Staro 03.12.2008., 10:16   #991
s.u.l.e.l.u.s
s.u.l.e.l.u.s's Avatar
Lokacija: Matulji
Postovi: 305
meni će ubrzo doć......
edit.krivo sam posto....
a vi koji igrate,dali su prenapuhani zahtjevi i kako ide?
s.u.l.e.l.u.s je offline   Reply With Quote
Staro 03.12.2008., 10:33   #992
R2D2x2
Postovi: 152
review
http://au.pc.ign.com/articles/934/934806p1.html
cak su se i IGNovci mucili sa grafikom..
". . . You're going to need a particularly powerful machine to see it in all its splendor at a decent framerate, as even on our system (Core 2 Quad 2.40 GHz, 2 GB RAM, 768 MB GeForce 8800 GTX with Vista 32) we were having performance problems even after toning down a few of the settings, and some of the effects (the shadows in particular) didn't look so hot when displayed in high resolutions."
neki lik sa foruma:
Specs:
DS3L Mobo
4 gig Corsair DDR2 XMS2
MSI Nvidia 8800GT
Vista Ultimate
Benchmarked at 21.5 FPS at 1360 * 768 and 20.2 FPS 1680 * 1050.
No option for Vsync; I have horrible Vsync issues. Tearing is very evident in all cut scences and while driving at night. This is a problem that may be particular to the MSI Nvida 8800GT as in every PC game I have to turn Vsync to on or I have the stated issue.
The game play is poor, unfortunately, with such low FPS. No matter what settings I have I get the same FPS which I find weird. I can have Very High rendering or Low rendering and the FPS are + or - 1. Same with resolution, density and other variables (including view distance)
Also, logitech game pad does not work at the moment. Keyboard / mouse clicks are EXTREMELY sluggish as well.
R2D2x2 je offline   Reply With Quote
Staro 03.12.2008., 10:35   #993
Beo
Lokacija: United Kingdom
Postovi: 512
Mislim da nisu prenapuhani. Osim ako imas 48xx karticu onda ces morat cekat fix.
Ugl koliko sam primjeti na raznim forumima visoke rezolucije nenormalno utjecu na fps.
Zadnje izmijenjeno od: Beo. 03.12.2008. u 10:46.
Beo je offline   Reply With Quote
Staro 03.12.2008., 10:47   #994
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Ma osobno netreba mi vise od 1024x768 sa medium detaljima...
Vec sam igrao igru (doduse PS3 verziju, konzola nije niti bila spojena na LCD sa HDMI kablom tako da je bila daleko od HD reze tj. 1280x720) i nakon 2 minute apsolutno nisam obracao pozornost na grafiku jednostavno me obuzela umalo me nisu potjerali iz ducana
Jos da mi se nejavljaju problemi kod stavljanja SP3 na Xp... zasto bi bilo jednostavno kada moze biti komplicirano
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline   Reply With Quote
Staro 03.12.2008., 10:53   #995
Beo
Postovi: 512
Ja sam si taman prije cca 2 tjedna nabavio mrak verziju xp sa sp3 ko da sam znao da ce mi trebati
Staro 03.12.2008., 10:57   #996
Exe
Exe's Avatar
Postovi: 353
Autor Gjurovski Pregled postova
Vele na dosta foruma da zna doći do problema ako se stavlja na postoječu inst. xp-a.Treba na frišku instalaciju ili da su integrirani več u sam xp kod instalacije.
Exe je online   Reply With Quote
Staro 03.12.2008., 11:00   #997
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Autor Exe Pregled postova
Ma to sam znao i prije nego sto sam poceo skidati SP3 (nadao sam se cudu ), ma neka si ga lagano podanfaju nema teorije da idem stavljati nove win... Nedavno sam ih stavio i sve poslozio, jednostavno nemam volje...
Da se radi o Homeworldu3 ili Dungeon keepperu 3 mozda i bi
Staro 03.12.2008., 12:09   #998
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,245
Koliko je ovo bodova?
Staro 03.12.2008., 12:11   #999
Bang
Datum registracije: Mar 2008
Postovi: 167
neznam jeste pročitali ali u read my fileu ljepo piše da današnji korisnici igru mogu igrati na medium dok će se u budućnosti moći igrati na high.kao pravili su igru za budućnost
neznam jel im to opravdanje za lošu optimizaciju ili su stvarno debili
Bang je offline   Reply With Quote
Staro 03.12.2008., 12:14   #1000
Bang
Postovi: 167
Autor ALiEN17 Pregled postova
mislim dosta za medium
Staro 03.12.2008., 12:15   #1001
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
ja nisam imao problema sa instalacijom SP3-a na postojeće Winowse tako da..... iznenađujuće bilo sve super
btw. više baš nema ljudi u ovo temi, igra se na veliko ja navečer tek
Z-man je offline   Reply With Quote
Staro 03.12.2008., 12:20   #1002
chingyos
chingyos's Avatar
Postovi: 375
Autor Bang Pregled postova
Teski ocaj za rockstar ako je tako...kao prvo to nije neka grafika da nemoze radit na danasnjim konfama...kreteni
chingyos je offline   Reply With Quote
Staro 03.12.2008., 12:24   #1003
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
kupio bih igru al neznam kak ce radit na mojoj konfi sa : athlon 64 3000+, 2GB rama, x1600pro...jel ima ko slicnu konfiguraciju da mi unaprijed kaze ?
gbijelic je offline   Reply With Quote
Staro 03.12.2008., 12:27   #1004
chingyos
chingyos's Avatar
Postovi: 375
Autor gbijelic Pregled postova
Nemoj kupovati igru jel ti nece radit,bolje nadogradi komp
Ljudima s boljim kompovima slabo radi a usput pise da minimum zahtjeva 2 jezgre!
Staro 03.12.2008., 12:29   #1005
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
možda ovi u rokstaru oče reč da če ti na istoj konfi za mjesec - dva radit bolje, pa ti samo kupi... hehe
Pizz je offline   Reply With Quote
Staro 03.12.2008., 12:45   #1006
Bang
Postovi: 167
hehe...neznam stvarno kad ću šta novo stavljat...možda procesor ali tek kada to bude isplativo...a i mogu stavit samo amd-a,a trenutno nevidim baš nekakav izbor
EDIT:iskreno da vam kažem već mi je pun kufer GTA4 i rekvajrmentsa i ostalih pizdarija. a rekvajrmentsi me toliko smetaju da mi je muka od rackstara.nebi a reko da ta igra stvarno treba toliku zahtjevnost i da ona izgleda cajber super duper genijalno,pa ajd trebaš kvad...loše loše loše
I JOŠ JEDAN EDIT:još nikog ama baš nikog nisam našo da u komfi koja pogoni igru ima amd 6000+ x2....nikog..
Staro 03.12.2008., 12:46   #1007
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
ma radit će ti dobro.... relax...
Staro 03.12.2008., 12:49   #1008
chingyos
chingyos's Avatar
Postovi: 375
Pa ne moras nista mjenjati super ti komp...a ako gta 4 ne radi..jasno je da se radi o nemaru programera i o neoptimiziranosti.
Staro 03.12.2008., 12:56   #1009
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
kupim vidim javim
Staro 03.12.2008., 14:17   #1010
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Zakaj ovi glupani na steamu vele da je available za kupiti, a kad kliknem nigdje nema cijene niti onaj checkout kolica?
Matth€w je offline   Reply With Quote
Staro 03.12.2008., 14:33   #1011
BeroVK
Lokacija: Vinkovci
Postovi: 780
Bem ti GTA IV ipak cu morat u shoping po novi procesor i grafu danas postam slike oko 8sati kad cu je dobit
BeroVK je offline   Reply With Quote
Staro 03.12.2008., 14:37   #1012
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Autor BeroVK Pregled postova
ma nemaš potrebe trebalo bi letit na ovom što imaš nije to tak loše
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 03.12.2008., 14:39   #1013
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Autor Ruky Pregled postova
Kakva prva, druga ili treća verzija? Postoji samo jedna, legalna i jedino o njoj smiješ postavljati pitanja.
Staro 03.12.2008., 14:43   #1014
Wolfblade
Wolfblade's Avatar
Lokacija: Lika
Postovi: 609
oce moja kanta moc ovo pokrenut
Wolfblade je offline   Reply With Quote
Staro 03.12.2008., 14:45   #1015
jurbAs
jurbAs's Avatar
Postovi: 2,583
Autor Wolfblade Pregled postova
sa nekom mukom da heheh
Staro 03.12.2008., 14:47   #1016
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
koji imas proc?
Staro 03.12.2008., 14:51   #1017
Wolfblade
Wolfblade's Avatar
Lokacija: Lika
Postovi: 609
Autor jurbAs Pregled postova
znači da ce se igra vuć tj: nece dobro radit?
koji imas proc?
Vidi pod moj komp
Staro 03.12.2008., 14:58   #1018
Lihto
Lihto's Avatar
Postovi: 3,945
znači da ćeš morat pričekat nove drivere ko svi sa HD4800 serijom i valjda patch..dok bi oni sa HD3800 serijom mogli igrat ladno,ja očekujem bacit to na plazmici na 1280x720 na high detaljima jednostavno mora radit
iPhone XR 128gb
Staro 03.12.2008., 15:02   #1019
Ruky
Ruky's Avatar
Postovi: 50
Autor tor Pregled postova
pa ja sam i mislio na tu verziju tj. na orginal kupljenu pa jos sam i napisao najrasirenija. nema veze nije vise bitno bas sam u procesu instaliravanja pa cu vidjet sam. sory na nespretno postavljenom proslom pitanju.
Ruky je offline   Reply With Quote
Staro 03.12.2008., 15:05   #1020
Necto
Necto's Avatar
Postovi: 748
A odakle vi nabavljate te originale ? Meni ovi iz algoritma kazu da nece doc do drugog tjedna, a mozda nece ni drugi tjedan.
Necto je offline   Reply With Quote
