Staro 27.06.2008., 13:31   #1
lordVerdranius
Postovi: 310
ATI RADEON HD 3870 - Links - Akcija - 799kn!
ZAGREB 26.06.2008. u 16:37 sati
SUBOTNJA AKCIJA - 28.06 .2008.
Sliku u thumbs
AKCIJA: VGA PCI-E GECUBE ATI RADEON HD 3870, 512MB DDR3, DVI, HDTV
Cijena za gotovinu/maestro/visa electron
799,00 kn
* Design based on ATI Radeon HD3870 series. (RV670XT)
* On-board with 512MB GDDR3 high speed memory.
* Unified Superscalar Shader Architecture built-in 320 stream processing units.
* Built-in HDMI support for HD video with multi-channel (5.1) AC3 support, enabling a plug-and-play cable-less audio solution.
* Hardware processing UVD (unviversal Video Decoder) delivers sharp images and vibrant color fidelity with 1080p playback of Blu-ray and HD DVDs.
* Dual DVI display port supports resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI, HDCP).
* ATI CrossFireX™ multi-GPU technology support (A complete ATI CrossFireX system includes ATI Radeon Graphics, an AMD 790FX or AMD 790X Chipset, ATI CrossFireX Certified memory and an ATI CrossFireX Certified power supply.)
* High-Speed 128 bit HDR (High Dynamic Range) rendering
* ATI Avivo HD technology includes fully integrated HD audio capabilities and supports playback of multi-channel (5.1) audio streams.
* Windows Vista with comprehensive DirectX® 10.1 support.
* Shader Model 4.1
Evo... Pa ako netko misli o novoj jefitnijoj grafi, mislim da je ovo OK izbor...
lordVerdranius je offline   Reply With Quote
Staro 27.06.2008., 13:33   #2
MP950
64VT klon
MP950's Avatar
Lokacija: ZGž
Postovi: 464
Zna li netko iz iskustva( ne nagađati) kakve su moguće razlike između krosfajra
DDR4+DDR3 i 2xDDR4 ?
Baš bi ljepo nasjela još jedna 3870 a aovo je jeftino a novo, samo me brine taj ddr3
MP950 je offline   Reply With Quote
Staro 27.06.2008., 13:42   #3
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
http://www.xtremesystems.org/forums/...d.php?t=180386
Prema ovom nebi trebalo biti nikakvih problema ipak imaju isti gpu.
Majo je offline   Reply With Quote
Staro 27.06.2008., 14:38   #4
MP950
64VT klon
MP950's Avatar
Lokacija: ZGž
Postovi: 464
Znam da neće biti problema, da će to radit, ali pitanje je kako će radit koja je razlika u performansama, nema veze, da neidemo u OT/SPAM, ako neko zna nek javi, samo ako zna iz iskustva, ne nagađanja
Staro 27.06.2008., 14:43   #5
Igorr
Flajing super šiiiip
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,704
Razlike u performansama nisu neke znacajne, ddr4 je po taktu brzi ali ima losije latencije tako da nije to nesto oko cega treba razbijati glavu
5.1.4 setup:
Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE
Amps - Marantz Cinema 40 + ROTEL RMB-1585
Igorr je offline   Reply With Quote
Staro 27.06.2008., 14:43   #6
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
Autor MP950 Pregled postova
pa zar nije oduvijek bilo bolje prodati staru i nadoplatiti pa kupit jednu novu?
u usporedbi sa kupovinom još jedne stare.
(a često je i jeftinije)
u ovom slučaju: 800+800 = 1600kn = 2x 3870
a jedna nova 4870 je oko?
(ako su novcate 4850 oko 1200kn)
SLI i Crossfire mi više miriše na to da iz dve nove grafe izvučeš maksimum maksimuma i budeš 'glavni',
a ne iz starijih, pošto obično 1 nova grafa troše manje struje od dvije stare, i daje bolje performanse..
možda brijem krivo, ali tako mi se čini da sam viđao tu na forumu rezultate....
a i netko je napisao na forumu kada spoji crossfire, ne može koristiti 2 monitora, kao što možeš normalno sa 1 karticom
pa je i to jedna prednost 'single card' setupa(uz one gore navedene)
potražit ću pa paste-am ako iskopam
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 27.06.2008., 15:27   #7
Pippincro
Pippincro's Avatar
Postovi: 616
Autor TomRi Pregled postova
Crossfire 2x hd3870 definitivno bolje gura igre na vecim rezolucijama od hd4850 - doduse driveri su tu ogranicavajuci faktor obicno.
Mogu mozda drugacije govoriti prvi "reportovi" s neta, ali pri takvim rezolucijama (1920x1200 i vishe) 2 kartice bolje guraju od jedne, a hd4850 nije neka revolucija naspram starije serije, vec super omjer ulozeno/dobiveno.
Tako da ako ide mjenjati postojecu 3870 za 4850 umjesto josh jedne da doda u crossfire (ako vec ima takvu plocu, nisam gledao), nedobiva skorom nista.
a razlika izmedju ddr3 i ddr4 u crossfire je samo u teoriji - naime u praksi u performansama razlike nema, a jedino je prisutna u tome da ddr4-tki mozes vishe overclockirat memu, na vishe taktove ali to se ne izrazi valjda ni u jednom fps-u.
I za kraj bih htio reci da bi se hd3870 rabljene trebale uskoro prodavat i po 600 kn, pa go for it.
Pippincro je offline   Reply With Quote
Staro 27.06.2008., 15:31   #8
MP950
64VT klon
MP950's Avatar
Lokacija: ZGž
Postovi: 464
E pa zato sam i mislio, jer za ovu grafiku dobim max 750kn, a 3870 ću uzet kad krenu po 600kn, fala.
A za monitor ni problem, jer jedini monitor u koji gledam je ovih 42"
