Staro 25.11.2008., 20:12   #1
Mar
Suit up!
Mar's Avatar
Postovi: 5,970
Apple MacBook Revolution - revolucija
Novi tablet/netbook iz Applea... idealno?
Configuration:
Enclosure Precision aluminum unibody
Processor 1.6GHz Intel Atom Processor with HyperThreading support
L2 cache 512KB
System bus 533MHz
Memory 2GB (one 2GB SO-DIMM) of 667MHz DDR2 SDRAM; supports up
to 4GB
Hard drive 16GB Flash SSD integrated
Graphics Intel X4500HD-A Hardware Accelerated Graphics
Video Built-in iSight camera; Mini DisplayPort output port with support for DVI, VGA, and dual-link DVI (requires adapters, sold separately)
Display 8.9-inch (diagonal) LED-backlit glossy widescreen display with Multi-Touch support, 1024-by-600 resolution
USB Two USB 2.0 ports (up to 480 Mbps)
Audio Built-in stereo speakers, built-in omnidirectional microphone, combined optical digital input/analog line in, combined optical digital output/analog line out
Networking Built-in 10/100/1000BASE-T (Gigabit) Ethernet
Wireless Built-in AirPort Extreme Wi-Fi (based on IEEE 802.11n draft specification)2; built-in Bluetooth 2.1 + EDR (Enhanced Data Rate) module
3G wireless modem support on selected models
Hardware accessories
35W MagSafe Power Adapter, AC wall plug, power cord, lithium-polymer battery
Weight
1.9 lbs / 0.86 kg
Staro 25.11.2008., 20:28   #2
AiM
Postovi: 355
ne sumnjam da ce naci kupci ali kad se bolje zapitam. Zasto ??. Nit je NB nit je PDA . Nekako nisam pobornik tih tableta jer su ni vrit ni mimo..
AiM je offline   Reply With Quote
Staro 25.11.2008., 21:03   #3
A.J.
A.J.'s Avatar
Lokacija: Rijeka (Umag)
Postovi: 1,197
ja stvarno neznam za sta bi mi mogao posluzit taj tablet. jedino mozda za video chat ali to ne koristim pa i to otpada
sta stane na 16GB a da moze biti korisno na 9" monitoru
jedino da se koristi kao digitalni okvir kojem se mijenjaju slike (neznam kako se tocno zove)
A.J. je offline   Reply With Quote
Staro 25.11.2008., 21:12   #4
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
9 inca je way premalo...
neka apple nauci nesto od sony-eve Tx serije. 11 inca je minimum minimuma za ista raditi.
.i.
Razer Blade 15
Staro 25.11.2008., 21:15   #5
Razer
Razer's Avatar
Postovi: 11,642
PS FTW
Staro 25.11.2008., 21:16   #6
Mar
Suit up!
Mar's Avatar
Postovi: 5,970
Autor Codiac Pregled postova
Jao kodiače od tebe nisam ovo očekiva
Staro 25.11.2008., 21:20   #7
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Prelos fotosop ...
Tomo je offline   Reply With Quote
Staro 25.11.2008., 21:20   #8
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,161
Ko o cemu, Mar navek na Apple!
Daj neki racun otvori za donacije. Pa da uplatimo i da konacno na stol stavis neki Apple. Cak i Codiac primjecuje koliko te tisti pa se pravi da nije PS uradak
Staro 25.11.2008., 21:24   #9
Codiac
bycod
Codiac's Avatar
Postovi: 6,699
a cuj kad imas 12" sve ostalo ti je premalo sta da kazem
.i.
Razer Blade 15
Staro 25.11.2008., 21:25   #10
Mar
Suit up!
Mar's Avatar
Postovi: 5,970
a cuj kad imas 22" sve ostalo ti je premalo sta da kazem
Jel
Ma slažem se da ispod 12" za te subnotebookove nema smisla ici.
@Visage, je Ajfon je bolji od tvojih Njokija, je da nema offline gps, je da nema tipkovnicu, je da ga za dodatne opcije moraš otključat.... al je tanji... i.... lijepši!
Staro 25.11.2008., 21:27   #11
Func
Func's Avatar
Postovi: 483
Stvarno jedna od beskorisnijih stvari. Ali dobro je znati da OSX ide na atoma.
Some say that he's Mac compatible, and that he once punched a horse to the floor. All we know is, he's called The ...
Func je offline   Reply With Quote
Staro 25.11.2008., 22:05   #12
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,948
Može li neki službeni link ? Koliko se sjećam, Apple je nedavno službeno izjavio kako mu područje netbookva i inih uopće nije interesantno i da ne namjeravaju u njega ulaziti.
m4dm4n je online   Reply With Quote
Staro 25.11.2008., 22:23   #13
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,127
Da, skupa sa blu ray-om
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 25.11.2008., 22:35   #14
Mad_Duke
Autor A.J. Pregled postova
Övo malo djubre je idealno. O tome dal je premalo. Nije. Ako ti je, uzmi si veci i budi sretan. Nekom je 15 incha premalo. Sve je stvar za sto ti treba.
Ovo malo djubre je idealno za sjediti na sastanku, pisati notese preko handwritting recognition softwarea. Mislim da bi ovo moglo biti veoma interesantno. A tko ne kuzi za sto sve tablet moze posluziti, neka ne pokusava shvatiti ovaj tip proizvoda. Ako nije za njega, neka se s njim ne sluzi.
Mene samo jaaaako zanimaju 2 komponente.
1. cijena ( jer ako je djubre totalno precijenjeno, onda definitivno otpada)
2. autonomija.
subjektivno
Da je 10 incha bili bi meni idealno. 9 jos moze proci.
Staro 25.11.2008., 23:02   #15
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,161
Autor Mar Pregled postova
E moj Mare.
Malo po malo, ode ti nama u roblje Stevino
G4 sam imao svega pola mjeseca i nije mi se svidjao estetski idealizam koji je tad vec bolesno nastupio u Apple-u. G3 pismaricu sam imao godinu i bio je jako dobar stroj. Ali zadnji stvarno inovativni model, bejaše 540c. Inace po svim listama, 2-gi najbolji proizvod od Jabucnih prenosnika.
Tad se stvarno mogao pohvaliti da je prvi u kojecemu: Prva pila sa trackpadom. Stereo zvucnici od kojih je odzvanjala soba dok je PC cistio sinuse na mono piezozoiku. PCMCIA, pa onboard LAN pa gomila do tada nevidjenih management zezalica za autonomiju baterije i boljeg rada.
Aktivna matrica koja je doslovno u depresiju bacala kad si je pokusao usporediti sa svime sto je tada bilo na trzistu. Tesko mi je uopce objektivno naci neku usporedbu danasnjih odnosa, koja bi imala jednaku tezinu usporedbe sa tim ekranom - prema svemu sto je bilo konkuretno ponudom tada. Tad si stvarno bio ponosan na svoj Apple i "budi drugaciji" imao je stvarno pokrice.
Neki dan procitah kako je Apple nakon 15 godina, skapirao da mu ideja PowerBook Duo i nije losa za probuditi ponovo. Da se manje glupirao sa rucnim Mar drndalicama, ovo je mogao biti danas proizvod bez premca. ccc
Ne znam za vas, ali ja prvom prilikom moram odgledati The Net (1995) nakon ove price. Sandra je tada morala u svakom filmu imati neku Apple makinu oko sebe. PowerBook (aktivni) Duo se upravo izreklamirao u borbi protiv dušmana.
Nagradno pitanje za Mar-a i ostale :
Od kojeg filma/serije (da malo pomognem) je Apple shvatio da ce mu najbolje dici prodaju > sto veci filmski angazman Macova? Od tog trenutka, Apple postaje najzastupljeniji komp na US platnu.
E moj Mare... ovo su bila vremena :
A ne danas, kad korisnik sam sebi placa da bi otisao na downgrade i pisao po "lepinja salaveta" tipkovnici
Boze glupih li vremena
8
Staro 25.11.2008., 23:40   #16
sick_boy
sick_boy's Avatar
Postovi: 680
Link? Google ne zna za to - rekao bih patka i neloš fotošop.
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 25.11.2008., 23:42   #17
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Novi CS4 na dijelu Točno se po fontu naziva konta da je fake.
Odkud si to pokupio opće? Mislim, meni je ovo totalno nepraktično, kao i cijeli princip ovakvih tableta, služi ko podložak za gablec. Šta će ti ovo kad možeš Makić-Zrakić kupit.
I sigurno ima/bi imalo puno 0 u cijeni.
Matth€w je offline   Reply With Quote
Staro 25.11.2008., 23:54   #18
Mar
Suit up!
Mar's Avatar
Postovi: 5,970
Visage ne shvaća zafrkanciju
@Matthew - nije CS4 nego CS3 homemade macbook
Istina, font je krivi, nisam nasa pravi font ;(, ali kako je većina pala na ovo
Staro 26.11.2008., 00:00   #19
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Buahah, patko jedna!
Nećeš mene!
Nisi napisao dimenzije pa mi je i to smrdilo, pogotovo još kad bi bio Gigabitni Ethernet, bio bi poprilično debel, i težak.
To je ekran od Aira? Mislim da, i inače, Apple nema potrebe za ovakvim proizvodom.
Staro 26.11.2008., 00:25   #20
sick_boy
sick_boy's Avatar
Postovi: 680
Nije da mu ne treba, ali kako bi se uklopili sa svojom cjenovnom politikom u trend jeftinih netbookova?
Ipak, ovakav bi uredjaj bio idealan za surfanje iz fotelje (ustvari ne bi, falile bi mu neke kontrole sa strane, kao na Asusu M2H, da se ne mora olovkom ili masnim prstima napikavati).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 26.11.2008., 00:35   #21
A.J.
A.J.'s Avatar
Postovi: 1,197
ja se jos cudio kako nema na sluzbenoj stranici
nisam mislio da je nekom tolko dosadno, pa imam posla za svakog od vas
Staro 26.11.2008., 01:16   #22
Mad_Duke
A steta. Ja se poveselio nekom relativno jeftinom netbooku koji je tablet.
npr.
http://www.crunchgear.com/2008/11/06...t-impressions/
http://eeepc.net/nec-tablet-netbook/
Staro 26.11.2008., 09:40   #23
Postovi: 34,028
Kad si čuo sa nešto jeftino Appleovo? Ne da će biti precijenjen, nego ultra-mega-turbo precijenjen.
Staro 26.11.2008., 12:11   #24
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Po meni vrijedi svake kune. Dodes, kupis, otvoris, ukljucis, radi. Dovidenja
Staro 26.11.2008., 12:29   #25
Postovi: 34,028
Štima, ali zašto se toliko špiči sa nekim polusoftverima tipa iTunes za najobičniji prijenos podataka na iPod? Nije li c/p sistem, kao kod mnogih drugih, jednostavniji?
Staro 26.11.2008., 12:45   #26
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Zato sto je to apple. Imaju lepi HW, imaju lepi SW. Oni si to mogu priustiti.
Staro 26.11.2008., 13:58   #27
w!cked
Datum registracije: Apr 2008
Lokacija: Zagreb, Zapruđe
Postovi: 48
Autor Tomo Pregled postova
PC - dođeš, kupiš, otvoriš, uključiš, radi. I sve to po tvom izboru i za puno manje para
Nemam ništa protiv apple-a, ali ne stoji ti to gore.
w!cked je offline   Reply With Quote
Staro 26.11.2008., 18:32   #28
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Svaka roba ima svog kupca
Staro 26.11.2008., 19:39   #29
Moree
Postovi: 328
Autor w!cked Pregled postova
Da da, naravno, i jos se k tome srusi 50 puta i zablesira 100. Da si probao radit sa macom, ili da bolje formuliram, da si duze vrijeme radio sa njim imao bi drugacije misljenje.
Posto imam i pc i mac reci cu ti da ni mrtav nebi koristio pc u poslu koji radim
Moree je offline   Reply With Quote
Staro 26.11.2008., 20:20   #30
Mar
Suit up!
Mar's Avatar
Postovi: 5,970
Mislim da nije ni mjesto ni vrijeme za PC vs Mac rasprave
