Staro 11.12.2008., 18:28   #1
mister92
mister92's Avatar
Datum registracije: Aug 2008
Postovi: 223
Win XP update
Imam win xp sp3 na kompu i laptopu i imam ukljucen automatic update da me samo obavijesti kada dođu novi updejti, ali problem je kaj mi na laptopu lijepo radi update a na kompu uopce nista ne prikazuje niti updaetat, cudan problem stvarno, ali s tim da je prije radio update na oba dva,
mister92 je offline   Reply With Quote
Staro 15.12.2008., 22:43   #2
Bobić
Bobić's Avatar
Lokacija: virovitica
Postovi: 19
Ponekad se zna dogoditi da SP3 ne sjedne kako bi trebao pa se javljaju problemi tvog tipa.
Nekima ovo pomoglo,,, probaj;
1. Open notepad
2. Copy the following text and past it into notepad
*-- copy text from between these comments
@echo off
if exist %windir%\system32\wups2.dll goto fix32
if exist %windir%\syswow64\wups2.dll goto fix64
goto error
:fix32
net stop wuauserv
regsvr32 %windir%\system32\wups2.dll
net start wuauserv
goto eoj
:fix64
net stop wuauserv
regsvr32 %windir%\syswow64\wups2.dll
net start wuauserv
goto eoj
:error
echo Unable to locate wups2.dll operation aborted
:eoj
pause
3. Save the file and name it sp3fix.bat (change the save as type option to all files *.*)
4. Run the sp3fix.bat file
you should get a regsvr32 confirmation window, click OK
your windows updates should now work.
Thanks and good luck
Bobić je offline   Reply With Quote
