#1 | |
Buying Bitcoin
Postovi: 8,207
Vista SP1, ne želi instalirati jedan update
Ne želi mi instalirati jedan update, i izbaci error "WindowsUpdate_80004005" Radi se o ovome: Citiraj:
Any idea? ![]() |
Datum registracije: Mar 2008
Postovi: 120
Evo sta pise na MS stranici za taj update: The original release of Update 938371 updates several internal components that Windows Vista requires in order to install or to remove Windows Vista Service Pack 1 more reliably. This update must be applied separately before you install Windows Vista SP1 to make sure that Windows Vista SP1 can be installed or removed from the computer. Update 938371 is necessary to install and to remove Windows Vista SP1 on all versions of Windows Vista.
#3 | |
Buying Bitcoin
Postovi: 8,207
Postovi: 120
Pa ak ti radi vista bez problema nemoj nista dirat ![]()
