Staro 05.02.2009., 15:38   #1
Jujo
Jujo's Avatar
Postovi: 37
BSOD??? HELP!!!
Dakle, moj problem je, hmm, vec dosadan. Imam Windows XP, i u zadnje vrijeme (mjesec dana) mi se svakih 6-7 sati (max.) pojavi BSOD i restarta komp. To me iritira jer me onda disconnecta s neta, prekine DL i slicno.
Pitanje: U cemu bi mogao biti problem?
P.S. Kad mi se sljedeci put pojavi, prepisat cu error message pa napisat ovdje
Jujo je offline   Reply With Quote
Staro 05.02.2009., 15:40   #2
Dr.Who
Dr.Who's Avatar
Lokacija: ST/ZG
Postovi: 580
za pocetak napisi konfiguraciju
Dobri trgovci: 1,2,3,4,5,6,7,8,9,10,11,12,13...
KUPUJEM
Dr.Who je offline   Reply With Quote
Staro 05.02.2009., 16:45   #3
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,953
m4dm4n je online   Reply With Quote
Staro 06.02.2009., 20:33   #4
Jujo
Jujo's Avatar
Postovi: 37
@dr. who: Molim umjesto velike slike staviti malu sa linkom na veliku
@m4dm4n: DL-ao sam program, installao, stisnuo analyze i pod Analisis pise:
Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
No crash dumps have been found on your computer
Conclusion
Crash dumps are enabled and no crash dumps have been found on your computer. In case your computer does experience sudden reboots it is likely these are caused by malfunctioning hardware or power failure. Then it's suggested you contact the support department of the manufacturer of your system or test your system with a memory test utility for further investigation.
Vjerojatno, jer nije bilo crasheva od kad sam install program, dakle u zadnjih 10 minuta :P
Cim bude, pasteam report
EDIT: Danas kupujem novi CPU Intel Dual Core 2.2Ghz, pa cu vidjet sto ce biti...
Zadnje izmijenjeno od: LAcy. 07.02.2009. u 19:02. Razlog: Novi CPU
Staro 06.02.2009., 21:35   #5
Jujo
Jujo's Avatar
Postovi: 37
Evo, pojavio se taj BSOD i otvorio sam WhoCrashed, ali i dalje isto pise...
Anyway, uspio sam zapisati neke podatke o BSOD-u...
Privrhu je pisalo:
Code:
KERNEL_DATA_INPAGE_ERROR
A dole kod memory dumpa je bio sljedeci kod:
Code:
0x0000007A
Nadam se da to pomaze
Staro 07.02.2009., 17:23   #6
thopok
Lokacija: Splity
Postovi: 3,003
Stop 0x7A is usually caused by a bad block (sector) in a paging file, a virus, a disk controller error, or failing RAM. In rare cases, it is caused when nonpaged pool resources run out. It is also caused by defective hardware.
Conclusion
Staro 08.02.2009., 12:23   #7
Jujo
Jujo's Avatar
Postovi: 37
Btw. problem rijesen nanovo instaliranim Windowsima, novim procesorom i novim hardom
Staro 13.02.2009., 15:14   #8
OpticPen
Postovi: 21
Autor Jujo Pregled postova
btw, ti nisi rijesio problem, vec si obrisao stari os, promjenio procesor i hdd. to je sad potpuno nova konfiguracija na kojoj se vrti novo-instaliran os. to kao da ja sad kazem, imam problem taj i taj .. i sutra kazem da sam ga rijesio tako da sam kupio novu konfiguraciju, sa novim windowsima. po meni to ne znaci da sam rijesio problem.
OpticPen je offline   Reply With Quote
Staro 13.02.2009., 16:50   #9
Jujo
Jujo's Avatar
Postovi: 37
Problem vise ne postoji... Dakle, rijesen je :P
A zasto problem ne postoji i kako je rijesen, nije bitno, nego je bitno da ne postoji, osim ako postoji, sto nije istina zbog toga sto ne postoji, jer sam ja unutar ovih tjedan i pol koliko imam nove komponente (tijekom kojeg nije bilo nikakvih ispada ovog problema) shvatio da je problem NEPOSTOJECI...
Nadam se da ste me svi shvatili :P
Staro 14.03.2009., 03:22   #10
matijab
Problem?
matijab's Avatar
Lokacija: negdje u fotelji
Postovi: 90
kakvi filozofi majko moja mila, ovo je previse
za to treba imat muda prijatelju, za to treba imat muda
matijab je offline   Reply With Quote
Staro 14.03.2009., 04:08   #11
miro123
Lokacija: wTC
Postovi: 18
baš,onda za svaki probem je rješenje novi hardver
miro123 je offline   Reply With Quote
