Zaključane teme
Staro 28.12.2008., 22:11   #901
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,129
Za telefon probaj BluePhoneElite, a za DVD probaj ffmpegx. A ako ne nadjes bas neku zamjenu, uvijek ti ostaju Parallels/VMware Fusion+Dozeri
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
^SuperUnknown^ je offline
Staro 28.12.2008., 22:53   #902
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Samo jedno pitanje:
DA li tvoja grafa ima kombinirano DVI - VGA konektor?
Ako ima probaj spojit na VGA konektor ako ti ga monitor ima
Mene je zezalo na 8400GS upravo to, nema slike preko DVIa, a preko VGA sranja ima
pozdrav..nema vga konektor...samo DVI
Hamm je online
Staro 28.12.2008., 22:59   #903
Roberto
Roberto's Avatar
Postovi: 2,655
Thanx,
Oba rade kak spada u onom što im je namjena, ali sad ću morat nabaviti i još neki program za syncati i prebacivati imenik, iSync mi ne radi s dvije od 4 nokie koje imam doma
Roberto je offline
Staro 28.12.2008., 23:13   #904
^SuperUnknown^
Prečupavi mod
Postovi: 9,129
Cudno, meni sa K800i dela savrseno
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 29.12.2008., 00:16   #905
Roberto
Roberto's Avatar
Postovi: 2,655
Eto, moj mob nije podržan
Našao sam i neki plugin, za bolju podršku uređaja, ali šipak. A nažalost bluephoneelite ima samo read only pristup imeniku u telefonu...
Roberto je offline
Staro 29.12.2008., 00:30   #906
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Question...
Koju distru da stavim u kojoj će mi moja zvučna (SB LIve! 24bit CA0106) radit kako treba kad se instaliraju driveri?Kalyway 10.5.2. je čisti promašaj,upgrejd istog također dok ideneb ima svoje muhe...
tomek@vz je offline
Staro 29.12.2008., 00:34   #907
Baja 001
Baja 001's Avatar
Postovi: 7,504
Question...
A da nađeš kext, lakše je nego tražit distru. Na krajukrajeva možeš otvorit topic na InsanelyMacu, i to je to, sigurno znaju.
Baja 001 je offline
Staro 29.12.2008., 23:47   #908
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Da sam našao kext već bi to sam riješio a neda mi se registrirat na forum samo zbog tog jednog problema-zato pitam ovdje pošto sam ovdje već registriran.
tomek@vz je offline
Staro 30.12.2008., 03:34   #909
Baja 001
Baja 001's Avatar
Postovi: 7,504
Isplati se registrirat, jer većina developera (svi) imaju tamo acc i mogu ti dati support, isto tako kako je cijeli forum u Hack duhu, znaju iz prve ruke useri koji imaju sličan problem/rješenje
Baja 001 je offline
Staro 30.12.2008., 10:06   #910
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
Mene još zanima dali se mogu nekako nabacit na ovu moju x1250 na laptopu..driveri od linuxa na kalway 10.5.2...jer mi sve to izgleda slično u terminalu...
boris87 je offline
Staro 30.12.2008., 10:16   #911
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Autor boris87 Pregled postova
Ukratko ne....
Linux distra >> Linux kernel
Mac OS X >> Darwin kernel
A ima tu još par sitnica...
Kontaš?
tomek@vz je offline
Staro 30.12.2008., 14:57   #912
Baja 001
Baja 001's Avatar
Postovi: 7,504
Ukratko ne....
Kontaš?
Kratko i jasno
Tada bi već odavno bio OSX debelo podržan na PCovima
Baja 001 je offline
Staro 30.12.2008., 15:10   #913
Roberto
Roberto's Avatar
Postovi: 2,655
Kad bi to bilo tak jednostavno...
Pogledajte si samo za primjer Intel WiFi 3945abg driver. Prije godinu dana su ga krenuli portati od postojećeg službenog Intelovog linux drivera, ali do sad nikom nije ta wireless kartica proradila na Macu, najviše što su postigli je da prepozna mrežu, ali ne radi...
Roberto je offline
Staro 30.12.2008., 15:26   #914
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Autor Roberto Pregled postova
Cek, znaci ako bi na Mac stavio Xp nebi wireles niti lan radio, tj nebi imao izlaz na net?
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline
Staro 30.12.2008., 15:37   #915
Roberto
Roberto's Avatar
Postovi: 2,655
Autor Gjurovski Pregled postova
Naravno da bi uz odgovarajući driver, ali ovdje je riječ o hardwareu (WiFi, a ne LAN kartici) koji nije podržan u Macu. Macovi ne koriste ovu Intelovu WiFi karticu pa nema ni kextova za nju. Linux driver i Win XP driver dakako postoje, tako da je napraviti kext (ili portati ga uz modifikacije iz linuxa) posao za entzijaste - naravno, one koji razumiju kako radi taj hardware i znaju programirati
Ako se dobro sjećam s Macovima (barem nekim modelima) dolaze i win xp driveri za uređaje iz Maca, u slučaju da preko BootCampa želiš dići prozore...
Roberto je offline
Staro 30.12.2008., 15:49   #916
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
OT: mislim inace nisam "BIO" ljubitelj Mac-a, no zakacio sam se na ovaj novi Macbook Aluminum 2.0ghz...
Vec duze vremena si planiram uzeti neki lap max velicine 13" a imao sam Asus-a EEE no to nije to, niti ovi noviji modeli sa Intel Atomom, pa koliko sam promatrao trziste za 9000k jednostavno nevidim konkurenciju Macbooku uz uvjet da bi naravno pod obavezno bio Boot Camp na njemu za WinXP a nisam se bas previse koristio Mac OSX-om da bi se i roku sekunde prebacio sa Win...
No ovo sad sa wirelesom mjenja perspektivu
Sorry na OT-u da ne otvaram novu temu bezveze...
Staro 30.12.2008., 16:01   #917
Roberto
Roberto's Avatar
Postovi: 2,655
Kako to misliš da ti mijenja perpektivu? Velim, ako kupiš pravi Mac baziran na Intelu, bez problema ćeš pronaći Xp drivere za uređaje u njemu, pa tako i za wireless. I digneš dual boot (legalno) bez frke.
A ako planiraš od klasičnog PCa ili PC laptopa napraviti ''hackintosh'' tu bi najviše problema mogao imati upravo s wirelessom. Moj HP laptop ima upravo gore navedenu intelovu wifi karticu, i jedino mi ona ne radi kad gore stavim OSX jer nema kexta (drivera) za nju. No i to se može riješiti, na ebayu ima za kupiti alternativnih kartica koje sam možeš staviti u laptop (ne mislim na USB modele, već one koji se ugrađuju u laptop).
Što se tiče OSXa, vjeruj mi, ne bi ti puno trebalo da se snađeš u njemu, vrlo je logičan i dobro osmišljen
Roberto je offline
Staro 30.12.2008., 16:25   #918
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
A tako znaci krivo sam ja shvatio, tnx jos jednom..
Staro 30.12.2008., 18:11   #919
Roberto
Roberto's Avatar
Postovi: 2,655
No problem
Evo ti konkretna informacija:
http://www.apple.com/macosx/features/bootcamp.html
Roberto je offline
Staro 30.12.2008., 23:34   #920
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
Evo uspio sam sve instalirat na svoj komp..samo osto wlan..
Imo svoju karticu d-link dwl-120+ i usb i izgleda da nema sanse da proradi...
Dobijo sad dvi nove..
Air Live Turbo-G WT-2000PCI I Air Live WL-5480USB i opet nista ne prepoznaje...
Evo ako netko ima neku od ovih nek pomogne...ili zna kako da proradi...
boris87 je offline
Staro 30.12.2008., 23:38   #921
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,153
Zanima me što preporučate kao softver za snimanje cd/dvd-a. Probao sam par besplatnih rješenja i brže su bili u trashu nego u app folderu. Nisam ni DVD-RW uspio izbrisati. Pržilice su SATA, H62 i H66 od LG-a
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
1v@n je offline
Staro 30.12.2008., 23:49   #922
deskjett
deskjett's Avatar
Lokacija: zadar
Postovi: 69
Autor 1v@n Pregled postova
toast titanium za przenje!? koji torrent koristite!? probao sam utorrent i kad je upanjen procesor mi radi na 100%, probao ga brisati pa opet instalirati ali uvjek isto!? transmission mi radi normalno
deskjett je offline
Staro 31.12.2008., 00:01   #923
^SuperUnknown^
Prečupavi mod
Postovi: 9,129
Toast Titanium, samo nije besplatan, ali je zakon
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 31.12.2008., 00:05   #924
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,153
Will buy Hvala
LCD: BENQ PD3200Q
1v@n je offline
Staro 31.12.2008., 01:39   #925
Baja 001
Baja 001's Avatar
Postovi: 7,504
PCI kartice ti neće proradit AFAIK
Što se tiče USB kartica, vidi na njihovom webu da slučajno nemaju za Mac, isto tako InsanelyMac je dobar izvor informacija.
Kako su kaže Toast je vrhunski alat, volio bi da se Nero ugleda malo na njega.
Ja osobno perem uTorrent & Transmission. Osobno uTorrent mi je draži ali ima mušica (zasada), dok Transmisson radi bez greške
Baja 001 je offline
Staro 31.12.2008., 01:44   #926
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
Može mala pomoć oko slova y i z na tipkovnici.Sve san stavio na Croatian di se moglo...
Suck Satan's cock
piNheaD je offline
Staro 31.12.2008., 01:58   #927
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,153
Radi radi, trust me. Evo me online već par dana na USRobotics USR5417 ( AirForce One ). Treba samo naći karticu s podržanim čipsetom, a to je problem.
Autor piNheaD Pregled postova
Imaš par stranica prije keyboard layout koji samo ubaciš na disk i odabereš ga u postavkama i sve radi.
LCD: BENQ PD3200Q
1v@n je offline
Staro 31.12.2008., 02:25   #928
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
Evo stavija san onaj fajl i di sad točno u postavkama treba ići?Sorry što san dosadan al ne snalayim se baš u macu
Suck Satan's cock
piNheaD je offline
Staro 31.12.2008., 02:39   #929
Baja 001
Baja 001's Avatar
Postovi: 7,504
Preferences>Keyboard
Baja 001 je offline
Staro 31.12.2008., 11:25   #930
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,153
Preferences - International - Input Menu. U listi nađeš taj fajl i staviš kvačicu, gore kod sata bi ti se trebala pojaviti ikonica tipkovnice.
A možeš doć do toga i brže, klikneš na našu zastavu gore kod sata, pa "open international" i isto staviš kvačicu na to što si dodao - "Cro"
EDIT: Kak na tom novom layoutu upisati @ ?? Start+Shift+2 šljaka samo kad odaberem defaultni hrvatski, ali na ovome ne ide!!
EDIT2: Može li se Opera postaviti kao defaultni browser? Za razliku od win verzije, ovdje te opcije nema u preferences. - riješio sam ovo na kraju, u podešavanjima Safarija treba odabrat operu kao defaultni browser. Mislim, stvarno.
LCD: BENQ PD3200Q
Zadnje izmijenjeno od: 1v@n. 01.01.2009. u 18:50.
1v@n je offline
Zaključane teme
