Zaključane teme
Staro 03.11.2008., 00:51   #421
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Imas router? Ukljuci mu DHCP i trebalo bi raditi odmah...
da ruter je Siemens 515
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline
Staro 03.11.2008., 01:01   #422
tech
Postovi: 1,687
Jel imate problema sa skidanjem torrenta sa transmission klijentom?dakle u 1h skidajuci full brzinom, on je meni skinuo samo 200mb, uvjeren sam da je skidao na full jer je surfanje bilo nemoguce...el problem u tome sto skida na NTFS particiju pa nemre brzo pisati po njoj?
Tnx!
tech je offline
Staro 03.11.2008., 01:07   #423
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,128
Skinuo s Transmissionom vec sigurno oko 500 giga, skida i upravo sad i normalno surfam (doduse osjeti se da ide malo sporije, ali je jos uvijek i vise nego upotrebljivo). Moze biti da te zajebava NTFS, zapravo gotovo sam siguran. Koji NTFS "driver" koristis? Ako koristis Paragon vrlo vjerojatno ti se paketici korumpiraju, pa ih Transmission skida ponovno...
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
^SuperUnknown^ je offline
Staro 03.11.2008., 01:10   #424
Wolverine
Wolverine's Avatar
Postovi: 12,433
Autor tech Pregled postova
Tnx!
nemam ama baš nikakavih problema sa transmisionom
a to kojom brzinom skida možeš uredno provjerit kako samim transmissionom
to kaj ti teško sirfaš može biti i do toga da ti torrenti pojedu svu raspoloživu upload brzinu
u principu ako ne limitiraš upload, definitivno nećeš moć uredno surfat
Vezano za dio di veliš da nemre brzo pisat po NTFS-u... niš sporije ne piše po NTFS-u
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Wolverine je online
Staro 03.11.2008., 01:13   #425
^SuperUnknown^
Prečupavi mod
Postovi: 9,128
Imas praf Wolv, upload bi svakako trebalo limitirati, ali ne bas na neku bezobraznu vrijednost Evo kak ja imam (schedule je kad sam doma):
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 03.11.2008., 02:09   #426
tech
Postovi: 1,687
upload je bio limitiran na ~15kbps(sto znaci da je ostalo jos 50kbps za surfanje, imam max tv).Za NTFS koristim onaj NTFS 3g driver koji sam instalirao sa iatkos-om...
tech je offline
Staro 03.11.2008., 02:20   #427
^SuperUnknown^
Prečupavi mod
Postovi: 9,128
Onda mozes jos probat 2 stvari:
1) Transmission - Preferences - Network - Peer listening port - tu bi ti trebao biti upisan port kojeg bi trebao na routeru otvoriti i mapirati na svoj komp. Kad odaberes port i upises ga u rubriku, sastrane bi trebalo zasvijetliti zeleno, dakle ovako:
http://homepage.mac.com/mike.barca/transmission.png
2) Probaj skidati na Journaled particiju (sistemsku od OS X-a) pa vidi jel ista mijenja stvari
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 03.11.2008., 20:08   #428
Baja 001
Baja 001's Avatar
Postovi: 7,504
@tech
Meni normalno skida, koja verzija je taj tvoj 3G?
Baja 001 je offline
Staro 03.11.2008., 20:55   #429
tech
Postovi: 1,687
@SU port je otvoren-ista stvar, kada skidam na journaled particiju ide sasvim normalno...
@Baja di to provjerim?
tech je offline
Staro 04.11.2008., 13:41   #430
Lihto
Lihto's Avatar
Postovi: 3,945
Jučer se opet igrao na OS-Xu i nikako namjestit mrežu,na ruteru je DHCP uključen,e sad da ponovim ja se spajam na server di je XP SP i tamo je sherana konekcija za net i to na visti radi normalno,ali na OS-Xu nikako šta napravit da to proradi,što se drivera tiče čini mi se ok.I jel OS X ima neki taskmanager da vidim koliko rama troši trenutno i da vidim nešto kao system pa da vidim informacije o kompu...
iPhone XR 128gb
Lihto je offline
Staro 04.11.2008., 14:07   #431
^SuperUnknown^
Prečupavi mod
Postovi: 9,128
Stavi onda konekciju na manually, definiraj rucno IP, za router stavi IP od stroja koji ima XP i DNS servere upisi od svog providera. I trebalo bi raditi.
Za Task manager - Spotlight - Activity Monitor - Enter
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 04.11.2008., 14:16   #432
Lihto
Lihto's Avatar
Postovi: 3,945
thx,a jel nekako mogu vidjet sherane particije od Servera,nakon što ovo podesim i gdje trebam ići?
iPhone XR 128gb
Lihto je offline
Staro 04.11.2008., 14:48   #433
^SuperUnknown^
Prečupavi mod
Postovi: 9,128
Ako su kak spada share-ane, i ako mreza radi trebao bi vidjet stroj sastrane u Finderu:
Ako ne vidis, klikni na Finder, gore na menu bar, izbornik Go - Connect to server i upisi:
smb://IP_stroja
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 05.11.2008., 19:11   #434
Baja 001
Baja 001's Avatar
Postovi: 7,504
SVI koji pokušavaju dobiti PCI portove, to će teško ostvariti na OSXu. Razlog je jednostavan OSX već od davno ne koristi PCI, tako da će te morati potražiti alternative (USB, PCI-E...)
Baja 001 je offline
Staro 05.11.2008., 19:21   #435
M.Vlahovic
Postovi: 891
Ovako jučer probao instalirati iDeneb 10.5.5
pomoću SATA prže, izabrao sam drivere 3870, alc889 i ichx, i instlairalo se i kad oće uć u desktop samo se slika onak zblesira ko artefakti kad je pokvarena grafička. 2 put sam probao i ništa.
3870
sata hdd
e6750
p35-ds4
što mi je činiti
uzto sam slučajno formatirao cjeli disk (250gb igrica, 150gb hd filmova, 100gb muzike, 20gb slika..itd itd
svaka meni čast
da pokušam sa kalyway 10.5.2 ?
kako da formatiram ovu najveću particiju koja će mi biti za stvari razne u koji format?
znači 100gb za osx a sve ostalo za ostalo isto u HFS ?
koje drivere da instaliram pri instalaciji, koji driver za network da uzmem ( mrežna integrirana mi je RTL 8168/8111)
je li potrebno neke postavke u biosu mjenjat, i kakva priprema treba ako namjeravam xp u dual boot, ali prvo macos x na prazni hard
Treba li na na iAtkos dodavati te kextove ko i na kalyway???
ja to ne kužim kak se radi
Zadnje izmijenjeno od: M.Vlahovic. 05.11.2008. u 19:53.
M.Vlahovic je offline
Staro 05.11.2008., 20:11   #436
Armand
192.168.0.1
Armand's Avatar
Lokacija: BiH
Postovi: 463
najkompatibilnije kartice su ti u biti one koje postoje nativno za Mac-a, znaci 7300GT/2600XT/8800GT
Su izvini, evo citam ovaj thread ponovo ispocetka da vidim da mi sta bitno nije promako, pa me je ova stavka malo dovela u razmisljanje. Pored ovih karti, koji jos hardware je podrzan nativno od strane maca. Pitam to iz razloga jer postoji mogucnost da nekad u skorijoj buducnosti dodjem do neke love i da se bacim u shoping, tj da idem kupovat neku novu masinu . Cini mi se da je ovo mjesto gdje cu prije dobit odgovor nego li u "konfiguracijama" jer tam sam se zanjih dana nagledao svakakvih nebuloza.
Ajmo ovako.... wolv, su, baja i ostali, da sada raspolazete sa nekih 4000 kn i da trebate da sastavite konfiguraciju sa najvecim procentom mogucnosti da sve proradi out of the box(mreza, zvuk, grafika) , sta bi kupili?
P4 3.0 Prescott (Zalman 7000b-cu) @ Gigabyte 8ik1100
2x512 Apacer ddr400
AiW x800xt + vf900
Hitachi 80gb Sata2
Corsair HX520W
Linksys WRT54GL@Tomato 1.25.8515 RAF (Victek Mod)
Armand je offline
Staro 05.11.2008., 20:15   #437
^SuperUnknown^
Prečupavi mod
Postovi: 9,128
Pogledaj moj sig, tamo sve radi savrseno (naravno uz poneki kext odnosno package koji su dio popularnih instalacija vec duze vremena), najbitnije su ti ploca pa grafulja. Ciljaj na P35 i P45 chipset i neke od ovih grafulja koje sam nabrojao. Nazalost P5K-E WiFi (koja mi se pokazala najbolja) vise nema za kupiti, ali citam i cujem da Gigabyte-ice P35 rade isto tako odlicno, detaljnije imas tu:
http://wiki.osx86project.org/wiki/index.php/HCL_10.5.2
Nadalje, obavezno SATA przilicu, SATA disk i tako
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 05.11.2008., 20:24   #438
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Armand Pregled postova
LINK
Upravo tako, novi chipseti i grafe, uglavnom ono što je novije. Isto tako kako je SU rekao, što sličniji Mac HW, jer je on najbolje podržan!
Baja 001 je offline
Staro 06.11.2008., 01:34   #439
M.Vlahovic
Postovi: 891
iDeneb ne radi - instalira ali pri butanju samo bude deformirana slika zblokirana miš se da micati
Kalyway ne radi - pri pokretanju instalacije samo mi prikaže prekrženi krug
Što mi je činiti??
Probat žu još JaS i drugu verziju iAtkosa ako ništa onda odustajem
Zadnje izmijenjeno od: M.Vlahovic. 06.11.2008. u 01:52.
Staro 06.11.2008., 19:19   #440
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor M.Vlahovic Pregled postova
Što mi je činiti??
Poslikaj sa fotićem te slike baš me zanima. I nikad ne odustaj od OSXa na kraju se uvijek isplati.
BTW to ti je šta imaš 2GB RAMa
Baja 001 je offline
Staro 06.11.2008., 21:23   #441
mamba69
mamba69's Avatar
Postovi: 10
Možeš vrtjeti Kalyway 10.5.2 bez problema i sve za grafičare, bez frke. Za pomoć se obrati slobodno,rado ću ti pomoći ako gdje zapne.
mamba69 je offline
Staro 06.11.2008., 21:43   #442
mamba69
mamba69's Avatar
Postovi: 10
Neznam koju konfiguraciju imaš, no Kalyway 10.5.2 dolaze i s integrated kextima, tako da jednostavno dižeš nakon instalacije. Javi se, mogu pomoći...meni je ovaj moj hackintosh alternativa i to dobra, mučio sam se oko mjesec dana, 20tak instalacija i sad mi sve radi kako treba...no instaliraj na vlastiti disk, ne particiju. Pozdrav!
mamba69 je offline
Staro 06.11.2008., 21:46   #443
tech
Postovi: 1,687
Tnx!
Ima tko prijedlog?port otvoren, i ostale stvari navedene malo viselje su eliminirane...
tech je offline
Staro 06.11.2008., 21:51   #444
mamba69
mamba69's Avatar
Postovi: 10
Vidi na http://forum.insanelymac.com/index.php?showforum=85 , i na http://wiki.osx86project.org/wiki/index.php/Main_Page , na potonjoj imaš listu podržanog hardwera po izdanjima softwarea, no P35 chipset je odlično podržan, osobito Gigabyteove ploče. Ako imaš problema ili ti je potreban još koji savjet, slobodno se obrati! Sretno!
mamba69 je offline
Staro 06.11.2008., 22:09   #445
tech
Postovi: 1,687
Na koji način mi tvoj post pomaže?Za insanely znam, pa te molim da tri puta pročitaš moj post i gore pročitaš moje postove pa onda piši nešto...Mislim da mi ne gine formatiranje cijelog hdd-a u hfs..
tech je offline
Staro 07.11.2008., 10:34   #446
Baja 001
Baja 001's Avatar
Postovi: 7,504
@TECH nema ti druge
Što se tiče zadnje verzije NTFS3Ga možeš je provjerit na:
Code:
 Type 'ntfs-3g --help' or '/usr/local/bin/ntfs-3g --help' on the command line.
Baja 001 je offline
Staro 07.11.2008., 18:16   #447
V3rt!g(o)
V3rt!g(o)'s Avatar
Lokacija: Marija Bistrica
Postovi: 70
crap, probal instalirati i ideneb 10.5.5 na a6tc. Stane na spalshscreenu, moram resetirat.
Dal je to jednostavno do lapa?
asus a6tc:
turion x2 1.6ghz
7300 go
c51mw čipset
::Think for Yourself; Question Authority:: T. Leary
V3rt!g(o) je offline
Staro 07.11.2008., 18:51   #448
mamba69
mamba69's Avatar
Postovi: 10
V3rt!g(o), pokušaj sa Kalywayem 10.5.2, on podržava tvoju konfiguraciju, ili kod dizanja Darvina stisni bilokoju tipku i -v-s. Detaljne upute pogledaj na stranama X86 zajednice. Tech, sorry, post mi se je obrisao, želim ti reći da ono što skidaš mora biti na particiji koja je formatirana kao journaled extended. Postoje li problemi i dalje ,pokušaj postaviti pitanje na forumu X86 zajednice, siguran sam da će ti tamo znati pomoći. Meni sve radi bez frke, no mislim da je i do konfig. routera ( a i navodno je sa siemensovim routerima poseban problem)...Kako god, javi da znam kako se razvija situacija...Pozdrav!
mamba69 je offline
Staro 07.11.2008., 19:05   #449
mamba69
mamba69's Avatar
Postovi: 10
Ako imaš (V3rt!g(o)) problema pri rebootu sa videom (bijeli, crni ili plavi ekran ili artefakti), stisni F8 kod dizanja Darwina i upiši: -s (single user mod) i nakon toga u rootu upiši mount -uw/ i enter i /movevideodrivers, nakon toga će te pitati koje želiš maknuti (nvidia, ati ili intel gma, upiši yes za potvrdu (ostavi one koji trebaju tvojoj konfig. (enter bez yes). Postoji li problem i dalje, (nakon ovog,a siguran si da si ostavio prave videodrivere), kod Darvina opet F8 i pokušaj sa drugim kernelom (vanilla je najpodržaniji, no to ne znači ništa); i to tako da upišeš ime kernela:sleepkernel (intel/amd/sse2/sse3)
speedstepkernel (intel/amd/sse2/sse3)
nforcekernel (intel/sse3)
modbinkernel (intel/amd/sse3)
vanillakernel (intel/sse3)
kabylkernel (intel/sse3) with sleep support
Javi kako je prošlo!
mamba69 je offline
Staro 07.11.2008., 20:05   #450
Baja 001
Baja 001's Avatar
Postovi: 7,504
Evo pratim ovaj thread i nisam vidio da je netko spomenio ovaj uređaj. Oni koji prate Mac svijet sigurno su već čuli za njega/probali ga. Što se mene tiče, ima potencijala, sa budućim HCL će biti još bolji, cijena od 125€ i nije toliko loša s obzirom šta nudi.
Baja 001 je offline
Zaključane teme
