Lokacija: Vukovar
Postovi: 74
Pomoc pri instalaciji wlan kartice Linux
Dobio sam drivere za wlan karticu no imam poteskoca pri instalaciji, zastanem ovdje: Ovo su upute: Code:
BUILD AND INSTALLATION INSTRUCTIONS ----------------------------------- hybrid-portsrc.tar.gz hybrid-portsrc-x86_64.tar.gz On the target machine, setup the source/hybrid/build directory 1. Create a new directory: mkdir hybrid_wl 2. Go to that directory: cd hybrid_wl 3. Untar the appropriate 32/64 bit file to that directory 32 bit: tar -xzf <path>/hybrid-portsrc.tar.gz 64 bit: tar -xzf <path>/hybrid-portsrc-x86_64.tar.gz After untar'ing you should have a src and lib sub directory plus a Linux 2.6 "kbuild" external makefile (Makefile). The lib sub directory has the pre-built binary, wlc_hybrid.o_shipped. You use the standard Linux 2.6 kernel build system as follows to make a Linux loadable kernel module (LKM): On the target machine, and cd'ed to the directory that contains the Makefile (fragment) 4. Cleanup (optional): make -C /lib/modules/<2.6.xx.xx>/build M=`pwd` clean 5. Build the LKM, i.e. wl.ko: make -C /lib/modules/<2.6.xx.xx>/build M=`pwd` You should now have a LKM, wl.ko inside this directory. make -C /lib/modules/2.6.21.5/build M=`pwd` i tu mi javi: make: Entering directory '/usr/src/linux.2.6.21.5 scripts/Makefile.build:17 /usr/src/linux-2.6.21.5/pwd/Makefile: No such file or directory make[1]: *** No rule to make target '/usr/src/linux-2.6.21.5/pwd/Makefile'. Stop. make: *** [_module_pwd] Error 2 make: Leaving directory '/usr/src/linux-2.6.21.5' HELP!!!! |
Lokacija: München/Varaždin
Postovi: 4,770
Polako...koja je točno kartica,koji čip (lspci ili lspci -v),koja distra,koji kernel (uname -r)? |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
i da ovo ti je Lspci i Lsusb ![]() @tomek moram do varazdina sa lapom skociti ![]()
Postovi: 4,770
