Staro 12.01.2009., 01:26   #1
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,535
Quake Live
Dobio sam danas mail da sam postao QUAKE LIVE Tester Ni ne sjećam se kad sam i kako se prijavio. Registrirao se, skinio plug in i probao. Super radi, grafika je ok, igrivost također.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Zadnje izmijenjeno od: LAcy. 15.01.2009. u 13:47.
LAcy je online   Reply With Quote
Staro 12.01.2009., 01:35   #2
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
mozesh malo detaljnije? (ukoliko je dopusteno)
tehnologija iza toga? (flash, neki OpenGL plugin ...)
ta beta je samo za windowse (ili je mozda OS independant?) ...
danij3l je offline   Reply With Quote
Staro 12.01.2009., 01:38   #3
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,107
I ako imas kakvu pozivnicu za to, samo salji
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 12.01.2009., 07:30   #4
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,535
Sinoć sam samo probao i otišao spavati, bacite pogled na www.quakelive.com. Tamo se prijavite kao tester i ako vam se posreći ovdje kreirate acc.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 13.01.2009., 22:55   #5
xEnomania
xEnomania's Avatar
Lokacija: Purger city
Postovi: 109
ja kad sam prvi put čuo da će Id radit na web based verziji novog Quakea onda su spomenuli da bi imao novi engine Tech 5 i kao nove neke opcije u igri, no od toga je ispalo skoro ništa, no nemam dakako ništa protiv ponovnog populariziranja Quake 3a.
You called down the thunder.
xEnomania je offline   Reply With Quote
Staro 13.01.2009., 23:10   #6
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,535
Nisam puno igrao ali live radi odlično, nema laga, trzanja bilo čega. Kretanje je brzo baš kako volim. Slika postavki govori da nekakav engine ipak je a ne flash.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 14.01.2009., 07:50   #7
Mad_Duke
Kakvo je kretanje, gameplay opcenito naspram quake-a 3?
Da li postoji neka vrsta konzole ili je cisto what you see is what you get?
Da li ima neka od mapa is quake 3 ( ne TA) ?
Da li treba imati quake 3 instaliran, opcenito mi nije jasno posto ide preko "flasha" ?
Staro 14.01.2009., 08:19   #8
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,535
Napisao sam već da je kretanje jednako kao i u quaku, brzo, naravno ima skakanje, saginjanje, sporije hodanje.
Što misliš pod konzolom?
Može se igrati u full screenu. Za mape ne znam, mogu pogledati.
Ne treba imati instaliran Quake 3, kod prijave i registracije se skine plug in, koji je koliko sam skužio zapravo neki 3D engine. Grafika se vidi na slici, nije najbolja ikad viđena ali nije uopće loša.
Jučer sam malo igrao protiv živih protivnika i radi odlično, bez imalo trzanja, nema problema sa pingom iako idem preko wirelessa a i utorrent je radio u pozadini. Zapravo mrežni dio je odlično napravljen.
Kad se ulogira dobije se prikaz trenutnih mečeva, tip (death mach, CTF...), skill u odnosu na procijenjeni moj... Sad nisam kod kuće ako vas zanima mogu staviti screen shotove.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 14.01.2009., 14:31   #9
Mad_Duke
Ma ne mora izgledati dobro, zapravo, sto je gora slika to bolje. zanimalo me da li postoji nes tipa konzola (tilda) da se jos narihta grafika ili je samo dostupno ono sto je u opcijama pod klikom.
Valjda dobim da probam hehe
Staro 14.01.2009., 15:57   #10
_Cox
_Cox's Avatar
Lokacija: Komin
Postovi: 89
I ja sam beta tester i evo vidim ponovno vratili pozivnice. Imam ih 5 na raspolaganju. Jednu sam vec obeca. Lacy dodaj me pod frende, nick: _Cox
EDIT: Nema konzole, barem je ja nisam uspia nac.
Zadnje izmijenjeno od: _Cox. 14.01.2009. u 16:12.
_Cox je offline   Reply With Quote
Staro 14.01.2009., 17:15   #11
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
nema konzole nemres namjestiti fov ni ista sto je govno....
al igra je q3 u browzeru mislim da bi taj live mogao izvuci fps iz bjedila u kojem se sad nalazi u smislu natjecanja.
.i.
Razer Blade 15
Staro 14.01.2009., 19:10   #12
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,535
Autor Codiac Pregled postova
Može se namjestiti fov.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Zadnje izmijenjeno od: LAcy. 15.01.2009. u 13:48.
Staro 14.01.2009., 19:39   #13
Codiac
bycod
Codiac's Avatar
Postovi: 6,699
jebga lacy ja nevidim tu fov...
.i.
Razer Blade 15
Staro 15.01.2009., 00:42   #14
stripy
a-wAnnaBe
stripy's Avatar
Postovi: 419
prvo, krshite NDA stavljajuci screenove.
dalje da ispravim neke netocne navode
-ima conzole (ctrl+alt+tilda i onda ak ocesh samo tildu "com_allowconsole 1"), ali sumnjam da ce vama ishta trebati a da se nemoze preko menua.
-nikad nije bilo receno da ce biti na id tech 5 enginu, ovo je malo updejtani q3 engine.
-ne treba se imati q3 instaliran, prilikom prvog spajanja se downloda plugin i onda se pere.
-vecina settingsa koje nariktate su server side i vezu se uz vash acc, tako da od kud god se logirate vas cekaju vashe postavke.
-onaj ekran nije kad se srushi, nego kad rade neki veci update na serveru, ili kad su ga premjeshtali.
ako netko oce invate nek pita na #quake.hr @ quakenet
lp
MBO: DFI LAN PARTY UT nF4 Ultra-D
MBO DFI Lan Party DK P35-T2RS S.775
Kingmax DDR2-800 KLDE88F 2 GB
Gigabyte VGA nVidia 8800GT 512MB
Antec super-midi kućište P182B crno
Arctic Cooling VGA cooler Accelero S1
Arctic Cooling turbo modul
Pioneer DVD ± RW DL DVR-215BK SATA
Cooler Master Hyper TX2 CPU hladnjak
Corsair 520HXEU ATX 2.2 modularno
CPU INTEL Core2Duo 8400
stripy je offline   Reply With Quote
Staro 15.01.2009., 00:52   #15
Mad_Duke
@_Cox -> Hvala na pozivnici.
Moram reci da radi super.
Jedino me smeta sto nema u opcijama da maknem oruzja da se ne vide. Ali ako konzola radi onda je i to rijeseno.
Jedino mi nije jasno. Ako je server side. Kako rade configi. Tj. dal ih mogu napraviti. Nis, probat cu sutra pa javim! Sad ide njonjat!
Ali brijem da ce to biti dobro. Nema excessive i ostalih izrod modova koji su mi okupirali liste kada bi se casual htio spojiti negdje!
Staro 15.01.2009., 01:03   #16
stripy
a-wAnnaBe
stripy's Avatar
Postovi: 419
cg_drawGun "0"
XP - %appdata%\id Software\quakelive\
Vista - %APPDATA%\..\LocalLow\id Software\quakelive\
i evo par commandi
http://quakefour.net/ql/
http://www.holysh1t.net/quake-live-beginner-guides/
hf
Staro 15.01.2009., 13:36   #17
fear1666
fear1666's Avatar
Postovi: 86
ima ko pozivnicu da mi posalje?? plz )
fear1666 je offline   Reply With Quote
Staro 15.01.2009., 13:39   #18
Valg
Lokacija: City
Postovi: 1,404
Pozivnica i za mene, ako se nađe, jer mi nisu gadovi htjeli poslati KEY!
Valg je offline   Reply With Quote
Staro 15.01.2009., 17:08   #19
ejSid
Lunatic
ejSid's Avatar
Postovi: 213
Evo i ja bio molio pozivnicu ako tko ima? hvala
ejSid je offline   Reply With Quote
Staro 16.01.2009., 15:40   #20
_Cox
_Cox's Avatar
Lokacija: Komin
Postovi: 89
Evo dobia sam novih 5 pozivnica, amo ime, prezime i mail na pm.
Staro 16.01.2009., 19:05   #21
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
@stripy - hvala za pozivnicu
Staro 16.01.2009., 19:10   #22
fear1666
fear1666's Avatar
Postovi: 86
Autor fear1666 Pregled postova
dajte ljudi plz, jedva cekam iskusati ovo )
Staro 20.01.2009., 08:55   #23
dani77
dani77's Avatar
Lokacija: Val
Postovi: 304
Kako sam dobio tako i dajem (thx _Cox)
10 pozivnica ceka nove vlasnike
Saljite na PM ime, prezime i mail
dani77 je offline   Reply With Quote
Staro 20.01.2009., 09:38   #24
stripy
a-wAnnaBe
stripy's Avatar
Postovi: 419
ja zato molim da me ne PM-ate
kao sto rekoh, samo dodjite na #quake.hr @ quakenet, tamo ce se uvijek naci netko s invajtom.
lp
Staro 20.01.2009., 16:21   #25
_Cox
_Cox's Avatar
Lokacija: Komin
Postovi: 89
Evo i kod mene 10.
Staro 21.01.2009., 14:53   #26
Punio4
Punio4's Avatar
Lokacija: Zagreb, Maksimir
Postovi: 437
Probao, no imam svako malo lagspikeove... Ne znam da li je do mene ili Qlivea.
Punio4 je offline   Reply With Quote
Staro 21.01.2009., 15:59   #27
stripy
a-wAnnaBe
stripy's Avatar
Postovi: 419
moram priznat da je jucer dost* bilo server lagova, tako da ako si jucer igrao nije do tebe.
*unutar 20min recimo 4 njih po gdje se na 2sec svi smrznu
Staro 20.02.2009., 23:17   #28
stripy
a-wAnnaBe
stripy's Avatar
Postovi: 419
samo info svima koji imaju acc, a ne zele ga izgubiti... da se ulogiraju do nedelje jednom.
jer ce se brisati neaktivni accovi (tko nije igrao 28dana), prije otvarannja tzv open bete.
a ostalima onda znaci informacija da se u srijedu mogu priduziti u beti quakelive-a.
Staro 21.02.2009., 13:45   #29
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
ako netko hoce invite:
imam jos 3 komada
samo posaljite na PM: First Name, Last Name, E-mail Address, Skill Level
DeadMan+ je offline   Reply With Quote
Staro 22.02.2009., 15:57   #30
stripy
a-wAnnaBe
stripy's Avatar
Postovi: 419
ili se strpite do 24.02? http://www.quakelive.com/
