Staro 25.10.2008., 09:16   #1
KidBoy128
KidBoy128's Avatar
Datum registracije: Apr 2008
Postovi: 291
uTorrent i vrlo spor net?
kada nešt skidam preko uTorrenta, net mi je užasno spor
neznam zašto
podesio sam na njemu i upload limit i download limit i net je još uvijek spor
sporiji od carneta, za jednu stranicu mu treba oko 5 minuta
a brzina kojom skida uTorrent je vrlo mala D: 5-10Kb/s, U: oko50Kb/s
http://www.speedtest.net/result/344576885.png
KidBoy128 je offline   Reply With Quote
Staro 25.10.2008., 09:30   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
A nisi naveo koju mrežu uopće imaš.
Adsl 2mbit, 8mbit, isdn...
Ali inače usporava net utorrent iako je upload i download mali.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je online   Reply With Quote
Staro 25.10.2008., 13:12   #3
msvrtan
Datum registracije: Oct 2001
Postovi: 2,735
upload ti ubija vezu. naime neusjevas ili kasnis sa slanjem potvrda da si primio djelove web stranica i zato mu treba tako dugo
msvrtan je offline   Reply With Quote
Staro 25.10.2008., 13:54   #4
Igneos79
Datum registracije: Mar 2008
Postovi: 328
Autor msvrtan Pregled postova
tocno, smanji upload na 10 kila dok surfas ili skidas nesto, a download ostavi na max
Igneos79 je offline   Reply With Quote
Staro 25.10.2008., 14:32   #5
ivan_karlovac
ivan_karlovac's Avatar
Datum registracije: Aug 2008
Lokacija: karlovac
Postovi: 111
Ja sam imao istovjetan problem sa utorrentom i nikakvim surfanjem i nakon puno googlanja sam shvatio da problem nije sa utorrentom niti sa prevelikim uploadom niti sa klanjem antivirusa i utorrenta nego sa time da su xp napravljeni tako tcp konekcije su limitirane na 10 i zbog toga kada skidaš sa utorrentom sve konekcije se zauzmu i ne možeš više surfati netom. Zato ako imaš xp sa SP2 instaliraj si patch sa http://www.lvllord.de/ i stavi broj tcp konekcija na 50 ili više meni je na 100 i sve radi ok imam brzinu 8 Mb/s i utorrent mi je nariktan da skida sa 5 Mb/s a uploud je na 40 Kb/s i uz te postavke ja i još 3 kompa u mojoj mreži normalno surfamo. Jedini je problem kada instaliraš taj patch moraš prvo deinstalirati antivirusni program jer meni naprimjer AVG8 odmah patch prepoznaje kao trojanac iako nije. Ako imaš SP3 onda koristi ovaj patch http://hwrms.com/blog/?p=17 i stavi na 100 tako preporučuju, ja ga nisam isprobao jer kada sam ja imao xp sa sp3 nisam mogao nači patch za sp3 pa za njega ne mogu garantirati.
ivan_karlovac je offline   Reply With Quote
Staro 25.10.2008., 15:01   #6
KidBoy128
KidBoy128's Avatar
Postovi: 291
ima li tko rješenja i za vistu?
taj patch je proradio na xp-u
ali na visti neće
PS imam t-comov adsl i 8mbits vezu, ali sad vidim da ti i nije tako bitno
Staro 25.10.2008., 15:32   #7
msvrtan
Postovi: 2,735
Autor KidBoy128 Pregled postova
ali na visti neće
@ivan_karlovac: vidis ja na xp-ima nisam imao nikada taj problem ali jesam cuo za njega
na visti je meni utorrent mjesecima skidao bez problema.. mislim da je onaj problem bio specifican samo za XP-e
Staro 25.10.2008., 15:58   #8
ivan_karlovac
Lokacija: karlovac
Postovi: 111
Nisam na visti ali ja ipak mislim da je i vista također ograničena na 10 tcp konekcija ako ti javlja u Windows Vista Event Vieweru: Event ID 4226 error onda imaš isti problem kao ja sa XP evo odi na ovaj link pa prouči http://www.mydigitallife.info/2007/0...windows-vista/ mislim da je i vista u tome problematična.
Staro 25.10.2008., 17:51   #9
sipe
sipe's Avatar
Postovi: 993
Nema veze s brojem konekcija nego s uplodom, ograniči ga na 10/20 pa onda probaj
sipe je offline   Reply With Quote
Staro 25.10.2008., 23:04   #10
KidBoy128
KidBoy128's Avatar
Postovi: 291
kada je utorrent uključen onda je net u govnima, kad ga isključim onda je sve ok
Staro 25.10.2008., 23:14   #11
Joke
N00B
Joke's Avatar
Postovi: 3,886
Koji je router u pitanju?Otvorio si portove?Koja verzija utorrenta?
IE6
Linux is Not Windows
Staro 25.10.2008., 23:42   #12
sipe
sipe's Avatar
Postovi: 993
Ja npr. ima 256 upload i utorrent stavim da šalje 10kb/s i nemam problema. Portovi su naravno otvoreni
Staro 26.10.2008., 05:12   #13
phelan
Postovi: 77
Autor ivan_karlovac Pregled postova
I ja imam isti problem s utorrentom, i kada sam pokusao skinuti s tog linka, ne ide - "the source file could not be read". Imas ideju kako da ipak uspijem instalirati taj patch? Thanx!
phelan je offline   Reply With Quote
Staro 26.10.2008., 12:34   #14
KidBoy128
KidBoy128's Avatar
Postovi: 291
imam zyxel p600
i 1.8 utorrent
Koje portove? kak se to otvara
Staro 26.10.2008., 13:17   #15
sipe
sipe's Avatar
Postovi: 993
imam zyxel p600
i 1.8 utorrent
www.portfoward.com
Staro 26.10.2008., 20:32   #16
Joke
N00B
Joke's Avatar
Postovi: 3,886
imam zyxel p600
i 1.8 utorrent
Odaberi port npr. 55000 i nadi tu za zyxela na ovoj stranici za otvorit portove http://portforward.com/english/route...outerindex.htm
IE6
