Staro 06.01.2009., 15:31   #1
Vragoder
Drone
Vragoder's Avatar
Lokacija: Senj
Postovi: 396
Stellarium - virtualni teleskop
Sličan google mapsima - samo sa pogledom u nebo i to u stvarnom vremenu.
Stellarium is a free open source planetarium for your computer. It shows a realistic sky in 3D, just like what you see with the naked eye, binoculars or a telescope.
It is being used in planetarium projectors. Just set your coordinates and go.
Features:
sky
default catalogue of over 600,000 stars
extra catalogues with more than 210 million stars
asterisms and illustrations of the constellations
constellations for eleven different cultures
images of nebulae (full Messier catalogue
realistic Milky Way
very realistic atmosphere, sunrise and sunset
the planets and their satellites
interface
a powerful zoom
time control
multilingual interface
fisheye projection for planetarium domes
spheric mirror projection for your own low-cost dome
all new graphical interface and extensive keyboard control
telescope control
visualisation
equatorial and azimuthal grids
star twinkling
shooting stars
eclipse simulation
skinnable landscapes, now with spheric panorama projection
customisability
add your own deep sky objects, landscapes, constellation images, scripts...
http://www.stellarium.org/
Linkano u članku Započnite 2009. pogledom u nebo! na net.hr.
Vragoder je offline   Reply With Quote
Staro 06.01.2009., 16:01   #2
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ajd da probam...
.i.
Razer Blade 15
Staro 06.01.2009., 16:50   #3
Vragoder
Drone
Vragoder's Avatar
Lokacija: Senj
Postovi: 396
Interface je dosta zahvalan, a kako bi bio vidljiv cijelo vrijeme, potrebno je kursorom dotaknuti donji lijevi kut ekrana, i kliknuti na dva mala trokuta.
Pretraživač sadrži neke hrvatske gradove (zapravo pogled iz njih), a za sve ostale lokacije - precizan kalkulator za zemljopisnu širinu i dužinu (baziran na Google mapsima):
http://www.satsig.net/maps/lat-long-finder.htm
Put your mouse cursor near your location and double click or just drag the map. The map display will move so that the selected point is in the centre. The latitude and longitude of the centre of the map is then shown below the map.
EDIT: Osim pogleda sa Zemlje, Stellarium sadrži pogled sa svih planeta i mjeseca u Sunčanom sistemu.
Zadnje izmijenjeno od: Vragoder. 06.01.2009. u 17:59.
