Staro 28.04.2008., 16:59   #211
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Wtf????
Pa ak ne uspije pocuclat svu struju iz ploce uzimat ce iz dodatnih pinskih konektora iz napajanja.
Zar ne??
Majo je offline   Reply With Quote
Staro 30.04.2008., 22:09   #212
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Meni normalno dela na mojoj ploči koja ima PCIe 1.0
MC
Staro 05.05.2008., 13:18   #213
prasak
You'll never walk alone
prasak's Avatar
Postovi: 324
Ne znam kad je to kod nVidie bilo da najjača kartica na tržištu košta 2600kn!
http://www.adm.hr/product_info.php?c...oducts_id=5705
Ako nije greška...
i5 2500k i Ryzen 5 1600
prasak je offline   Reply With Quote
Staro 05.05.2008., 13:26   #214
jurbAs
jurbAs's Avatar
Postovi: 2,582
Autor prasak Pregled postova
Ako nije greška...
greska 100% 1000kn gore minimum
EDIT nazvao danas covijek je napravio gresku umjesto GTX napisao GX2 tako da se zna
jurbAs je online   Reply With Quote
Staro 05.05.2008., 13:45   #215
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
Ako nije greška...
ASUS EN9800GTX je najjača kartica na tržištu ?
ili su oni ispravili gresku ili si previse popio
edit: nisam ni skuzo jurbasov post ... *dumb*
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment.
-It`s what Jesus would do.
B3mt1 je offline   Reply With Quote
Staro 05.05.2008., 14:01   #216
Wolverine
Wolverine's Avatar
Postovi: 12,424
to je GTX a ne GX2
i iskreno preskupa je jer 8800GTS 512 nađeš za oko 1500kn
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 05.05.2008., 14:16   #217
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Ev da kazem kratke dojmove nakon 10 dana korištenja grafe...
Temp su ok, trebalo je namjestiti vrtnju ventilatora na 50-60% (toliko da ga ne čujem).
3D Mark06 - 18800 bodova.
Crysis lijepo dere sve na High na 1024x768, nije mi se dalo gnjavit s drugim postavkama...
Sve u svemu za sad sam vrlo zadovoljan.
MC
Staro 05.05.2008., 14:53   #218
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
prasak, pa ima več i 9800 gtx po 1800 kn tako da sumnjam da je greška......još bolje, bar če se uskoro ić u nabavu neke
edit: nisam skužio da je riječ o gtx a ne o gx2
Z-man je offline   Reply With Quote
Staro 05.05.2008., 16:01   #219
prasak
prasak's Avatar
Postovi: 324
E jesam pomutnju napravio... Pisalo je na tom linku da GX2 košta toliko, ali je očito bila greška u cjeniku koja je sad ispravljena.
Staro 05.05.2008., 22:40   #220
Razer
Razer's Avatar
Postovi: 11,642
Autor Sa_Stilom Pregled postova
Super?
Staro 05.05.2008., 23:06   #221
jurbAs
jurbAs's Avatar
Postovi: 2,582
kakvo zadovoljstvo?! ne kontam
Staro 06.05.2008., 18:30   #222
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Kartica je strava,tri reviewa sam pročitao..osim konstantnog problema sa ventilatorima odnosno hlađenjem kad je nvidia u pitanju,ne vidim nijednu manu ovoj kartici..pa ni cijenu,od 3.999kn ne smatram pretjeranom..to je ipak high-end..uzmemo li u obzir bar 20% pad cijene kroz pola godine,ako ne i više..nakon ljeta ova kartica se ozbiljno nameće kao odlična kupnja...
Pitanje je samo..otkud mi sad love za Lenovo220X,2x2gb neke brutalis meme, i Core2Extreme...
No to je cijena high-end komponenti..ne možeš ovo staviti na Dual-Core 2160...i onda glumiti baju....makar bi i to bilo zanimljivo..al meni se to više gadi,zakeljiti VGA od 4000kn na proc od 300...smiješno..
Tko ima love..nema alternative..
Staro 06.05.2008., 18:31   #223
Razer
Razer's Avatar
Postovi: 11,642
Eno imaš ju već za ~3300kn
Staro 06.05.2008., 18:31   #224
thedream
thedream's Avatar
Postovi: 5,458
Autor Razer Pregled postova
Super?
Nemoj uopće komentirati....to je kriminal..meni leti na 640x480 sve..
Staro 06.05.2008., 18:33   #225
thedream
thedream's Avatar
Postovi: 5,458
..ma rejzor,brate..pa vidi u šta ja gledam..pa to je kontejner CRT..kad ubodem Lenovo,ondak ćemo na 1920 puta nešto...il koja već reza..
a ne 1280x1024...i glavoboljćek nakon sat vremena..a u sobi 50 stupnjeva od ove kante
Staro 07.05.2008., 19:41   #226
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Istina, kriminal jest... No, tak to ide
MC
Staro 09.05.2008., 08:13   #227
Gradjanin
Gradjanin's Avatar
Lokacija: Livingrad
Postovi: 539
naj krivo shvatiti. no definitivno moras promjeniti neke stvari. osim ako bas ne inzistiras da ostane ovako kako sada imas.
prvo napajanje. ovakav stroj zasluzuje finiji struju. power/cooling 750Wquad bi recimo bio onak...slag na torti.
a monitor necu komentirati. imas recimo to tako, trenutno najbolju SOLO (iako su to zapravo dve u jednoj) karticu na trzistu a SAMO 19" monitor. ono, ta je kartica definitivno za 24" monitor i vise reze od 1024x768 u highu...ili se ti to samo salis
°Citius Altius Fortius°
Gradjanin je offline   Reply With Quote
Staro 09.05.2008., 08:27   #228
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Autor Gradjanin Pregled postova
A kaj misliš da će nešto dobiti sa snažnijim napajanjem? Ne bih vjerovao, ali razliku između Silencera i HX-a nebi niti ti skužio.
Staro 09.05.2008., 09:01   #229
mbed
mbed's Avatar
Postovi: 354
ako nisi primjetio, on ima crt monitor, pa može stavit malo veću rezoluciju
mbed je offline   Reply With Quote
Staro 09.05.2008., 09:04   #230
maX
maX's Avatar
Postovi: 7,326
a SAMO 19" monitor
hoces reci da taj "SAMO" 19'' samsung 959NF nemoze drzat 1280x1024 ili 1600x1200 rezu?
Staro 09.05.2008., 09:27   #231
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Dragi moj, ne trebaju mi perverzije, i moram reći da je komentar kao komentar totalna nebuloza.
Na LCD neću preći sve dok mi monitor ne rikne, i kad rikne, tražit ću novi CRT, ništa manji ili slabiji od mog. Da mi je naći 21 pa na dalje, do yaya.
Za Crysis na 1600x1200 ili 1280x1024 je odličan, pogotovo kako boje prikazuje. Već sam rekao da vrti i 1920x1440x75Hz.
Nažalost, neke igra bolje rade na SingleGPU, no za sada je to bio samo CSS.
A kamoli da 520W napajanje nije dovoljno, to neću ni komentirati. Napomenut ću ti samo da mi je ostao još uvijek ne upotrijebljen jedan kabel.
Imao sam 750W pa sam ga prodao, jer su čiste bedastoće imat takav bojler doma.
Tvoj komentar mi više zvuči na prcanje, te na ne razumijevanje, jer sam lijepo napisao da sam samo bacio oko na Crysis. To ne znači da igram igre na toj rezi.
Ponavljam, igrati igre na 1600x1200, da i uzmem 24" LCD, kao da će se nešto i promjeniti u prikazu.
Još uvijek tko god da svrati na kavu kod mene, kaže glasno da koliko je bolja slika na CRTu nego na LCDu...
MC
Staro 09.05.2008., 09:32   #232
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Autor maX Pregled postova
Vidi se da čovjek brije na rezu, a ne na kvalitetu.
Te da još manje zna o CRTima, komentar je bio tek toliko da nešto kaže...
MC
Staro 09.05.2008., 09:43   #233
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Autor mbed Pregled postova
Ali samo "malo" veću
MC
Staro 09.05.2008., 10:22   #234
ante2
ante2's Avatar
Postovi: 1,313
jel ti je monitor spojen sa BNC kabelom ili obicnim kablom ??
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 09.05.2008., 10:28   #235
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Trenutno običnim. Iako meni slika isto zgleda ijedno i drugo
Aj pustimo sad to, nego da pitam, 9800GX2 ima HDMI. Kupnju LCDa sam odgodio za kojih 2-3mj. Kako da u međuvremenu pustim sliku na CRT TV koji ima scart i composite?
Čuo sam da u chipoteci imaju VGA na Scart, al kad sam došao tamo, eno već mjesec dana, nisu još dobili na stanje...
MC
Staro 09.05.2008., 10:38   #236
ante2
ante2's Avatar
Postovi: 1,313
nisi uz grafu dobio i tkz obicni adapter sa composite izlazom ???
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 09.05.2008., 10:49   #237
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Ne, dobio sam 2 adaptera DVI2VGA, ali za HDMI nisam niš dobil.
Bum danas ponovo piknul BNC, nisam isprobavao na ovoj grafi.
Doduše, imam VGA 2 BNC, dal da nabavim DVI 2 BNC ili će ovaj bit ok?
MC
Staro 09.05.2008., 10:59   #238
ante2
ante2's Avatar
Postovi: 1,313
iz mog iskustva VGA 2 BNC na adpter za DVA na VGA (covjece koja komplikacija sa izrazima) radi ko puska pa ako ne budes imao problema ne vidim razlog da ides u potragu za egzoticnim adapterima tipa DVI 2 BNC (ako to uopce postoji, a ako da volija bi to vidit onako znatizelje radi)
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 09.05.2008., 11:02   #239
ante2
ante2's Avatar
Postovi: 1,313
gle ipak postoji DVI 2 BNC
http://www.pccables.com/00679.htm
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 09.05.2008., 11:05   #240
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Vidio sam da ima DVI 2 BNC, al čini mi se da nema u Hrv
Niš, bum baš bacil oko ponovo, jer kao što rekoh, nisam bio skužio razliku kad sam imao 7900GS ili GT više se ni nesjećam što sam imao.
Znamo da je 88xx serija bila revolucija kod nvidia kod prikaza slike, pa ću vidit kak to sad zgleda, iako se ne nadam da će nešto bit bolje, svakako javim
MC
