Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI accuses Nvidia of cheating
Dakle-kaj je na stvari, da li je patka ili Nvidia opet po dobrom starom običaju laganini vara We said that what we saw when we were in Geneva with Nvidia was a clear difference between the code that was running PS 3.0 path and a referred system that was running PS 2.0 code. ATI says that CryTek's representative told it that what Nvidia showed us in Geneva was a 2.0/3.0 path versus 1.1 path. The key message is that Shader model 3.0 and 2.0 look exactly the same, the ATI representative added. In a developers' mail that we also received, it added that there is a possibility that the 3.0 path might be slightly faster in same cases on some hardware - an obvious reference to Nvidia. ATI also claims that its hardware will run faster then Nvidia's anyway and he added: "It's pretty much impossible to make a sm3.0 game look noticeably different to a sm2.0 game, which is why Nvidia was comparing the 2.0/3.0 path with a 1.1 path." A CryTek representative responded on this matter with this answer: "Was Nvidia showing SM3.0 vs. SM2.0 or SM1.1?" He replied to his own question by saying that Nvidia was showing 3.0/2.0 vs. 1.1. |
Datum registracije: Feb 2004
Postovi: 218
hhahaahahhahaahha! ![]() |
nEkspert
Datum registracije: Oct 2002
Lokacija: Sibinj
Postovi: 137
Nemaju dostojan odgovor, pa se izvlače. ![]()
#4 | ||||||||||
Postovi: 3,263
stvarno su mugeri! : lol2 :
PC Ekspert
Datum registracije: Sep 2000
Lokacija: Zagreb, Hrvatska
Postovi: 1,214
totalno nebitno.... dok ne dodje directx 9.0c tak svejedno tko kaj pokazuje. ak je ATi u ovome vidio priliku za dobar PR, malo me brine kaj bu imali za pokazati - ljudi se primaju takvog smeca obicno kada su u k. sa onim bitnim.
Nissan GT-R Black Edition |
doktor, trekkie, amd-ovac
Postovi: 1,043
A što ćeš, ATI sere.Činjenica je da NVIDIA ima finalni silikon, praktički spreman za proizvodnju-dok ati nije pokazao ništa... ATIjeva kartica je zasad spekulacija.Nvidia ima stvarni produkt što će skoro u shopove.Endpoint->Ati gubi, ovaj puta...ovog trenutka.kao što je nvidia izgubila s FX-icama. |
#8 | |
Super Moderators
Postovi: 17,485
ps3 je tu najmanje bitan. Opet mu-lja-ju I ona spika sa optimizacijama na relaciji novih ploča i Nvidia grafičkih, jadno...optimizirali su tako da neke ATI-ce postižu slabije rezultate nego kad je upiknuta Nvidia grafa. Meni je cijela spika i ponašanje kojeg se Nvidia i dalje uredno drži malo onak... A prvenstveno se kupac osjeća majmunom kad čuje takva muljanja. A ništ...bumo vidli kak stvari stoje kad i ATI izbaci svoju grafu i kad se to sve skupa KONAČNO pojavi na tržištu, ovak razglabamo o stvarima koje ne možemo ni kupiti ![]() |
Postovi: 1,043
A ti namjeravaš kupiti?ja da, meni je bitno zato kako će to izići, jer već dulje vrijeme odgađam novu kantu, a imam pare...zbog ovoga i 939pin athlona.Ati ili nvidia?Tko je brži,to je meni bitno... a ova tužibaba igra od atija mi se ne sviđa, ako su toliko pametni, zašto već nemaju karticu na tržištu?nek se pokažu stvarnim rezultatom, a ne bacanjem pijeska u oči... |
#10 | |
Super Moderators
Postovi: 17,485
Mene isto zanima kak stvari stoje, ali Nvidie ne-ma-za-kupiti. Pa nebum kupil grafu koju su napravili u 20 primjeraka i podjelili na par siteova na review. Bila to Nvidia ili ATI. Ne pada mi na pamet kupit grafu koja nije bar mjesec dana na širem tržištu, koja je skupa do jaja kad izađe, za koju se ni ne zna kak se ponaša u realnom radu. Ni jednu svoju ATI-cu nisam kupil odmah nego tek kad sam vidio kak stvari stoje A daj mi samo reci da li Nvidia ima novu grafu na tržištu??? Nema Eto ti ga na I kaj buš onda kupil? Ali to ne mjenja na stvari da je Nvidia OPET muljala. Nije to nikakvo tužakanje-muljali su i uhvatili su ih...opet. Ono kaj mene čudi je to kaj se jedna velika kompanije koja kakti drži do ugleda i povjerenja kupaca bavi takvim stvarima. |
Postovi: 1,043
ne, ali je bliže nego atijevka... nemoj mi sada reći da nije bilo "crnog" s obje strane.Tu nitko nije odmah loš ili dobar, i ja sam imao i jednu i drugu, kako mi je pasalo tada...Činjanica je da nvidija ima konkurenciju,, i to vrlo jaku... |
Super Moderators
Postovi: 17,485
A gledaj-dok se ne pojave kod nas u dućanima ništ koristi. I dok se ne vidi cijena. Jebeš ti to ak budu razlike između grafi 5% a cijenaaaaaa Nedam 3-4 soma za grafu i bog. Ili nedajbože pet tisuća krznatih. |
Postovi: 1,043
A istinu kažeš ->iskustveno, ne bi rekao niti za ati, niti za nvidiu da će cijene biti "normalne" Znaš što?Kada sam kupovao ledtekovu gf3(običnu) još vrlo davno...kad je bila nova-platio sam ju oko 3700kn, kaj mi sad vrijedi?500kn?Ako i toliko... |
#15 | |
Postovi: 2,937
#16 | |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,030
#17 |
Datum registracije: Apr 2004
Postovi: 16
Sve mi se čini da sindrom muljaže sa starog nam ,dobrog i propalog 3DFX-a prelazi na NVIDIU!
A64 3200+, Zalman CNPS 7000A Gigabyte K8VNXP Limited Edition Club ATI Radeon 9800XT, 256 MB infineon 3200, 1*512 DDR 400 Mhz WD 80 GB, 7200 RPM Teac DVD-rom Case Antec Plusview1000 AMG, Chieftec 420 W Samsung 19" SM 959NF |
#18 |
Lokacija: Dimension 8
Postovi: 785
U biti to sto oni izdaju novotarije nece znaciti nista vec ce samo pasti cijene ovih sada koje su na vrhu a one za srednju klasu jos ce biti jeftinije i upravo je to bitno. |
