Staro 10.01.2009., 18:00   #1
PSP User
PSP User's Avatar
Lokacija: Vukovar
Postovi: 74
Pomoc pri instalaciji wlan kartice Linux
Dobio sam drivere za wlan karticu no imam poteskoca pri instalaciji, zastanem ovdje:
Ovo su upute:
Code:
BUILD AND INSTALLATION INSTRUCTIONS
hybrid-portsrc.tar.gz
hybrid-portsrc-x86_64.tar.gz
On the target machine, setup the source/hybrid/build directory
1.  Create a new directory:                 mkdir hybrid_wl
2.  Go to that directory:                   cd hybrid_wl
3.  Untar the appropriate 32/64 bit file
      to that directory
        32 bit:                             tar -xzf <path>/hybrid-portsrc.tar.gz
        64 bit:                             tar -xzf <path>/hybrid-portsrc-x86_64.tar.gz
After untar'ing you should have a src and lib sub directory plus a Linux
2.6 "kbuild" external makefile (Makefile).   The lib sub directory has the pre-built
binary, wlc_hybrid.o_shipped.
You use the standard Linux 2.6 kernel build system as follows to make a Linux loadable
kernel module (LKM):
On the target machine, and cd'ed to the directory that contains the Makefile (fragment)
4.  Cleanup (optional):                  make -C /lib/modules/<2.6.xx.xx>/build M=`pwd` clean
5.  Build the LKM, i.e. wl.ko:           make -C /lib/modules/<2.6.xx.xx>/build M=`pwd`
You should now have a LKM, wl.ko inside this directory.
Sve je ok, dodjem do:
make -C /lib/modules/2.6.21.5/build M=`pwd`
i tu mi javi:
make: Entering directory '/usr/src/linux.2.6.21.5
scripts/Makefile.build:17 /usr/src/linux-2.6.21.5/pwd/Makefile: No such file or directory
make[1]: *** No rule to make target '/usr/src/linux-2.6.21.5/pwd/Makefile'. Stop.
make: *** [_module_pwd] Error 2
make: Leaving directory '/usr/src/linux-2.6.21.5'
HELP!!!!
PSP User je offline   Reply With Quote
Staro 10.01.2009., 19:18   #2
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,777
Polako...koja je točno kartica,koji čip (lspci ili lspci -v),koja distra,koji kernel (uname -r)?
Staro 13.01.2009., 19:02   #3
PSP User
PSP User's Avatar
Lokacija: Vukovar
Postovi: 74
Kartica je: Broadcom 4322AG 802.11a/b/g/draft-n Wi-Fi Adapter
distribucija je Backtrack 3 na USBu instaliran...
Staro 13.01.2009., 21:25   #4
tomek@vz
tomek@vz's Avatar
Postovi: 4,777
Što kažu slijedeće komande:
1) dmesg
2) lsmod
3) lspci (ako je PCI kartica) ili lsusb (ako je USB stick)
Staro 14.01.2009., 17:31   #5
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
i da ovo ti je Lspci i Lsusb
@tomek moram do varazdina sa lapom skociti
.i.
Razer Blade 15
Staro 14.01.2009., 22:31   #6
tomek@vz
tomek@vz's Avatar
Postovi: 4,777
Autor Codiac Pregled postova
anytime
