Staro 19.08.2008., 19:57   #1
Punio4
Punio4's Avatar
Lokacija: Zagreb, Maksimir
Postovi: 437
Izašao Pidgin 2.5!
Dakle, napokon je došao i taj dan, kad mogu baciti Live Messenger u smeće.
Naime, 2.5 donosi podršku za msn7 protokol, dakle p2p file transfer, statusi, custom smileyi, te najbitnije, offline messaging.
http://pidgin.im/
http://downloads.sourceforge.net/pid...dgin-2.5.0.exe
Version 2.5.0 (08/18/2008)
* libpurple
o Ability to create custom smileys (currently only the MSN protocol utilizes the feature). (Thanks to Mauro Sérgio Ferreira Brasil, Marcus Lundblad, Jorge Villaseñor and other contributors)
o Add a configure option, --with-system-ssl-certs to allow packagers to specify a system-wide SSL CA certificates directory. When set, we don't install our SSL CA certs, so it's important that the libpurple package depend on the CA certificates.
o Add SSL Certificates support to the NSS SSL plugin. (Thanks to Lou Cipher)
* XMPP
o Fix a bug that caused the UI to not refresh and caused the client to use 99% CPU when an XMPP account lost its connection to the server.
o Possibly fix a bug where some clients could get into a state where they moved a buddy back and forth between two groups in an endless loop.
* IRC
o /ctcp command (Vladislav Guberinić)
o Allow for auto-detection of incoming UTF-8 formatted text on accounts which are configured to use some other encoding.
* MSN
o Update MSN support to protocol 15 (Elliott Sales de Andrade, Jorge Villaseñor, Mike Ruprecht, Carlos Silva, Ma Yuan, Daniel Ljungborg and others)
o Personal messages are now supported. They are treated as status messages.
o Offline IM is now supported.
o Aliasing is now supported server-side.
o Buddies are now emblemed. Bots and web clients should now be distinguished.
o Update smiley set for non-faces.
o Failing to update a buddy icon when the buddy has gone offline no longer crashes.
o Custom smileys received in a chat no longer go to a new window.
o Processing is no longer completely frozen after the servers block a message because it contains (what they consider) inappropriate text.
* Pidgin
o Custom buddy icons can now be added to and removed from buddy list entries via the buddy list entry right-click menu.
o Resize large incoming custom smileys to a maximum of 96px on either side.
o Offer to add new buddies into the same contact as existing buddies in the same group if the alias given is the same.
o Minor smiley style update.
* General
o Group and Chat buddy list entries can now be given custom buddy icons.
* Finch
o Added "Invite..." menu to chats.
o Added "View All Logs" menu in the buddylist to display a list of all IM logs.
o Added '/msgcolor' command to change colors of different classes of messages in a conversation. See '/help msgcolor' for details.
o Added tab-completion for commands in conversation windows.
* Windows-specific changes
o Don't install the GSSAPI SASL plugin on NT4 to avoid an error popup.
o Use the Kerberos for Windows libraries installed on the system (if present) instead of including enough to load the plugin (Kfw still needed to be installed for it to actually work before this change).
o Upgrade to Perl 5.10 (System Perl runtime must be upgraded for Perl plugins to continue to work).
o Upgrade SILC to use the 1.1.7 toolkit
Uživaj narode!
Zadnje izmijenjeno od: Punio4. 19.08.2008. u 21:03.
Punio4 je offline   Reply With Quote
Staro 19.08.2008., 23:50   #2
tpm4
tpm4's Avatar
Postovi: 330
super.
vec koristim nekih 4-5 mjeseci 2.4.2.
nova verzija je dosta poboljsanja, svida mi se.
tpm4 je offline   Reply With Quote
Staro 20.08.2008., 15:58   #3
Dule
Dule's Avatar
Postovi: 698
ja ne mogu naci kako promijeniti (ili vidjeti) svoj personal message u 2.5.
Dule je online   Reply With Quote
Staro 20.08.2008., 16:20   #4
tOta
Lokacija: ...
Postovi: 685
Autor Dule Pregled postova
Kad mijenjaš status dobiješ ovo:
Jedino što nedostaje primjena personal message za sve statuse, da se ne mijenja kada odem away i sl.
tOta je offline   Reply With Quote
Staro 23.08.2008., 16:50   #5
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,435
Koliko je ova nova verzija stabilna?
Meni se 2.4. vjecito rusio.
Staro 23.08.2008., 22:58   #6
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Autor BlackDwarf Pregled postova
Za sada radi vrlo dobro...
Ja sam MSN bacio u smeće ćim sam došao do pidgina, tj. onda je bio gaim
Staro 26.08.2008., 21:19   #7
Dule
Dule's Avatar
Postovi: 698
ima bugova (ovo govorim za win verziju, linux jos nisam probao). custom smajlije prikazuje ali nece da ih zapamti (savea).
offline poruke rade ali nece da ih dostavi osobi koja je appear offline i ima live msn.
steta, pidgin je mogao u potpunosti zamjeniti live messenger, ovako ostaje cekati da se ti bugovi poprave.
Staro 26.08.2008., 23:15   #8
kalixius
...carpe diem...
kalixius's Avatar
Lokacija: Zagreb - okolica
Postovi: 1,363
Svaka čast tome Pidginu,no stalna zamjena MSN Live-u nikada postati neće.
kalixius je offline   Reply With Quote
Staro 27.08.2008., 15:09   #9
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
znači, radi u Messengeru, offline mesaging? zakon, to me je uvijek odvraćalo od takvih zamjenskih all in one programa.. uvijek im je nešto falilo...
da li radi messenger Video call?
probat ću ovo definitivno..
da li ima tako nešto i da podržava Skype u sebi?
Staro 03.09.2008., 06:28   #10
siLk
Postovi: 9
Zasto bacat MSN u smece? Zato sto je od MS-a? Uopce nije los prog, vise je cool drzat program koji se rus svako malo. Jao ljudi...
yeaaaaaaaa...
siLk je offline   Reply With Quote
Staro 03.09.2008., 13:11   #11
Punio4
Punio4's Avatar
Postovi: 437
Primarni razlog zašto bacam MSN u smeće jer ima kronično loše riješeno sučelje.
Dakle, užasno puno prostora zauzima za količinu prikazanog teksta, i sa onim očajnim kvazi-vista sučeljem strši van ko žulj među ostalim aplikacijama.
A i to "u smeće" znači da se ne pokreće pri startupu, i da nije defaultni MSN klijent
I dalje ga držim instaliranog, za file transfere.
Staro 04.09.2008., 00:25   #12
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
ne ne, imam ja msn instaliran, i imat ću ga, ali trebam imat još jedan username logiran, a za to ću koristit pidgin.. znači da mogu dvije osobe biti istovremeno logirane na istom kompu... (ja i draga)
Staro 04.09.2008., 13:29   #13
A.J.
A.J.'s Avatar
Lokacija: Rijeka (Umag)
Postovi: 1,197
pa stavi si msn plus i ukljuci opciju da mozes imat vise msna upaljeno i to je to
samo ovdje stavis kvacicu u postavkama msn plus
A.J. je offline   Reply With Quote
Staro 04.09.2008., 13:50   #14
Roberto
Roberto's Avatar
Postovi: 2,651
Pidgin je prije svega all in1 tool, a tek onda zamjena za neki messenger. Ja primjerice koristim i yahoo messenger i google talk i skype, povremeno i ICQ. Pidgin ima integriranih 15-ak IM protokola.
To mi je izvrsna stvar jer mi 2-3 programa koje koristim zajedno pokrenuti požderu preko 100 mb memorije, a pidgin ih ima sve u jednom sa nekih 20 - 30 mb u memoriji.
Još da integriraju podršku za skype (mada je dostupna preko plugina)
Roberto je online   Reply With Quote
Staro 04.09.2008., 14:23   #15
A.J.
A.J.'s Avatar
Postovi: 1,197
znam da ima puno tih programa koji mogu imat vise tih IM accounta istovremeno, ali me zanima dali ima neki koji ima file transfer i ako moze podrsku za one animacije. jer mi ide na kurac taj msn kad se salje neki veci file, uvijek prekine nakon nekog vremena. il kad nekom nesto saljes a ovaj s druge strane ne vidi da je ponudeno
