Staro 19.09.2008., 19:16   #361
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Fleks Pregled postova
A jesi genije, bas si me dobro nasmijao sa ovim
To ti je kao da prebacis neki sugavi mp3 u Flac.
Dakle - nemoguce.
Vidim da su se neki uhvatili pametovat. Zadnji put sam skupio BAN kada sam se zakačio sa nekim pametnjakovićima.
Isto tako radi se o ekipi tj. filmskim kućama koji prodaju Blurayove sa starijim filmovima koji su u većeoj kvaliteti.
Znam i nisam toliki debil da MP3 u FLAC (ili neki drug kvalitetan format) ne daje ništa korisno.
MOj upit je bio kako ti studiji imaju snimke u HDu kada su snimani sa starom opremom, a nakon toga sam mislio da se može nešto tako postić nekakvim rekodiranjem da bi dobio bolju kvalitetu.
Prema tome svi koji pametuju i nemaju konstruktivnih prejdloga neka ..................................
Staro 19.09.2008., 19:20   #362
morph
morph's Avatar
Postovi: 1,530
The very short answer is that there are around 20 million "quality" pixels in a top-quality 35mm shot.
What this means is that a 5300 x 4000 digital camera would produce a shot equivalent to a scan from a quality 35mm camera
How many pixels in a frame of 35mm film?
A 1920x1080 HD signal is only 2 million.
Should be able to salvage enough resolution on old film to make a decent picture.
Q: I just bought a Blu-ray player and am a big fan of old films. Is it possible for older movies that were shot before high-definition existed to really be HD?
A: There’s no reason movies shot on 35-mm film can’t look great in HD; their native resolution is actually far higher than Blu-ray’s. (Remember: These movies were shot to fill huge theater screens.) And when films are scanned into digital, they are brought in at between 2000 and 8000 lines of horizontal resolution—far more than Blu-ray’s 1920 pixels across by 1080 pixels down.
Evo konkstruktivan prijedlog: 1,2
Odgovor nadjen u cca 120 sekundi:
morph je offline   Reply With Quote
Staro 19.09.2008., 19:48   #363
Baja 001
Baja 001's Avatar
Postovi: 7,504
@morph
Zahvaljujem na odgovoru, sada mi je jasnije.
Staro 23.10.2008., 07:11   #364
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Vulgaris seosko pitanje: program za konvertiranje .mkv u .avi? Koji je najbolji i najjednostavniji za nas cobane?
Staro 23.10.2008., 15:46   #365
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,940
Autor Dizel Pregled postova
Why?
Ako je radi gledanja u PowerDVD radi i obično mjenjanje ekstenzija. Uglavnom radi
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je online   Reply With Quote
Staro 23.10.2008., 18:13   #366
žile
žile's Avatar
Postovi: 3,074
Imam i ja njubovsko pitanje-jel se može HD gledat na DVD playeru koji ga službeno ne podržava?
Pretpostavka kako ne može.Zanima me jel ima DVD player koji čita HD,tj. .mkv,i koliko cirka košta,i može preporuka čim boljeg za što manje pare?
žile je offline   Reply With Quote
Staro 23.10.2008., 20:14   #367
dugixy1
Postovi: 577
Autor žile Pregled postova
žile nemože,nema kod nas tako nešto za kupiti,ćak je i vani situacija loša,imaš neke playere koji puštaju mkv ali nestandardnih oblika,potraži,imaš tu na forumu par tema i slikica.ja odavno tražim tako nešto.
poz
edit
http://www.tvix.co.kr/Eng/products/5100sh.aspx
dugixy1 je offline   Reply With Quote
Staro 23.10.2008., 21:33   #368
žile
žile's Avatar
Postovi: 3,074
Hvala.
Pizda im materina.A koliko dođe DVI->HDMI kabl?Tako nešto postoji,jel,čini mi se da sam to vidio ovdje negdje da je spomenuto?
Staro 23.10.2008., 21:48   #369
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Hvala.
A kaj će ti to?
Sa grafom si trebao dobiti DVI-HDMI adapter, ako hoćeš spojit komp na telku koja ima HDMI onda ti treba samo čisti HDMI kabel...
Staro 23.10.2008., 21:53   #370
žile
žile's Avatar
Postovi: 3,074
Hm,možda i jesam dobio,sad mi nije kutija,a ni komp baš pri ruci,koja nije dugačka 200km pa da provjerim.
Jel se gubi na kvaliteti signala pri toj konverziji?Da,u pravu ste,hoću ga spojit na TV.A HDMI-HDMI koliko dođe?Ako će gubit osjetno na kvaliteti dok gledam HD na toj plazmi,i ako kabl košta 100kn,onda ću bolje dodat još malo pa kupit HD4870.Vratit će se ta investicija na računu za struju i plin
Možda lupetam sad,ja sam u ovom svijetu laik koji hoće gledat filmove na plazmi,i najradije bi kupio player
Staro 23.10.2008., 21:59   #371
Jelc
Super Moderators
Postovi: 17,485
HDMI kabel se može kupiti u maltene svakom dućanu, proserčaj malo
A sve novije ATI-ce šalju preko DVI-HDMI i sliku i zvuk, svaka mora dolaziti sa tim adapterom.
Staro 23.10.2008., 21:59   #372
Mr.Ex.President
Torrent freek
Postovi: 3,940
Ma ja san jedno vrijeme spaja na tv, doduše nije plazma, al ima 72 cm
Pa san skužija da mi je skoro isti k. kad se uzme u obzir par parametara koji vas ne zanimaju
Uglavanon glede teme, ja san možda retardiran, al dan danas još nisan uspija natjerat mkv film (koje najčešće konzumiran) da se vrte preko grafičke. I dalje procesor odrađuje sam sve I da se razumimo, nije mi ga ža, ža mi je toga da mi pokoji film zapinje jer neman quad A i rijetko koji 1080p mogu pogledat u miru, šta me frustrira
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 23.10.2008., 23:11   #373
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Why?
ZAto jer DivX playeri ne podrzavaju .mkv kompresiju i trebam rekodirati u .avi.
Staro 23.10.2008., 23:44   #374
Postovi: 7,568
Ako si nabavil kakav sfušano skodirani .mkv, onda nema te sile, codeca i playera koji bude natjeral karticu da ti preuzme to na sebe.
S druge strane konfiguracija ti je i više nego dostatna za fludino gledanje bilo kojeg HDa, osim ako nemaš mali milijun codeca za sve živo i neživo, pa se kolje sve odreda.
Staro 23.10.2008., 23:52   #375
Mr.Ex.President
Torrent freek
Postovi: 3,940
Autor McG Pregled postova
A znaš i sam kakve iman, neću pisat da ne poberen ban
I jasno mi je da pola tih ne radi, ali ostala polovica meni isto ne radi, iako ekipi okolo radi nekih 50% sigurno. U mene je taj postotak 5%
A konfiguracije je ok, al...neznan. Čak i nema toliko codeca...instalacije je doduše prastara, al sve štima. Bili su tu ffdshow i ac3 filter, posli san doda ovih par za HD ali bez previše eksperimentiranja, tako da sumnjam da je zagušeno... Al opet, nešto ne štima, to mi je jasno, jel. Zato i kažem da je očito da san ja retardiran
720 ide ok, 1080i tako-tako, 1080p je negledljiv, tj. je on gledljiv, al mene osobno previše iritira. Naravno sve to se podrazumjeva za nekakvu standardnu kvalitetu, one uber-nabildane video materijale kao šta je ovdje bio onaj Samsungov test klip ne mogu normalno vrtit bio 720, 1080 ili 5652
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 23.10.2008., 23:59   #376
Postovi: 7,568
Kad budeš imal vremena fino složi čiste Windowse, bez trunke codec-pack sranja i divljih (BSplayer i društvo) playera. Pa onda lako prek MPC ili KMplayera (pošto prek npr. VLCa i sl. nema šanse da to složiš jer on ima svoj skup integriranih codeca) podesiš prema vodičima s ove teme da ti kartica preuzima na sebe 720p i 1080p za kojeg si siguran da je pripremljen (DXVA) i skodiran kak spada. Ako radi ljudima s integriranim HD 3200/3300 i raznim verzijama GeForce 8 serije, nema razloga da i kod tebe ne proradi s HD 3850.
Staro 24.10.2008., 00:07   #377
Mr.Ex.President
Torrent freek
Postovi: 3,940
Ma nema ni sad previše codeca, iman MPC i KMP, te u pozadini PowerDVD8 i CoreAVC Pro + ac3 i ffdshow od prije. I to je mislim to. Al ok, windows ima sigurno godinu dana, pa prepisujem to tome, odnosno svom smeću koje se u međuvremenu nakupilo, bilo je tu i Bsplayera i sl. pizdarija, eksperimentiranaj s tv karticama, ovim, onim, koji su vjerovatno unatoč potpunoj deinstalaciji i čišćenju ostavili svoje "korjenje" po sistemu...
A novi windows, testiranja, zajebancije...eh, nije mi ovo toliki problem, da bi se s tim igra, ionako mi je pun k novih windowsa pošto sam ih u zadnjih 60 dana digao bar 20 komada, ne sebi naravno. Većina filmova ionako izađe na 720p prije nego na 1080 pa i nije da se zamaram previše, samo me, eto, nervira, pošto već iman tu nesritnu 3850
Uglavnon fala na.....savjetima, jel
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 24.10.2008., 10:05   #378
žile
žile's Avatar
Postovi: 3,074
Meni radi normalno 1080p sa KLite packom+MPC koji dođe s njime.Kako vidiš šta odrađuje posao,po zauzeću ili?
Staro 24.10.2008., 10:10   #379
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Spustite se iz tih svojih softversko/rekoderskih/enkoderskih shamanskih guru prepredanja i nek mi netko odgovori na moje seljacko pitanje; cime prebaciti taj drkavi .mkv u .avi da mogu ko' covjek gledati film na DivX playeru? Boli me lagano kita za ta HD preseravanja kvalitete slike.
Staro 24.10.2008., 10:16   #380
syss
syss's Avatar
Postovi: 10,805
Staro 13.11.2008., 16:15   #381
Ruky
Ruky's Avatar
Postovi: 50
imam jedan problemcic u htpc-u imam amd 4000+ ali taj procesor mi je full preslab za neke mkv filmove koji su 1080p a hardverska akceleracija bas i ne radi sa mkv fajlovima. tako da sam se odlucio kupiti procesor koji bi to mogao gutati bez problema! u drugom kompu imam intel 8400 i on te filmove zvace sa 40-50% zauzeca kad bi kupio amd 6000+ dal bi to funkcioniralo ko i na intelu?
Ruky je offline   Reply With Quote
Staro 13.11.2008., 16:18   #382
Postovi: 7,568
Kaj ne bi bilo lakše da malo naclockaš taj 4000+ X2 i koje su ti ostale komponente? S druge strane kupnja 6000+ X2 je loš potez jer procesor ne vrijedi te novce.
Staro 13.11.2008., 16:32   #383
Ruky
Ruky's Avatar
Postovi: 50
mislim da ga je nemoguce dovoljno naklokati zato kaj vec steka na filmovima od 6 gb a da ne pricamo o filmovima od 12-15 gb! nije mi bas jasno kak 6000+ ne vrijedi tih novaca kad kosta 600kn a intel 8400 koji ima isto 2 jezgre po 3ghz kosta 1150 kn.
MB Gigabyte MA78GM-S2H to mi je maticna i čiftek napajanje od 400w i 2 gb kingmax rama 800mhz
a na drugom kompu mi je e8400, 3 gb rama kingmax 800mhz, 8800gt, p35-ds3 gigabytei funkcioniraju svi mkv-i bez problema. neda mi se vise zajebavat sa codecima i hardverskim akceleracijama tak da sam odlucio kupiti neki dovoljno jaki procesor ak treba i cetverojezgreni.sano da to funkcionira ali opet nebi bas hto baciti pare u vjetar posto je to samo htpc. jel ima ko ideju koji procesor sa am2 socketom to moze bez hardverske akceleracije?
Staro 13.11.2008., 16:40   #384
Postovi: 7,568
Da, ali E8400 je sasvim druga arhitektura koja slomi taj 6000+ X2 u svakom pogledu i ta dva procesora se ne mogu uspoređivati na temelju radnog takta i cijene. 6000+ X2 ne vrijedi (bar IMHO) te novce je troši ko da nema sutra i već sam po sebi naclockan do same granice. Pored 5000+ X2 Black Edition jednostavno se ne isplati, a da ne spominjem masu jeftinih modela iz 4000+ X2 serije koji se daju naći po Tržnici i raznim oglasnicima. Mislim nemaš kaj izgubiti ako probaš malo naclockati taj 4000+ X2, pa vidiš kak se ponaša s filmovima. Bolje to nego doma ići kupiti novi 6000+ X2, a i ako su ti filmovi DXVA lako složiš da ih kartica (ako je sposobna) koju imaš vrti umjesto procesora.
Autor Ruky Pregled postova
Ovo kaj ti imaš u HTPCu je čist dosta za HD, tj. bilo koji dvojezgreni procesor je dovoljan za HD materijal, bez da slažeš akceleraciju prek grafičke. Ovisno o taktu procesora i zauzeće prilikom gledanja HD materijala bude nešto manje. Ako pogledaš malo po ovoj temi skužil budeš da ljudi s raznim dvojezgrenim procesorima bez ikakve hardverske akceleracije vrte sav HD bez problema. Ovo da imaš 40-50% zauzeće na E8400 i 8800GT je vredu, ali slična zauzeća imaju ljudi s procesorima na dosta nižem taktu, tak da ti u određenim slučajevima svi ti GHz ne znače ništ pretjerano. Pošto imaš 8800GT složi si akceleraciju, jer nema smisla da ti procesor ima tolko zauzeće, a kartica je sposobna preuzeti HD na sebe.
Zadnje izmijenjeno od: McG. 13.11.2008. u 16:54.
Staro 13.11.2008., 17:13   #385
Ruky
Ruky's Avatar
Postovi: 50
ma krivo sam valjda napisao 8800 gt mi je u drugom kompu. u htpc-u imam integriranu ati 3200!
citao sam nesto napreskokce po ovoj temi i kolko sam skuzio codeci nisu standarizirani tako da blu ray i hd-dvd radi bez problema jel se pali hardverska akceleracija i neki mkv filovi isto pale hardversku akceleraciju a ali ak nekaj nije dobro skodirano onda ide samo preko procesora.
ja sam prtljao sa ffdshow-om i sa codecom od powerdvd-a i jedina je razlika sta ffdshow zastajkuje a powerdvd codec preskace frejmove ali film ide fluidno.
znaci ak je nekaj lose skodirano mozes dubit na glavi ali nece upaliti hardversku akceleraciju.
jesam upravu ili moram ponovo bolje procitat?
Staro 13.11.2008., 17:25   #386
Postovi: 7,568
Dobro si napisal, ja sam ti samo rekel da pošto već imaš u drugom kompu 8800GT da složiš akceleraciju da se E8400 bezveze ne zamara i da nemaš 40-50% zauzeća. U HTPCu imaš 780G grafičku i na nju isto možeš složiti akceleraciju, a kaj se tiče same akceleracije ona se ne pali sama od sebe, ako ju ti prethodno (neovisno o softveru) nisi složil. Za full-HD filmove to ide prek PowerDVD-a, dok .mkv ide (pod pretpostavkom da je HD pripremljen DXVA) prek MPC HC playera ili KMplayera, prema uputstvima iz ovih (1, 2) postova. Imaš u obje konfiguracije kartice koje su sposobne preuzeti HD na sebe i nema razloga da si ne složiš tu akceleraciju i makneš zauzaće s procesora.
Staro 13.11.2008., 17:34   #387
A.J.
A.J.'s Avatar
Lokacija: Rijeka (Umag)
Postovi: 1,197
dali ja HD2600 Mobility sposobna preuzet tu akceleraciju?
A.J. je offline   Reply With Quote
Staro 13.11.2008., 17:50   #388
Postovi: 7,568
Da, sposobna je.
Staro 13.11.2008., 18:00   #389
A.J.
A.J.'s Avatar
Postovi: 1,197
hvala
i ja cu kod sljedeceg instaliranja windowsa instalirat prema onim uputama... sad imam preko jednih drugih uputa sa divx foruma...
Staro 15.11.2008., 16:40   #390
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
Pitat ću ovdje jer se dosta o njemu ovdje pričalo.
Nikako nemogu upogonit KMPlayer na visti, jel kome uspjelo ?
Instalacija prođe ok, međutim kad ga pokrenem samo monitor blicne i to je to.
stuc je offline   Reply With Quote
