Staro 12.01.2009., 16:38   #1
Rofellos
Rofellos's Avatar
Lokacija: ZGB
Postovi: 90
Problemi sa przilicom
kiddara
Your Organization/Home Here
1A23-0009-6030-1294-2086-1014
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22.7.2004 17:33:44
Nero version: 6.3.1.25
Recorder: Version: 9P53 - HA 4 TA 1 - 6.3.1.25
Adapter driver: HA 4
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: Version: 9P53 - HA 4 TA 1 - 6.3.1.25
=== Scsi-Device-Map ===
DiskPeripheral : Hitachi HDS721612PLA380 atapi Port 0 ID 0 DMA: On
DiskPeripheral : Seagate ST3160021A 8.01 mv61xx Port 4 ID 0 DMA: Off
CdRomPeripheral : ATAPI DVD A DH20A4P 9P53 mv61xx Port 4 ID 1 DMA: Off
ArrayPeripheral : MARVELL Virtual Device 1.00 mv61xx Port 4 ID 20 DMA: Off
=== CDRom-Device-Map ===
ATAPI DVD A DH20A4P E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 1962MB (2009712kB)
Memory in use : 22 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.1.2009
ISO compilation
16:03:26 #1 Text 0 File Isodoc.cpp, Line 6083
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
16:03:26 #2 Text 0 File Reader.cpp, Line 126
Reader running
16:03:26 #3 Text 0 File Writer.cpp, Line 124
Writer ATAPI DVD A DH20A4P running
16:03:26 #4 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
16:03:26 #5 Text 0 File Burncd.cpp, Line 3152
Turn on Disc-at-once, using DVD media
16:03:26 #6 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2249327 (499:51.02, 4393MB)
16:03:26 #7 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO (enabled: CD)
16:03:26 #8 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: ATAPI DVD A DH20A4P, Media type: DVD+R
Disc Manufacturer ID: MBIPG101, Media Type ID: R05, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 7
16:03:26 #9 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
16:03:27 #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2249328 (2249328) = #2249328/499:51.3
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2249328 blocks [ATAPI DVD A DH20A4P ]
16:03:27 #11 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [ATAPI DVD A DH20A4P ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4606623744, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2249328 | lead-out | 1 | 0x00 | 0x41
16:03:27 #12 Phase 24 File dlgbrnst.cpp, Line 1855
Caching of files started
16:03:27 #13 Text 0 File Burncd.cpp, Line 4163
Cache writing successful.
16:03:27 #14 Phase 25 File dlgbrnst.cpp, Line 1855
Caching of files completed
16:03:27 #15 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 16x (22.160 KB/s)
16:03:27 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
16:03:27 #17 Text 0 File Cdrdrv.cpp, Line 8230
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Media type ID: R05
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 4D 42 49 50 47 - 31 30 31 52 30 35 01 38 ...MBIPG101R05.8
23 54 37 13 02 50 6B 02 - 8C 63 15 15 0B 0B 08 08 #T7..Pk..c......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
16:03:27 #18 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 3:34,846 (214846ms) -> OK
16:03:27 #19 Text 0 File DVDPlusRW.cpp, Line 628
Start write address at LBA 0
DVD high compatibility mode: Yes
16:06:01 #20 SCSI -1024 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 4, TA 1, LUN 0, buffer 0x04000000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x06 0x89 0x60 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x08 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x08 0x03
16:06:01 #21 CDR -1024 File Writer.cpp, Line 304
Communication failure
16:06:01 #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
16:06:02 #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
16:06:08 #24 Phase 127 File dlgbrnst.cpp, Line 1855
Generating DVD high compatibility borders
16:06:27 #25 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
16:06:27 #26 Phase 129 File dlgbrnst.cpp, Line 1855
Generating DVD borders completed successfully
16:06:27 #27 Text 0 File dlgbrnst.cpp, Line 1713
16:06:27 #28 Phase 38 File dlgbrnst.cpp, Line 1855
Burn process failed at 16x (22.160 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 8.3.2007 0:51:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 8.3.2007 0:51:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\mv61xx.sys': Ver= 1.2.0.51 built by: WinDDK, size=143360 bytes, created 18.10.2007 21:22:02 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
HKLM\System\CurrentControlSet\Services\mv61xx\Parameters\Device
mv61xx - NumberOfRequests 32 (recommended: 0)
Uglavnom nezeli mi przit DVD-R,DVD+R, CD-R izbacuje Communication corrupted errore, jedino kaj przi je DVD+RW. Ucemu bi mogoa bit problem*?
Rofellos je offline   Reply With Quote
Staro 12.01.2009., 16:50   #2
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Probaj drugi program za snimanje, ako ne zeli ni onda pogledaj dali ima koji noviji firmware za tu przilicu. Ako ne proradi onda je neispravna i kupuj novu.
