Zaključane teme
Staro 13.02.2009., 12:10   #1291
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
kod mene su bili ovakvi...
Preheben rez, samo vrhunska napajanja imaju tako mali pad napona.
E wolv, jel si koristio one 6pin na 8pin PCI-E adaptere? Jel uredno dela sa takvim adapterom?
Gilbert5 je offline
Staro 13.02.2009., 12:15   #1292
Wolverine
Wolverine's Avatar
Postovi: 12,429
nisam pošto TX750W ima 4x 6+2PCI-e konektora
ali sa nekim drugim napajanjima sam morao koristit onaj 6 na 8pin adapter i sve je delalo kako treba
btw samo da napomenem jedan Spire 750W je sa jednom HD4870x2 na +12V padao ispod 11,36V nakon čega je gasio komp
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Wolverine je online
Staro 14.02.2009., 21:25   #1293
D@nt3
D@nt3's Avatar
Postovi: 144
frendu treba napajanje. Konfa je slijedeća:
Core 2 Quad 9550 4X2,8 ghz
6 GB rama kingmax ddr2 800 mhz
Asus GTX 295
ASUS P5K-E WiFi
2 harda i prža.
Zadnje izmijenjeno od: D@nt3. 14.02.2009. u 21:38.
D@nt3 je offline
Staro 14.02.2009., 22:01   #1294
Big Guy
RPG player
Postovi: 1,574
I hate to see you leave, but I love to watch you go
Big Guy je offline
Staro 14.02.2009., 22:25   #1295
Wolverine
Wolverine's Avatar
Postovi: 12,429
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Wolverine je online
Staro 14.02.2009., 23:04   #1296
Big Guy
RPG player
Postovi: 1,574
@Wolverine
nisi mi odogovio prije , pa te pitam opet
koje bi napajanje bilo najbolje (omjer uloženog/dobivenog), a koje najjače po sirovoj snazi
Napajanje Xilence 1200W Gaming Edition, Modular = 1366 kn
COOLER MASTER Real Pro 1250W = 1999 kn
Napajanje SILVERSTONE Power Supply Strider ST1000, 1000W = 1508 kn (nisam našao ST1200 kod nas)
Napajanje CORSAIR 1000W, HX Series CMPSU-1000HX , modularno, 12cm vent = 1674 kn
ne kupujem ništa takvog, znam da svaki mogao tjerati bar 10 konfi kao moj laptop , samo me zanima ako se isplati uzeti ova ostala napajanja pored npr corsair 1000W ili relativno jeftinog Xilence 1200W
i
koliko sam skužio ti si koristio TX750W za DFI LP UT X48 T3RS, Intel QX6850 @3,5GHz, 2x HD4870x2 i max potrošnja iz mreže je bila 944W, a to je malo više nego je napajanje deklarirano (750W) pa me zanima da li sva dobra napajanja mogu dati više od deklariranog i koliko više ?
Big Guy je offline
Staro 14.02.2009., 23:20   #1297
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,312
HX je najbolji jer se sastoji od dva TX-a 750. Isto kao i TTovo 1500W koje je Beren jednom testirao na PCE.
Moraš razumjeti da potrošnja iz mreže nije snaga koju PSU daje, već ona ovisi o iskoristivosti PSU-a.
Recimo, da je u full loadu oko 80% učinovito, tak da pomnoži 944W sa 0.8 i dobiti ćeš snagu koju PSU isporučuje.
Sva dobra napajanja mogu dati više od deklariranog, dobro ne baš sva. ... TX650 recimo ne daje više od deklariranog prema testovima, a moje bi trebalo bit deklarirano na 700W. . . .
Gilbert5 je offline
Staro 14.02.2009., 23:28   #1298
Big Guy
RPG player
Postovi: 1,574
jesam pomnožio, zato sam i napisao da daje malo više od deklariranog
944x0.8 = 755.2W
i to je sa minimalnom iskoristivosti od 80%, a mogla bi biti veća
Big Guy je offline
Staro 14.02.2009., 23:38   #1299
Hei$$e
Hei$$e's Avatar
Lokacija: Našice
Postovi: 444
Autor Gilbert5 Pregled postova
Čitao sam to nekidan na HS-u. Stvarno premoćno napajanje. Čak je i nešto bolje od Toughpowera 1500w zbog boljih kondenzatora. Jel TX650 Seasonic S12 650 ili S12 600?
Zadnje izmijenjeno od: Hei$$e. 15.02.2009. u 00:38.
Hei$$e je offline
Staro 14.02.2009., 23:42   #1300
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,312
Autor Big Guy Pregled postova
944x0.8 = 755.2W
Pitanje kako je vatmetar točan, ova potrošnja je bila u peaku vjerovatno...samo najkvalitetnija napajanja mogu kontinuirano raditi na maximalnim deklariranim vrjednostima. Tako da samo neka mogu raditi van deklariranih specifikacija, a još manji postotak ih to može napraviti bez obzira na trajanja opterećenja.
Gilbert5 je offline
Staro 15.02.2009., 00:01   #1301
Big Guy
RPG player
Postovi: 1,574
@Hei$$e
tx650 je corsair
s12 je seasonc
@Gilbert5
istina, sumnjam da kolega ima neki za 3 tisućice kn
ali da je i max 750W to je svejedno puno bolje od nekih koji jedva rade na pola deklariranog tako da je to pravih 750W, a ne da se moraju računati razni gubici itd pa se dobije 100W manje od deklariranog jer koja je onda svrha deklaracije kada većina proizvođaća laže
i da bilo je vjerojatno na peak-u sa OCCT + 3DMV, ali ipak treba računati na max potrošnju da se komp ne ugasi kada se ga jako optereti
Big Guy je offline
Staro 15.02.2009., 00:20   #1302
žile
žile's Avatar
Postovi: 3,074
@Hei$$e
tx650 je corsair
s12 je seasonc
TX650=seasonic
Hoćeš reći znači da će na 670W potrošnji npr. ovaj moj TX izdat riku?
Šchit,trebao sam kupit CWT kada je bila još mala razlika u cijeni
žile je offline
Staro 15.02.2009., 00:26   #1303
Big Guy
RPG player
Postovi: 1,574
@žile
aha, ti misliš na tko ga prozvodi, ja sam napisao tko ga potpisuje
Big Guy je offline
Staro 15.02.2009., 00:33   #1304
Hei$$e
Hei$$e's Avatar
Lokacija: Našice
Postovi: 444
Autor žile Pregled postova
TX650=seasonic
Da ali možda je S12 600 pa je zapravo već deklariran na veću snagu pa nemože više davati. Zato sam pitao koji je Seasonic TX650.
Hei$$e je offline
Staro 15.02.2009., 00:41   #1305
Wolverine
Wolverine's Avatar
Postovi: 12,429
Autor Hei$$e Pregled postova
Corsair od Seasonica koristi E+ seriju napajanja
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Wolverine je online
Staro 15.02.2009., 01:11   #1306
Hei$$e
Hei$$e's Avatar
Lokacija: Našice
Postovi: 444
Ali samo za 500+w modele. No nije to bitno, pitam jer TX650 600 ili 650w Seasonic?
Hei$$e je offline
Staro 15.02.2009., 01:28   #1307
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,312
Ne, želim reći da sam pročitao kako se na testovima ponašao. Sve pet, super, samo kaj nema snage izvan specifikacija kao recimo 450/550VX...82+ serija enermaxa...itd. Al to je samo lijepo za pročitati, malo kome će to zaista biti bitno....eventualno Razeru ili Wolvu koji spaja brutale od kartica gore pa može reći kaj je sve delalo bez beda - iako po nazivnoj snazi to nebi bilo za zaključiti.
Kada mu bude previše, samo se elagantno zagasi i nikome ništa.
Gilbert5 je offline
Staro 15.02.2009., 11:55   #1308
Wolverine
Wolverine's Avatar
Postovi: 12,429
Pa već sam ti odgovorio to je E+ serija
no to si mogao i sam provjeriti
S12 600
S12 E+ 650W
TX650
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Wolverine je online
Staro 15.02.2009., 13:08   #1309
Hei$$e
Hei$$e's Avatar
Lokacija: Našice
Postovi: 444
Zahvaljujem na odgovoru. Ipak moja pretpostavka nije točna
Hei$$e je offline
Staro 16.02.2009., 14:24   #1310
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
370W, PC POWER (PCP&C) Silencer, 80 PLUS
Došlo vrijeme da i ja kupim napajanje s kojim ću se osjećat u najmanju ruku sigurniji... Pročitao sam puno preporuka i znam napajanja koja su najviše pohvaljena i predložena onaj 450W VX ak se ne varam corsair i FORTRON 400W PNF... (fortrona sam u više navrata stavljao u računala i sve 5), međutim, kako je moja situacija vrlo delikatna... heh, trebam napajanje sa 80mm ventom... Jer u kućištu mi je takav 'airduct' smiješan. Mislo sam da nema veze. Međutim ima. Sad trenutno imam LCpower 420W koji se jako grije, sad, reći ćete preslabo, to sam i ja mislio, pa sam jednom imao prilike isprobat komp s fortronom 400W i isto se jako grije... (Nema hladnog zraka da ga ohladi, a onaj frontier drek je bio hladan jer je imao 80mm)
A strah me uzeti bilo koje jer se bojim buke koju proizvode te manje turbine, pa mi je za oko zapeo gore navedeni model i još jedan...
Sharkoon SHA350-8P, pa sad...
Komp mi ne troši mega puno struje (Vidi 'moj komp')
Imate iskustvas tima, preporuke?
Tomtam je offline
Staro 16.02.2009., 14:48   #1311
Big Guy
RPG player
Postovi: 1,574
Big Guy je offline
Staro 16.02.2009., 14:53   #1312
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
Pa za Te pare ima Corsa CX400...
-POP- je offline
Staro 16.02.2009., 14:56   #1313
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
Autor -POP- Pregled postova
cak i jeftinije - Corsair 400W.
Burko je offline
Staro 16.02.2009., 15:17   #1314
Postovi: 34,028
Konačno da je nešto u Linksu pojeftinilo. Znam da je bilo preko 400kn (406 ili 409kn) tj. 50kn skuplje nego u adm-u, a sad je jeftinije nego tamo.
coconut je offline
Staro 16.02.2009., 15:21   #1315
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
Opa, danas/sutra uzimam napajanje. Sad kad vidim ove cijene i VX450W mi je u igri...
-POP- je offline
Staro 16.02.2009., 15:32   #1316
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
Za to napajanje sam i pitao...
Autor Burko Pregled postova
Corsair taj ima 120mm vent, a meni treba od 80mm.
Tomtam je offline
Staro 16.02.2009., 15:36   #1317
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
Zašto ti treba sa 80mm?!
-POP- je offline
Staro 16.02.2009., 15:53   #1318
Wolverine
Wolverine's Avatar
Postovi: 12,429
slobodno uzmi taj PC P&C, nećeš se razočarati
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Wolverine je online
Staro 16.02.2009., 15:59   #1319
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
Ma 'airduct' imam neki koji baš ne radi dobro s 12cm (vidi u moj prvi post)
OK, hvala!
Tomtam je offline
Staro 16.02.2009., 16:00   #1320
Burko
Burko's Avatar
Postovi: 2,317
Autor Tomtam Pregled postova
koliko sam skuzio, tebe je strah da se ventilator previse cuje, pa hoces bas psu sa 80mm ventilatorom? ako je taj slucaj, sto veci ventilator - manji broj okretaja da bi se dobio veci protok zraka (zanemarimo lezajeve, koliko je tih, bla bla).
a inace je ova cijena zaista jako dobra, ne znam zasto uopce razmisljati o icemu drugom osim ovog corsa?
Burko je offline
Zaključane teme
