Staro 28.05.2008., 11:58   #1
matman
Lokacija: n/a
Postovi: 362
Kriptiranje jedne .txt datotekice
Dajte predložite neki alat koji je neovisan o platformi (win, unixoidi) + ako je moguće da nije nekaj instalacijsko nego samo izvršno (pa tu dolazimo do problema platformi valjda)
Ja sam naletel na ovo, i ako sam dobro skužil izvršava se prek browsera (nisam detaljno proučil i nisam još probal).
http://www.myersdaily.org/joseph/javascript/alphac.html
Ali ako je tak i da samo trebam par fajlova uz kriptiranom datoteku imat na stiku (netrebaju nikakve instalacije) to bi bilo idealno.
Zadnje izmijenjeno od: matman. 28.05.2008. u 13:03.
matman je offline   Reply With Quote
Staro 29.05.2008., 08:41   #2
mrga
all you need is freeware
mrga's Avatar
Lokacija: Stolica
Postovi: 897
Nisam siguran jel radi onako kak ti hoćeš, al definitivno probaj Truecrypt
Main Features:
* Creates a virtual encrypted disk within a file and mounts it as a real disk.
* Encrypts an entire partition or storage device such as USB flash drive or hard drive.
* Encrypts a partition or drive where Windows is installed (pre-boot authentication).
* Encryption is automatic, real-time (on-the-fly) and transparent.
* Provides two levels of plausible deniability, in case an adversary forces you to reveal the password:
1) Hidden volume (steganography – more information may be found here).
2) No TrueCrypt volume can be identified (volumes cannot be distinguished from random data).
* Encryption algorithms: AES-256, Serpent, and Twofish. Mode of operation: XTS.
Further information regarding features of the software may be found in the documentation.
Ovo je potpis.
mrga je offline   Reply With Quote
