#2642 |
The mighty pirate
Lokacija: London
Postovi: 9,096
Jel itko zna gdje se u cijelom gradu može naći Comet? ( http://www.playerzblog.com/wp-content/gta4car_comet.jpg ) Treba mi da dostavim onom nekom Brucievom frendu, a auta nigdje. Znam da se može dobiti cheatovima, ali namjeravam cijelu igru proći bez korištenja ijednog.
#2647 |
Lokacija: funtana
Postovi: 130
Step 1: Run Regedit by Clicking on Start -> Run , type in regedit and press enter. Step 2: Browse to "HKEY_LOCAL_MACHINE>SYSTEM>CurrentControlSet>Control>Windows" Step 3: Modify the value of "CSDVersion" from "0x00000200" (SP2) to the Windows XP SP3 value of "0x00000300" (I suppose you could also go to edit > find, and search for CSDVersion that way) Step 4: Close. Step 5: Restart windows (but in most cases an explorer restart will do). |
#2648 | |
Postovi: 747
#2652 |
muimerP
Lokacija: VG
Postovi: 3,334
Ishur´s Guide to Electronic Music Zadnje izmijenjeno od: Halos. 26.12.2008. u 12:55. |
#2653 | |
The mighty pirate
Lokacija: London
Postovi: 9,096
#2654 |
Postovi: 747
#2655 |
Yippie-Ka-Yay
Postovi: 560
ako nekome treba lokacija svih globova, stunt jumpova i tih auta za dostavljanje, jednostavno upišite u internet klubu kao adresu www.whattheydonotwantyoutoknow.com , ima još par korisnih sranja, ne regidtrira se kao cheat i dobro posluži. |
#2656 |
Postovi: 22
So, to make sure you have the correct card, it's easiest to consult the box where the card came in. On the box you will find a green sticker with some barcodes and some serial numbers. The BIOS update is only applicable if on your sticker the serial numbers are:
#2659 | |
Lokacija: rijeka
Postovi: 3,857
#2660 |
Default
Lokacija: Požega
Postovi: 1,512
#2663 |
Datum registracije: Apr 2008
Lokacija: Velika Gorica
Postovi: 471
Statistics Average FPS: 53.41 Duration: 37.07 sec CPU Usage: 74% System memory usage: 91% Video memory usage: 91% Graphics Settings Video Mode: 1680 x 1050 (59 Hz) Texture Quality: High Render Quality: High View Distance: 32 Detail Distance: 70 Hardware Microsoft Windows XP Professional Service Pack 3 Video Adapter: WinFast GTX 260 Extreme+(NVIDIA) Video Driver version: 177.83 Audio Adapter: SB X-Fi Audio [C000] Intel Pentium III Xeon processor Intel Pentium III Xeon processor File ID: benchmark.cli Pitanje: da li da idem povećavat view distance i detail distance iako u postavkama veli da sam sa ovim ispunio svih 896mb memorije (HAHAHAHAHAHAHAHHA BOLESNOČČČČA) |
#2664 | |
its slightly turbocharged
Postovi: 5,430
![]() Ja držim na 1680x1050, bez commandlinea, veichle density 40, view distance - 50 Render - high, detail - medium Ide glatko ko beba, fraps nisam dugo palio ali 30 FPSa sigurno
blaa |
#2665 | |
Postovi: 7,326
kao sto sam vec napisao, ja sam se preporodio kod prelaska sa E5200 @ 3.7GHz na Q6600 @ 3.6GHz ![]() fps u GTA4 je skoro za duplo porastao |
#2668 |
Lokacija: Vinkovci
Postovi: 780
Kako nemos izvuci s tim athlonom 5000 bar 20fpsa, meni Athlon X2 5000 + 9600GT 25fpsa, view distance 25, detail distance 25, i shadows 0, sa onim fixom ide i preko 30 ![]() Zadnje izmijenjeno od: BeroVK. 27.12.2008. u 21:52. |
#2669 |
Lokacija: Orahovica
Postovi: 7,363
Ma neam pojma. Stavio sam sad 8.12 drivere i osla grafika u pm, cesta mi potpuno crna a ostale teksture podivljale. Naravno nezam koje sam prije imao pa ne mogu vratiti. Ajd neka mi netko preporuci drivere koji su oke za moju grafu. |
#2670 |
Yippie-Ka-Yay
Postovi: 560
Ako ti 8.12 ne radi neznam što bi ti trebalo radit. Probaj s onim driverima koje si dobio s grafom. Ako to ne upali probaj flashat BIOS od grafe(meni je riješilo problem s teksturama). |
