21.10.2008., 20:03 | #1 |
LateralusX
Postovi: 1,788
Nvidia izdaje 180.42 beta drivere - "Big Bang II"
NVIDIA Releases 180.42 Beta Drivers DOWNLOAD Code:
Beta driver for GeForce 200-series, 9-series, and 8800-series desktop GPUs. Recommended for the best experience on Far Cry 2: “Since we first began working on Far Cry 2 in early 2005, we have used GeForce GPU’s to develop the game and worked closely with NVIDIA’s excellent engineers. While Far Cry 2 represents an outstanding PC gaming experience for a wide range of systems, GeForce users can expect to enjoy the game quite literally ‘The Way It Was Meant To Be Played’.” - Louis-Pierre Pharand, Ubisoft, Far Cry 2 Producer Enables NVIDIA SLI technology on SLI-certified Intel X58-based motherboards with the following GPUs: GeForce GTX 280, GeForce GTX 260, GeForce 9800 GX2, GeForce 9800 GTX+, and GeForce 9800 GTX. |
21.10.2008., 20:35 | #2 |
Lokacija: CROATIA
Postovi: 31
jesu tu oni drveri koje su nazvali big bang? |
21.10.2008., 20:40 | #3 |
BSD
Lokacija: Keebwork
Postovi: 7,495
Ja probao i nemogu ih nasnimiti instalacija stalno stoji na istom mjestu nema onog no responding i tih shema i kad prekinem instalaciju i reset kompa driver i kao instalirani :S
21.10.2008., 20:55 | #4 | |
Postovi: 12,413
Prožvakano već gro puta Prije instalacije ili uninstaliraj PhysX softver ili napravi extract drivera u folder i pokreni samo instalaciju drivera Ovako on nakon kaj instalira drivere želi instalirat i PhysX koji ti već imaš instaliran pa zato stoji
21.10.2008., 21:12 | #5 |
BSD
Lokacija: Keebwork
Postovi: 7,495
Ma znam kako se brise to... Obrissem uvjek prvo nvidia physX pa nvidia drivere pa cleaner pa restart i onda nove ali jednostavno nece. Ove177.89 isprve uvijek.A te nove 180 drivere nemos extractat posto odmah krene zip pa insatalacija ,a ne pita gdje ces extract tako da..
21.10.2008., 21:34 | #7 |
BSD
Lokacija: Keebwork
Postovi: 7,495
Moja isprika Wolv.Uspio sam extract.Hvala.Samo jos jedno pitanje,: negdje sam citao da su ovo driveri napravljeni kao ne samo zbog Far Cry 2 ali tak nes pa me zanima koliko je to istina i ako je dali to znaci da ce bit jako velika razlika izmedju 17x i 180 drivera u Cry-u 2 ?
21.10.2008., 21:55 | #9 |
BSD
Lokacija: Keebwork
Postovi: 7,495
Pazi ovo.Napravim sve kako treba fino instalacija krene STANE opet na istom mjestu stoji 11 minuta i izbaci kao nije napravljeno nista pokrenite instalaciju kad retsartate komp.Opicim restart driveri normalno snimljeni leti sve ali nema PhsyX-a.Nasnimim ga rucno 8.10 ver i sad kad u CP otvorite phsyX nema vise onih demo cuda i gluposti nego u nvidia CP-u otvori samo jednu postavku i to dali zelite enable ili disable i to je to( Physx nema vise svoj menu poseban).
22.10.2008., 19:41 | #10 |
DJ_Darude kicks ass...
Lokacija: Virovitica
Postovi: 213
da tak imam i ja... čudno je malo sve to...
..:: Vlak je uvijek brži ::.. |
22.10.2008., 21:01 | #11 |
Postovi: 12,413
Evo ja fino skinuo stare drivere, maknuo stari PhysX, očistio DCPro-om, reboot ponovo očistio Driver cleanerom i instalirao nove derivere bez ikakvog zastajkivanja
23.10.2008., 08:13 | #12 |
Lokacija: Livingrad
Postovi: 539
nemres vjerovat da smo dosli do toga da jedna igra zasluzuje svoje drajvere...nije da slicnog nije bilo i prije...ali bas gustam vidjet taj FC2....i kako ce se druziti sa Mr.Slijem
°Citius Altius Fortius° |
23.10.2008., 08:29 | #13 |
Lokacija: VG
Postovi: 1,758
23.10.2008., 11:41 | #14 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Isa ti...đesoblaci na Endiviji?
23.10.2008., 11:59 | #15 | |
LateralusX
Postovi: 1,788
23.10.2008., 17:47 | #18 |
its slightly turbocharged
Postovi: 5,426
Stavio svježe windowse danas i prvi put pokušam instalirati, dođe do pola, i stoji i odjednom kaže da nisu instalirani bla bla Ja restartam, kad ono imam nVidia Control Panel i tamo piše 180.42 Pokrenem ponovo instalaciju i normalno "succesfully" završi
blaa |
24.10.2008., 00:02 | #20 |
Postovi: 213
men je isto tak nešt rekao setup... pa sam opet pokrenio setup i sve cool
24.10.2008., 21:42 | #22 |
Lokacija: dalmacija
Postovi: 37
napravili su mali update! sad je v180.43 |
25.10.2008., 11:42 | #26 |
Postovi: 12,413
vidim već je teško postalo i c/p u google nayiv bete http://www.google.hr/search?hl=hr&q=...aživanje&meta=
25.10.2008., 14:25 | #27 |
Postovi: 213
25.10.2008., 22:53 | #30 |
Postovi: 348
Stavim ove najnovije 180.43 i kod inst. sve prođe ok, ali u win xp reza 800x600 i ne mogu je mijenjati kao ni boje koje su na 4bit. Kak to riješiti |
