 17" monitore. Radije uzmi LG Flatron F700P ili Samsung SyncMaster 757DFX ili 797DF.
Proc: AMD X2 3800+ cooled by TT BigTyphoon
Matična: ABIT AN8 SLI
RAM: 2x512MB OCZ Platinum EL rev2 PC3200
Grafička: SAPPHIRE ATI RADEON HD3450 256MB
HDD: WD 40GB i Samsung 160GB @ 7200
RW:DVD-ROM Pioneer DVD-106
PSU: 420W Xilence RedWing
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again."
--uoɥʇʎd ʎʇuoɯ--
Raven_1 je offline   Reply With Quote
