Zaključane teme
Staro 14.02.2009., 17:31   #1
mister92
mister92's Avatar
Datum registracije: Aug 2008
Postovi: 223
Ganged i Unganged način rada
imam plocu koju vidite pod moj komp, i sad verzija biosa najnovija F3 kada sam flasho nemam vise opciju za ganged znaci za ukljucivanje dual channela, pa mi to bas nema smisla, jel zna netko mozda da li je to u novom biosu pod nesto drugo ili stvarno neam podrske sto mi je jaako cudno
mister92 je offline
Staro 14.02.2009., 17:44   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Nema to veze sa dc-om, ta opcija je maknuta na preporuku AMD-a.
Jelc je offline
Staro 14.02.2009., 18:09   #3
mister92
mister92's Avatar
Postovi: 223
zasto je maknuta, kaj to znaci da sad vise nemogu iskoristit DC
mister92 je offline
Staro 14.02.2009., 18:46   #4
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor Black Warrior Pregled postova
Pa nije to ukljucivalo DC!
Kak ja imam dual channel, a uopce ni nemam te opcije.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline
Staro 14.02.2009., 19:53   #5
Postovi: 7,568
Officially, the classic ganged mode provides the fastest memory access in single-threaded applications, while the unganged mode is called to improve the performance of multi-threaded software. Synthetic test results will be published in a separate review, and today we'll focus on real-life applications. As for the question if we were right, the 0.1 point (0.1%) difference is hardly a reason to start using the Unganged mode in primary tests. Especially as the Ganged mode is motherboard default, and even the 10 times higher value (1%) would still be negligible as a possible measurement error.
Izvor: iXBT Labs i 5 sekundi u Googleu, a net imaš još takvih recenezija i objašnjena ko u priči, pa sljedeći put prije otvaranja nove teme ne bi bilo na odmet odvojiti mali dio vremena na pretragu.
McG je offline
Staro 15.02.2009., 00:40   #6
mister92
mister92's Avatar
Postovi: 223
ok fala puno
mister92 je offline
Zaključane teme
