Staro 16.07.2008., 13:40   #91
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,488
pokušajte otvoriti http://www.racunala.koncar.hr/
Ovako mi piše:
Reported Attack Site!
This web site at www.racunala.koncar.hr has been reported as an attack site and has been blocked based on your security preferences.
Attack sites try to install programs that steal private information, use your computer to attack others, or damage your system.
Some attack sites intentionally distribute harmful software, but many are compromised without the knowledge or permission of their owners.
i onda me vodi na ovu str. http://safebrowsing.clients.google.c...ala.koncar.hr/
Staro 16.07.2008., 17:33   #92
Jole911
Jole911's Avatar
Lokacija: Hrvatska-Požega
Postovi: 423
@AnArChY
Da li imas jos kakvih detalja + - kako Nela jel sljaka s cim ima najvise problema....
Pozdrav!
Staro 16.07.2008., 18:44   #93
AnArChY
AnArChY's Avatar
Lokacija: Space
Postovi: 48
Autor Jole911 Pregled postova
@AnArChY
Pozdrav!
eto, vec tjedan dana radim na Nelici....
do sada nisam primjetio nikavih problema...
XP radi besprjekorno
sto se ekrana tice, onako odokativno - bez problema se moze gledati pod kutem cca 160 stupnjeva
ekran je mat a ne "bright view" tako da je zbilja ok.
laptop je cvrst , tastatura ugodna pri tipkanju - sve 5
jedini problem je tastura koja nema sve "dodatne" simbole, ali nista sto se nemoze rijesit :-)
AnArChY je offline   Reply With Quote
Staro 16.07.2008., 19:29   #94
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
kak mislis nema dodatne simbole? ima hrv ili neglesku tipkovnicu?
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 16.07.2008., 20:11   #95
svemir
Postovi: 164
Dal si probao kako vrti HD filmove. Tocnije filmove ripane sa x.264 kodekom.
svemir je offline   Reply With Quote
Staro 16.07.2008., 21:14   #96
Ag008
Ag008's Avatar
Postovi: 7,488
Autor antrax Pregled postova
To su ti onui znakovi poput @ na tipki v ili { na b i ...
Staro 16.07.2008., 23:31   #97
AnArChY
AnArChY's Avatar
Lokacija: Space
Postovi: 48
Autor Ag008 Pregled postova
tocno, na tipki nije oznacen @ i ostali, a neki simboli "iznad" brojeva su na "krivom" mjestu - " je oznacen kod slova Ć, ( je kod broja 9 i sl.
Jedino neznam da li mozda za laptope postoji "posebna" hrvatska tipkovnica?
Nazalost nemam nikakve HD filmove pa ne mogu isprobati...
Zadnje izmijenjeno od: AnArChY. 16.07.2008. u 23:44.
Staro 17.07.2008., 12:49   #98
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
hehehe, uzeli su englesku tastaturu i samo prebrisali znakove nasim slovima (pogledaj malo bolje, nebi se cudio da ima samo male crne stickerice poljepljene). probaj prebacit (alt+shift), vidjet ces da se odgovara
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Staro 17.07.2008., 15:58   #99
Ag008
Ag008's Avatar
Postovi: 7,488
nemoj pretjerivati, naljepnice...
Staro 17.07.2008., 22:15   #100
AnArChY
AnArChY's Avatar
Lokacija: Space
Postovi: 48
da, to je to.... male crne naljepnice...
ima gdje to za kupiti?
Staro 17.07.2008., 22:36   #101
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
nemoj zezat, jos nisu smislili bolji nacin za to?? to sam zadnji put vidio na nekom p3 acer laptopu, hehe
no nemam pojma gdje bi to bilo za kupit sumnjam da uopce ima..
i krajnje glupo da made in croatia laptop za hrvatsko trziste dolazi s tim, uh..
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Staro 17.07.2008., 23:05   #102
tutix
tutix's Avatar
Postovi: 4,069
...sa made in China djelovima. Pa valjda si već dovoljno haxorz da znaš gdje su čćšđž .
tutix je online   Reply With Quote
Staro 18.07.2008., 11:54   #103
AnArChY
AnArChY's Avatar
Lokacija: Space
Postovi: 48
Autor tutix Pregled postova
ma nisu problem dijakriticki znakovi....
evo slicica pa pogledajte...
tamo gdje bi trebali biti oznaceni : i ; su >< i tako to.....
mislim, nije neki problem, znam gdje se nalaze svi simboli, ali ono, zelim da mi bude tocno oznaceno....
Zadnje izmijenjeno od: AnArChY. 19.10.2008. u 13:27.
Staro 18.07.2008., 13:49   #104
Ag008
Ag008's Avatar
Postovi: 7,488
ja ništa ne vidim!
nikakve naljepnice
Staro 18.07.2008., 17:34   #105
Jole911
Jole911's Avatar
Postovi: 423
Pa cekaj jel si ti dobro namjestio tipkovnicu na HR?Ili je krivo ostampano slovo? Auuu je guzva na tipkovnici ko u 16 tercu
I sad ti vidi razliku ovo je od IBM R51e ko nebo i zemlja.
Svaka cast Koncaru ali nije vrijedan 500 kn sto je IBM Lenovo skuplji...
I uzmi u obzir da je ovo staro 2 godine i nefali ni sta sva se slova vide kao nova.
Staro 18.07.2008., 19:16   #106
AnArChY
AnArChY's Avatar
Lokacija: Space
Postovi: 48
Pa pogledajte sliku, krivo su odstampana slova na tipkama...
@Jole911
Ti usporedjujes 15" sa 14" laptopom - pa normalno da je drugaciji raspored tipaka!
Kao sto je drugaciji izmedju 15.4" i 17" laptopa
A u Koncaru je Dualcore proc, a ne celeron kao u N200
Zadnje izmijenjeno od: AnArChY. 18.07.2008. u 19:36.
Staro 18.07.2008., 20:08   #107
Jole911
Jole911's Avatar
Postovi: 423
Sam si naveo da su ti tipke i slova čćšđž na krivom mjestu kako to znaci da su krivo ostampani.
Ma nije al nema veze .... Notebook Lenovo N200, TY2EACR
Pozz!
Zadnje izmijenjeno od: Jole911. 20.07.2008. u 05:27.
Staro 22.07.2008., 13:48   #108
Ag008
Ag008's Avatar
Postovi: 7,488
U novoj verziji nele:
procesor Intel Pentium Dual Core s taktom 1,86 GHz,ekran 14.1"WXGA(1280x800) color LCD,memorija 1 GB DDR II RAMA,120 Gb disk,DVD+RW,audio i video kartice na matičnoj ploči,mikrofon,wireless LAN,touch pad,tipkovnica podržava međunarodna i hrvatska slova,4 USB porta,VGA port,težak 2,4 kg s baterijom,
nova tipkovnica
novi sjajni ekran
Staro 22.07.2008., 15:13   #109
AnArChY
AnArChY's Avatar
Lokacija: Space
Postovi: 48
nova tipkovnica
novi sjajni ekran
to je bilo brzo.....
po meni je sjani ekran veliki minus......
Zasto se forsira sjajni ekran? Da li je bolji/kvalitetniji od mat ekrana?
Ali mi se svidja par dodatnih herza i tipkovnica.
Je tipkovnica ista ili je i drugaciji raspored slova?
Inace, krivo smo se razumjeli, na tipkama nisu naljepnice, nego ja pokusavan nac naljepnice sa tih par drugacijih simbola - izgleda da ima jedino na ebay-u....
Staro 22.07.2008., 15:17   #110
Postovi: 34,028
Anarhijo, ajde baci već jednom neki review Nelice. Neki benchmark, pokoji graf i sl. Ljudi to žele čitati.
Staro 22.07.2008., 17:13   #111
Ag008
Ag008's Avatar
Postovi: 7,488
Autor AnArChY Pregled postova
ne, poptpuno je nova, hrvatska tipkovnica, ima sve pravilno označeno
Staro 22.07.2008., 17:41   #112
Jole911
Jole911's Avatar
Postovi: 423
Jel netko zna objasnit koji nije sjajni ekran te koji je mat ? ja neznam u te znakove ..Meni isto neodgovara taj sjajni ekran jer cu koristit LapTop po vani znaci da mu nesmeta svjetlo-.
Kako da ja sad ovdje ocjenim kaka je to ekran ?
LAPTROP HP
Pozdrav!
Staro 22.07.2008., 18:03   #113
Ag008
Ag008's Avatar
Postovi: 7,488
ma sve je to isto samo što ovaj svjetliji ima jači kontrast, pa ga je lijepo koristiti i vani i unutra, ali ima i manu što ima odbljesak, sunca ili..
ali mana mat je što ostaju mrlje od prstiju,
ali najbolje da vidite sami:
lijevo sjajni desno mat
Staro 22.07.2008., 22:17   #114
Jole911
Jole911's Avatar
Postovi: 423
Kakva je ovo vrsta ekrana je se bas nerazumijem u to ""AntiGlare (1280 x 800 WXGA)
Hvala!
Staro 22.07.2008., 22:43   #115
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
Hvala!
to nije sjajni
==mat (bar mislim)
[ASUS ZenBook UX303UA - i7-6500U, 8GB RAM, Intel HD Graphics 520]
What man is a man that doesn't make the world better
daxxx88 je offline   Reply With Quote
Staro 22.07.2008., 22:53   #116
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
hp ekrane sa "staklom" oznacava sa sufiksom "bright view", kada toga nema onda je mat. ovo sto je ag008 napisao da je mana mat ekrana da ostaju otisci prstiju, to je istina, ali s druge strane to vrijedi za bas sve ekrane + ekran se ne dira kao ni stakla automobila
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Staro 23.07.2008., 00:11   #117
Jole911
Jole911's Avatar
Postovi: 423
Joj mene brine jos i ovakve stvari jer moram narucit nisam iz ZG pa zatko kod koga kupit evo sad sam zabrinut.Jer se mora unaprijed platit uuhhhh.......
POTROSACKI KOD
Pozdrav!
Staro 23.07.2008., 01:02   #118
AnArChY
AnArChY's Avatar
Lokacija: Space
Postovi: 48
POTROSACKI KOD
Pozdrav!
a cuj, zato se raspitas prije o firmi iz koje kupujes...
kao i na ebay-u.....
Ali eto, ja narucio, platio i sve doslo....
A nesto mi govori da Koncar nece tako brzo propast
Autor coconut Pregled postova
cuj, opcenito o njoj i opcem dojmu sam vec sve napisao, tako do....
Sto se benchmarka tice, eto rezultati PCMark 05
Ako zelite neke odredjene testove, recite s kojim programom.....
Zadnje izmijenjeno od: Jelc. 30.07.2008. u 15:13.
Staro 23.07.2008., 02:19   #119
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
OT: "...je odlucio kupiti jedan od najboljih kompjutora na trzistu... ...14000kn..." i na racuni pise iMac, hahaha, ovo me dobro nasmijalo
@jole... bilo koja od firmi ovdje spominjanih nije za neku crnu listu, neki imaju vise neki manje problema, odnosno bolji ili losiji odnos prema kupcu, ali generalno svi sve isporucuju uredno i bez nekih vecih kasnjenja.
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Staro 28.07.2008., 16:02   #120
Alex21
Postovi: 13
I ja sam vlasnik jedne slonice Nelice.
Dokupio sam 1GB rama, tako da sada laptop na Visti lijepo diše...
Djeluje čvrsto i robusno, ekran je jedan od boljih iz dosadašnje KONČAR-eve ponude, te ima dovoljno USB-ova.
Svakako bi se složio da je odabir SIS-a kao platforme nešto lošije rješenje od Intel-ovog, no to je vjerujem i razlog ovakve cjene.
U konačnom omjeru cijene/performase možda je to i dobar odabir...
HD filmovi 720p (x264) se uredno vrte (može se uključit i raznih filtera u ffdshow-u)...
QuickTime doduše ne... oni štekaju, te se najvjerojatnije radi u problematičnoj softwerskoj sprezi na relaciji, VGA diver->Vista -> QuickTime (šteka i na 640x480), no rijetko nalitem na .mov, pa eto.
E sad... tipkovnica...
Ovako odštampana tipkovnica je minus... radit na poslu s normalnom, pa preć na nelinu tipkovnicu, pa drugi dan opet na normalnu, ako ste programer, smetat će vas...
Kontaktirao sam ih po tom pitanju, te su mi rekli da će najesen najvjerojatnije biti moguće zamjeniti tipkovnicu s hrvatskom verzijom...
ASUS P5Q-E p45
Intel Core2Duo E8500
ATI Radeon 4870
2 x 2GB DDR2-1600
Seagate 500GB/32MB SATA
Audigy 2ZS
Terratec Cinergy 400TV
Chieftec 550W
Alex21 je offline   Reply With Quote
