Staro 11.07.2006., 19:34   #1
6Ur4Z
Datum registracije: Jul 2004
Postovi: 4
Pioneer DV-393 player subtitle problem
Na Pioneer DV-393 playeru pokusavam gledati filmove s udaljenosti vece od pola metra, ali mi to zbog strahovito malog fonta prikazivanja titlova na ekranu ne uspjeva. Pokusao sam prebacivati prijevode na disku u razne formate (*.srt, .sub, .ssa, ...) ali nema uspjeha. Na netu nema nikakvih firmwareova za skinuti. Nasao sam neki za DV-470 ali se tip ne kune da ce to raditi i na 393. Jeste li imali kakvih iskustava s tim ili da cekam firmware? Dajte koju pametnu - nagradjujem toplom rjecju i prijateljskim stiskom ruke.
6Ur4Z je offline   Reply With Quote
Staro 11.07.2006., 19:41   #2
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
http://www.pioneerfaq.info/english/d...tion=Firmwares
Nažalost moraš se strpiti, ili probaj na svom playeru ovaj firmware.
Možeš probat i sam pomoću serial kabla izvući firmware iz playera (link na stranici gore je dead player-postupak je isti ako želiš izvići firmware) i pomoću mtkremakera i fontcreatora napraviti firmware sa vlastitim (većim) fontom.
Link za mtktoolse:
http://board.softpedia.com/index.php?showtopic=2786
Evo i kratka uputstva za moddanje fonta:
Autor Dinderi
If you want more options for subtitles' size, you can do as follows:
1. Download MTKFontCreator
2. Create your favorit fonts using your favorit CodePage (for example Windows or Special Code Page 1252, Arial Narrow, Outline 1, Width div. by 4, Size 20, 22, 24, 26)
3. Save files with newly created fonts.Now you have 4 files with 4 sizes of fonts
4. Download MTKRemaker.
5. Open Firmware 1.09.03 by Gufiak and Subz3ro (or any other wink.gif ) with MTKRemaker 0.22
6. Go to MT13x9 -> Data Part -> OSD -> OSD1 Visuals -> Fonts
7. Rightclick "Font 8", choose "Replace" and replace with your previously created fonts with lowest high (f.e. Arial Narrow 20) .
8. Do the same with "Font 9", "Font 10", "Font 11" replacing with bigger and bigger fonts.
9. When replacing is done, save firmware, burn CD, upgrade your player.
Best regards
Dinderi
Warsaw - Poland
Zadnje izmijenjeno od: Pomo. 11.07.2006. u 19:52.
Staro 11.08.2008., 07:21   #3
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Malo dizanje teme iz mrtvih, jel ima tko doticni player i koji FW vam se cini the best? Ja sam probao neki sa Softpedie, ali nema 1250 titlove, tj. pokazuje mi one hijeroglife umjesto č,ć i đ. Takodjer ne kuzim kako promijeniti da NTSC filmovi budu u boji jer mi se initial settings menu nije promijenio od originalnog FW-a, a na mom DV-470 je poprilicno vec upgradean nakon par flasheva moddanim FW-ima sto GrgArta, sto Gufiaka(imam i one subtitle opcije itd, sto na ovom playeru ne vidim).
Staro 19.08.2008., 12:48   #4
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Posto nitko nije pomogao, evo da ja pomognem drugima koji imaju dotican player. Ovaj FW radi kao zvijer i najbolji je od svih, a flashao sam ih sigurno 5-6 komada u 2 dana.
Postupak flashanja je kao i obicno. ISO burning, nasloviti CD sa VELIKIM slovima "PIONEER" i snimati na najmanjoj mogucoj brzini. Flashanje je as usual, gurnes CD u player i kad ti na ekranu napise da stisnes "play" stisnes i cekas, kad izvuce tray van uzmes CD i nis ne diras. Kad se tray zatvori flashanje je gotovo i pojavi se "Pioneer" logo as usual.
Evo i link za download najbolje verzije koju sam skuzio.
http://rapidshare.de/files/38407225/YDB6C18A.rar
Staro 01.09.2008., 13:17   #5
Pioneer DV-310 Divx player
Da ne otvaram novi topic.
Nabavio sam gore navedeni DV-310, najvise mi se svidja USB sucelje da mogu pristekati 80GB hard pun materijala
nego, ima li tko link ili firmware kakav za navedeni player.
ovaj 393 imam otprije, ali sam ga proslijedio staricma, i to sto Dizel kaze, stroj je zivotinja nije ni ovaj los, ali imam problem sa našim slovima.
Đ prikazuje nekako, ali Š,Ž,Ć ne prikaže nikako, dok mu je Č onaj "ae".
pa ako neko ima kakav info, bilo bi zahvalan.
Staro 11.09.2008., 18:33   #6
Bran
nemam kaj napisati
Bran's Avatar
Datum registracije: May 2003
Lokacija: Međimurje
Postovi: 1,303
Probaj onaj Sebastianov firmware za Pioneer. Mnogi govore da je najbolji za Pioneere.
Staro 13.09.2008., 21:26   #7
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Da, vjerovatno nije dobro konvertiran za 1250, trazi drugu verziju i flashaj, nece mu nista biti, bez brige
Meni je upao u oko ovaj Pioneer DV410V, cini mi se da mi je taj iduci kad svoj oldskul Pioneer DV470 prodam.
Staro 19.09.2008., 17:44   #8
...Tihomir...
...Tihomir...'s Avatar
Postovi: 344
Autor Dizel Pregled postova
Nisam pomogao jer nisam vidio ;-) Neznam koja je ovo tvoja verzija ali ja sam se puno igrao s tim, čak sam i sam prepravljao firmware za 393. Odi na moju stranicu: http://firmwares.prohosts.org/index.htm i po meni to je najbolji bios od puno isprobanih. Veliki titlovi, mogućnost izbora titla čak i ako se nezove isto kao i film, dodana moja grafika... Na stranici ima dosta firmwarea za navedeni model uz opise i slike. Jednu verziju sam preveo i na hrvatski, nažalost ne i najbolju jer sam izgubio interes...
Pozdrav!
...Tihomir... je offline   Reply With Quote
Staro 19.09.2008., 18:36   #9
Ubleha
Ubleha's Avatar
Lokacija: BiH
Postovi: 1,485
Da se nepatite sa modanjem evo link sa firmwareovima za vecinu Pioneer dvd-ova i recordera, provjereno rade, imaju hr slova i dosta veci font i jos dosta opcija.
http://www.pioneerfaq.info/index.php?question=Firmwares
Tek sam sada vidio da je vec u prvom postu vec bila ova adresa ali nije naodmet jos jednom.
Nisam pijan sve dok mogu da ležim na podu i da se nizašta nedržim.
Ubleha je offline   Reply With Quote
Staro 31.01.2011., 02:13   #10
isoimagefw
Datum registracije: Jan 2011
Lokacija: uhgfohffh
Postovi: 2
Snimio sam i kad sam ubacio DVD u player javilo mi je can't play dics. U čemu bi mogao biti problem? File koji sam spržio je .bin file, kojeg je komp na kojem sam pržio prikazao kao .avi file tj. s ikonicom onog nekog tuljka.
Kako da to konvertiram da bude normalno i čitljivo na mom playeru? Skinuo sam i neki iso image reader, mislim da se zove magic iso, ali ništa s njim nisam uspio napraviti...da uninstaliram program s kojim gledam .avi formate pa da onda pokušam?
isoimagefw je offline   Reply With Quote
Staro 31.01.2011., 21:29   #11
acer
Whatever :)
acer's Avatar
Datum registracije: Nov 2002
Lokacija: Rijeka,Bulevard
Postovi: 1,753
Ne moras nista deinstalirati,koji program koristis za snimanje,ako imas nero sa njim sve mozes rijesiti.
http://www.pioneerfaq.info/english/burn_guide.php
Evo ovdje imas tutorial kako sprziti ISO fajla sa nerom.
GIGABYTE B450 AORUS PRO
Fractal Design Define XL R2
Chieftec A-80, CTG-750C, 750W
AMD Ryzen 5 3600
Be Quiet Dark Rock Pro 4
Asus Nvidia GTX 1060 OC Edition, 3GB
Avermedia Live Gamer HD Lite
GEIL Evo Spear AMD GASB416GB3200C16ADC, DDR4 3200MHz, kit 2x8GB
Kingston NVMe M.2, 1TB
LG BH16NS55 Bluray writer
LG GGW-H20L Bluray writer
27" Philips
Brother HL-2240
Das Keyboard 4 Professional, MX brown
Logitech mouse G402
Scanner HP Photosmart G3010
Cambridge Audio DacMagic 100
Scythe SDAR-2100 + Scythe Kro Craft Speaker SCBKS-1000
Windows 10 PRO x64
Staro 02.02.2011., 01:15   #12
isoimagefw
Lokacija: uhgfohffh
Postovi: 2
Autor acer Pregled postova
Imam Nero, napravim sve kako tamo piše ali player mi ne očitava. Ponovo sam spržio, ovaj put sam uploadao SoftonicDownloader_for_anytoiso-converter pa mi ga je Nero očitao kao iso file, a ne kao avi file, ali opet mi ne radi.
Tamo na slici je .bin file prikazan drukčije nego kao kod mene na kompu gdje je označen ikonicom koja označava avi, odnosno, nakon instaliranja SoftonicDownloader_for_anytoiso-convertera, ikonicom koja označava iso format.
Osim tog, neke opcije koje su prikazane na slici niti ne mogu izabrati, npr.:
  1. On the tab Burn you check Write, Finalize CD.
  2. Write speed 4x
  3. Write method: Disc-at-once
Namjestim na 4x i na Disc-at-once, ali opcije Write i Finalize CD ne mogu checkirati jer su mi zamrznute.
Zadnje izmijenjeno od: isoimagefw. 02.02.2011. u 01:20.
