Lokacija: vel.gorica
Postovi: 303
(riješeno) Vista ne želi prikazati hidden folders
vista mi ne zeli prikazati hidden foldere, ukljucim tu opciju u folders options-stisnem apply, ok i nista. odem ponovno u folders options i automatski vrati na do not show hidden folder... kak to rijesit? |
Postovi: 303
rijeseno, evo rjesenja: Be aware that you actually may be infected by a virus, or maybe you once was, and the registry didnt get proberly restored. You should open the registry, but remember to back it up. You can make a restore point in system restore, or just open the registry and export the whole thing, or export some selected keys. Start >> Run >> (type) regedit >> (rightclick on the little my computer icon, and export the whole thing.) find this key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced. Go to the rightside of the window, where the values are. Find the value "Hidden" . Rightclick it and modify it to 1. This next text is from my own registry. Kopy it to notepad, then rename the notepad file, so it have the extension .reg ,and then doubleclick it.: Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden] "Text"="@shell32.dll,-30499" "Type"="group" "Bitmap"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\ 00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,53,00,\ 48,00,45,00,4c,00,4c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,34,00,00,\ 00 "HelpID"="shell.hlp#51131" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\NOHIDDEN] "RegPath"="Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Advanced" "Text"="@shell32.dll,-30501" "Type"="radio" "CheckedValue"=dword:00000002 "ValueName"="Hidden" "DefaultValue"=dword:00000002 "HKeyRoot"=dword:80000001 "HelpID"="shell.hlp#51104" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL] "RegPath"="Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Advanced" "Text"="@shell32.dll,-30500" "Type"="radio" "CheckedValue"=dword:00000001 "ValueName"="Hidden" "DefaultValue"=dword:00000002 "HKeyRoot"=dword:80000001 "HelpID"="shell.hlp#51105" |
