Datum registracije: Aug 2008
Postovi: 321
Printer maintenance HP LJ4200
bogdaj! jucher smo napravili printer maintenance na dotichnom pisachu i sada nas zanima slijedece... kako resetirati printer (ili namjestiti) da mi pokazuje na onoj info stranici status printer maintenancea? i dalje je na 0%.... poruku sam resetirao na displayu, pa da ne prchkam dalje, jel mi mozhe netko pomoci? ili smo neshto sj**** i on to automatski mora pokazati? fala puno! |
Postovi: 23,547
Mislim stvarno je bilo teško naslov topica uvalit u i u 5. linku naći:HP-LJ4200/4300 Reset indication service after replacing Maintenance Kit After a maintenance kit is installed, the maintenance-kit counter must be reset. Use the following procedure to reset the maintenance-kit counter. 1. Turn the printer power off. 2. Hold down the SELECT ( ) button, and then turn on the printer power. Continue holding down the SELECT ( ) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. 3. Press the UP ARROW ( ) button to scroll to NEW MAINTENANCE KIT. 4. Press the SELECT ( ) button to reset the maintenance-kit counter. Note. Perform this procedure only after a maintenance kit has been installed. Do not use this procedure to clear the PERFORM PRINTER MAINTENANCE message temporarily. Do not use this procedure to clear the PERFORM PRINTER MAINTENANCE message temporarily. |
Postovi: 321
tipkal sam vec u Google, ali to nisam pronashel... svejedno ti hvala ![]() |
