Staro 22.07.2004., 15:19   #1
morski
morski's Avatar
Datum registracije: Jul 2004
Lokacija: Lovran
Postovi: 16
Konfa za 7500-8000 kunića
CPU INTEL PENTIUM4 2.8 GHz (800 MHz, 1MB), Socket 478, Prescott
Zalman 7000A-CU Cooler, cijeli od bakra, za Intel Pentium4 (Socket478), AMD Athlon/ Duron/ AthlonXP (Socket 462) i AMD Athlon64 (Socket754), hladnjak s 92mm ventilatorom, 1350-2400rpm, 2-ball bearing, Fan Speed Controller, 20-25dBA, 773g
EPoX IR Adapter (5.25")
HDD Seagate ST3120026AS, 120 GB 8MB, S-ATA150, 7200
CD-RW/DVD-ROM LG, 52x CD-R/32x CD-RW/16x DVD/52x CD-ROM speed, all in one, ATAPI, retail, 2MB buffer, SuperLink Buffer Underrun Error Protection
DVD+RW/-RW PIONEER DVR-107, DVD+R (8x), DVD+RW (4x), DVD-R (8x), DVD-RW(4x), CD-R (24x), CD-RW (24x), 2MB buffer, bulk
FDD 1.44 MB TEAC
Sapphire Radeon 9600XT 128MB DDR, TVout, DVI
Speakers TEAC Power Max PM-60, 2x60W PMPO (2x0.8W RMS), 120-18000Hz
LOGITECH Internet Keyboard, HR raspored tipki, OEM
LOGITECH, optički miš s kotačićem, PS2 S90 OEM
CODEGEN midi tower 6066-C9, 420W, P4, USB, srebrno; 475x195x445; 5.25"x4, 3.5"x2, 3.5" (hidden)x5 NOVO!
Fax modem externi 56k V.90/Voice/Speak./SVD PRO-NETS Conexant (Rockwell) /VD56SP
Mislim uzet ovu konfiguraciju i sad imam nekih dvojbi:
Maticne:
MB EPoX 4PDA5+, Sck478, Intel 865-PE, FSB533/800, UDMA100, 4 x SerialATA (SATA RAID 0,1,10,5), 5PCI, AGP(8x), 4DDR, 8 channel sound (digital audio out), Gigabit LAN, USB2.0, ATX
ili
MB GIGABYTE 8IPE1000PROG, Sck478, Intel 865PE, FSB 800/533, Serial ATA, UDMA133, 5PCI, AGP8x, 4DDR (Dual channel 400/333/266MHz), 6-channel sound, Gigabit LAN, USB 2.0, FireWire, HT, ATX
RAM:
DDR 512 MB 184 pin, PC3200, 400MHz , A-Data, V-Data DDR 512 MB 184 pin, PC3200, 400MHz , A-Data, V-Data
ili
DDR 512MB 184 pin, 500MHz, KINGMAX HardCore Series
I nemojte mi moplim vas zapocinjat temu o tome kako je AMD bolji jer ja jednostavno vise volim intela i nije mi problem dat parsto kuna vise za nj.
Hvala
morski je offline   Reply With Quote
Staro 22.07.2004., 21:14   #2
Raven_1
Night shift
Raven_1's Avatar
Datum registracije: Jul 2002
Postovi: 884
1. Ako uzimaš Intela zašto ne uzmeš ploču s i 875 chipsetom, ali ako ti nije bitna razlika od 7-10% u preformansama onda uzmi radij Epox, nego Gigabyte.
2. Zašto uzimaš combo drive kad imaš PIONEER DVR-107 koji bolje čita DVD-ove od LG-a. Radije to uloži u dodatne ventilatore jer se Prescott prilično grije.
3. Ja bi uzeo kvalitetnije napajanje i prostranije kućište, ali ako smatraš da ti je Codegen ok onda ga uzmi.
4. Što se tiče RAM-a za Intel je bolje da ima više MHz nego niske latencije. To je bitno i ako budeš dizao FSB da ti memorija ne bude ograničenje.
Proc: AMD X2 3800+ cooled by TT BigTyphoon
Matična: ABIT AN8 SLI
RAM: 2x512MB OCZ Platinum EL rev2 PC3200
Grafička: SAPPHIRE ATI RADEON HD3450 256MB
HDD: WD 40GB i Samsung 160GB @ 7200
RW:DVD-ROM Pioneer DVD-106
PSU: 420W Xilence RedWing
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again."
--uoɥʇʎd ʎʇuoɯ--
Raven_1 je offline   Reply With Quote
Staro 22.07.2004., 21:56   #3
morski
morski's Avatar
Lokacija: Lovran
Postovi: 16
1. Znaci Gigabyte
2. LG otpada
3. Daj mi prijedlog iz VE-mil cijenika
4. Kingmax
Staro 22.07.2004., 22:36   #4
LuXor
Lokacija: Bjelovar
Postovi: 752
Zaboravi Gygabyte!!!
Rađe EpoX...
I mogao bi uzeti "ne-prescott" proc, dakle northwood i Abit IC7-MAX3 ili ASUS P4C800E-Deluxe, jer te matčne imaju i875 chipset.
Živio Kingmax HardCore!!!!!!!!!!!!1
(ili, ako si pri novcima, uzmi CorsaurMicro XMS512-4000C2 PRO memoriju, jer je to nabolje što postoji!):clap: :clap: :clap:
LuXor je offline   Reply With Quote
