Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Nvidia’s Core-Logic Data Corruption & Overclocking
Zar opet? ![]() ![]() Nvidia Corp., a leading designer of graphics processors and chipsets, recently admitted that its most-recent chipset for Intel Corp.’s microprocessors may cause data corruption in case processor bus and system memory are overclocked. Earlier customers blamed previous-generation Nvidia’s core-logic sets for data corruption under the same circumstances. Apparently, when computer enthusiasts overclock processor system bus (PSB) and memory clock-speeds on systems that are based on Nvidia nForce 790i-series core-logic, they may experience data corruption on hard disk drives. Earlier end-users complained about the same issue on systems powered by previous-generations Nvidia nForce chipsets. “Nvidia has received reports of data corruption when using certain high speed memory and overclocking the front side bus. Our engineers are currently investigating this issue and as soon as we have more information, we will provide an update to this knowledge base article,” a statement by Nvidia in its technical support forums reads. Even though this is not the first time when customers complain about data corruption, neither Nvidia nor any of the mainboard makers have disclosed the reasons of the problem. Nvidia nForce 790i Ultra SLI core-logic supports Intel Core 2 processors with up to 1600MHz processor system bus and overclocking capability beyond that, dual-channel DDR3 memory with speeds over 2000MHz, three PCI Express 2.0 x16 slots for graphics cards, six Serial ATA-300 ports for hard disk drives and so on. http://www.xbitlabs.com/news/chipset...g_Company.html
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Hehehe dobro je da neke stvari uvjek ostaju konstanta u stalno promjenjivom IT svijetu... ![]()
-- Have a nice day... |
Super Moderators
Postovi: 17,485
Kad se samo sjetim kak su se špinčili da KT400 nema PCI lock a NF2 ima...pa se nastavilo sa problemima vezanim kaj za chipset kaj za opjevane sw ide drivere ![]() Citiram: Idemo dalje. Kraj citata. Mali savjet-koristite MS drivere i ne overklokujte svoj računar ako imate Nevidia chipset ![]()
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ae ae nf2 nije bio tako (jako) los. to sto imaju sljepce u odjelu za pisanje drajvera svakome se desi ![]() uostalom oni ustvari paze na svoje kupce ![]()
Lokacija: n/a
Postovi: 6,128
NF2 je imho jedini Nvidia chipset koji je valjao (prvenstveno zbog Soundstorma), NF4 donekle, jer je bio jako eksponiran (sve najbolje ploce iz tog doba su ga imale), iako nije bio superioran VIA-inom K8T890 (dobro sam vidio sta taj chipset moze). O Nvidia chipsetima za Intel procesore da ne govorim. Nijedan nije valjao, mozda zato sto su Intelovi chipseti toliko dobri. ![]() 790i je svejedno sranje od chipseta, bez obzira na ove probleme. |
Super Moderators
Postovi: 17,485
Pa, chipseti za AMD i nisu toliko loši, ali bi se o legendarnim driverima dalo razgovarati. Kad se samo sjetim kako je net uzduž i poprijeko bio zaglušen drekom nestretnih usera koji su zla ne misleć i ničim izazvani išli instalirati "Hardware-Based Firewall and ActiveArmor" điđice pa su se na službu za korisnike javljali isključivo sa susedovog kompa... ![]()
Postovi: 6,956
Hehe kako ne kužiš oni su skužili pravu i veliku istinu, jedini način da napraviš stvarno siguran komp je da korisnika izbaciš iz jednadžbe i to su i napravili... ![]()
Super Moderators
Postovi: 17,485
I meni se čini da su se vodili tom idejom ![]()
#9 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
S druge strane, vec vidim jedan dan na vijestima na PcE - "Pobjesnjeli haker tuzi nevidiju jer izgubio screenshotove svog svjetskog rekorda u superpiju".
Super Moderators
Postovi: 17,485
Ne moraju oni nikaj priznat-svaki mazohista koji drži do sebe ima kombinaciju Nevidia chipset/Pentijum, nije to ništa novo...ali ako u BIOS-u imaš "overclock" tab sa opcijama za clockanje...molim lijepo... ![]() Nije taj BIOS napravio mali Ivica u kućnoj radinosti nego Nevidia. Znači-to je ipak regularna opcija a ne nekakav izlazak iz regularnih parametara proizvoda.
Does youer dewg byte?
Postovi: 1,940
Samo jedan mali komentarčić na post iznad mene. Prije par godina kad ste kupovali matičnu,grafu, kaj god, u menjuelu ste mogli pročitati poruku tipa : Primite na znanje da OC smanjuje stabilnost sistema i povećava mogućnost neispravnosti komponenti. Danas kupite i pročitat će te poruku : Primite na znanje, OC opcija vam je u BIOSu , ili preko xxx programa . ![]()
" Have you tried turning it off and on again ? Are you sure it is plugged in ? " ![]() |
Super Moderators
Postovi: 17,485
Toliko o tome da komentiraš a očito ne znaš ni osnovni info o tom chipsetu... Budući da se radi o najskupljim pločama (rang 300$-450$), pločama koje se i reklamiraju za overclocking-vjerovao ti ili ne ti ljudi koji su utukli toliki novac u svoj stroj ne žele da im propadnu podatci. A bogme ni nisu iskrcali brdo para da bi vozili na default postavkama. DDR3, SLI ili Quad SLI u Ultra inačici, napon za proc do 2v...kad se složi takav stroj cifra je poprilična. Ili kako je to Nevidia najavljivala: "The Fastest, Most Overclockable Rig" ![]() Toliko o tome ![]() Nećemo ni pričat o tome da se radi o ploči koja se špinči sa NVIDIA® MediaShield™ Storage điđom...
Postovi: 11,642
Baš me zanima u kojim situacijama... Možda sa SATA diskom i PCI-E sabirnicom na 150MHz+ ![]() |
#15 | ||
E Pluribus UNIX
Lokacija: M82
Postovi: 6,753
OTOH, sto se tice tvojeg smijesnog referiranja na cijenu - postoje ploce za PC koje stoje reda velicine 1000$, pa na njima uopce nema "overclock" tab s opcijama za clockanje. "Entuzijasti modernog doba" ciji je maksimalni Grunfovski pothvat promjeniti tri opcije u sarenom BIOS-u jos uvijek nisu svjesni da njihovi poduhvati, ma koliko ih "sponzorirali" neki, jos uvijek ne samo da nisu profesionalni, nego donose i tisuci i jedan potencijalni problem. Naravno, zalosna je istina da bi ukidanjem ouvrklouka nVidia (i ne samo oni) popusili big time, no to samo govori o profilu tipicnog home PC usera - no to je vec neka sasvim druga tema... Citiraj:
#16 | |
Super Moderators
Postovi: 17,485
I da, 300$-450$ za ploču nije malo. Dakle-najskuplja ploča sa tim chipsetom. Namjenjena i reklamirana kao overclockerska. Ono : "The Fastest, Most Overclockable Rig Get unbeatable performance at stock and overclocked speeds (single GPU). NVIDIA nForce 790i Ultra SLI MCPs offer the highest CPU FSB overclocking with the latest CPU technology as well as unrivaled DDR3 memory overclocking. And real-time component monitoring and tuning features with ESA give you complete control over your PC." je sa Nevidia službenih stranica... Rezime-napravili su skupu overclockersku ploču koja ti ubije boga na harduljku kad je-pazi ti to clockaš ![]() Za krepat ![]() Na stranu korisnici koji su popušili sa ovom pločom (Quad, superskupi DDR3, SLI ili Quad SLI-dakle brdo para), ovo nije prvi put da dolazi do korupcije podataka sa Nevidia chipsetom. Bogme nije ni drugi put ![]() Koliko se sjećam-prije nisi ni morao clockati da bi došlo do korupcije podataka... I kaj su naučili iz svega toga-ništa ![]()
#17 | |
Postovi: 6,956
![]() E da i propo standarda i ostaloga, vidim da prodaješ svoju BA2 ploču, nije vrag da nije baš tako standardna kako bi trebala bit sa svojim "standardiziranim specifikacijama" jel.... ![]()
-- Have a nice day... Zadnje izmijenjeno od: yedwy. 21.04.2008. u 07:17. |
#18 | |||
E Pluribus UNIX
Lokacija: M82
Postovi: 6,753
#19 |
Super Moderators
Postovi: 17,485
No,no...istinabog da imam samo ATI grafe...ali sam imao i NF2, NF4 Ultra i sad imam isto Nevidia 590 SLI chipset ![]() Čak sam i overklokovao svoj računar ![]() Ne znam zakaj svi misle da ja ne volim Nevidiu ![]()
#20 |
Postovi: 6,956
Gle buba znam vidio sam onaj post koji si stavio oko diskovlja i da točno većina usera ne kloka mašine i zapravo ih nije niti briga kaj je uopće unutra i to stoji kaj veliš ali to ne znači da je ono kaj sam rekao manje istina, jer vidiš i sam da je dio koji kloka ipak značajan čim rade se takve ploče jel... ![]() To kaj ti ne spadaš u tu skupinu je već nekaj drugo... ![]() Osim toga sam si vidio sa pločom (koju pretpostavljam da nisi nikad niti klokao) da nije baš sve crno bjelo jel (a perjanica je ponude tog istog Intela nije li, tj ex perjanica ali nema veze) i da ne radi kako bi trebalo u jednom od segmenata koji bi kod takve ploče trebao biti skoro pa i najbitniji (mislim server/workstation/extreme PC ploča pa storage šteka???), sad ta greška ili bolje rečeno neoptimizacija koja tebe muči vjerojatno nebi mučila 99 od 100 korisnika ali eto postoji i tebe muči što opet nešto znači, možda je posljedica greške u čipsetu ili u ploči kao ploči to neznam, ali ako se zna da je cjela serija SVIH ploča baziranih na nečemu (aludiram na povod ovom threadu) u startu omašena počne se pitati koji k rade tamo ti dizajeneri čipseta, isto kao i smojom pločom i pržom, ima BSOD sindrom kad se koristi onboard zvučna i prža u isto vrijeme, neko je napisao da je to posljedica "neslaganja" čipseta ploče i čipseta prže, to je idiotluk od strane proizvođača mislim ja se fakat ne sjećam da mi na prži igdje piše "ne radi sa nf4 čipsetom kako treba"... ![]()
-- Have a nice day... Zadnje izmijenjeno od: yedwy. 21.04.2008. u 11:51. |
#21 | ||||
E Pluribus UNIX
Lokacija: M82
Postovi: 6,753
Nazalost, ni od tada nisu uspijeli rijesiti nekakve djecije bolesti na desktop chipsetima koje ih pate i svrstavaju ih u kategoriju neozbiljnih i nepozeljnih proizvodjaca chipseta. OTOH, uopce nisu napraviti los posao na Opteron based plocama sa svojim MPC+IO rjesenjima. Citiraj:
![]() Znacajni dio iz perspektive korisnika PiSiEksperata. PiSiEksperti su strahovito malen i skoro pa zanemariv dio citavog IT svijeta. Gdje se ne overklokira. Ne tjuna i ne stima latencije. Ne renderira high quality p0rn. O tome je bilo rijec. Nedvojbeno su klokeri, tvikeri i superpi korisnici veliki dio *njihovog* trzista. No sve u svemu, globalno, taj dio je zanemarivi reprezentativni primjerak da bi bilo potresno to sto izlazenjem iz standardnih specifikacija - stvar ne radi onako kako je zamisljeno. Citiraj:
Kao sto rekoh - my bad, u potpunosti.
#22 | ||
Postovi: 6,956
Zato jer sam pročitao još jednom i zaključio da nisi zaslužio onakav uvredljivi odgovor (ovaj puta) iako znaš i sam da nekad fakat nastupaš tako da... Mislim nisam niti ja niš bolji nekad i to je istina, svi nekad malo patronizirajuće nastupamo... Citiraj:
To što ti neki feature smatraš suvišnim ne znači da i jest, a ako nečega nema a misliš da treba opet ne znači da tako misli proizvođač, svako bira kaj mu se najviše sviđa... Ali ako neku ploču platim 1200kn (bilo to za porn ili bilo kaj drugo) radi toga jer ima OC opcije i sl ipak ne znači da oću da mi skoruptira podatke... ![]() Citiraj:
#23 |
Postovi: 10,805
od svega spomenutog ja bi samo htio da se ne blati nf2 nepotrebno ![]() driver sim-tam, tko je imao net i google to je riješio za pol sekunde ili uopće nije imao potrebe rješavati (imao sam i nf2 plain i kasnije 400 nisam imao problema sa nvidia ide driverima), dok sa druge strane imamo na ovom forumu 3-4 stranice veselih catalyst korisnika koji gledaju hd preko svojih state-of-teh-art drivera ![]() |
#25 | |
E Pluribus UNIX
Lokacija: M82
Postovi: 6,753
Jedini gorak okus je, kao sto si i rekao, sto je ta ploca navodni "vrhunac Intelove ponude".
#26 |
Lokacija: München/Varaždin
Postovi: 4,792
Dečki...prepirete se bez veze.Bubba je jednim dijelom u pravo i to onom da ako neka firma kaže da njihov proizvod može to i to onda on to mora i u stvarnosti moći bez ikakvih negativnih posljedica,jer inače je to lažno reklamiranje što bih osobno najstrože kažnjavao....Dakle-ako ploča ima RAID te piše da radi-onda jebemu miša on mora radit kako RAID i treba raditi bez ikakvih štucanja.Ako on ne radi kak spada na toj ploči,bolje ga maknut i reći "nismo stavili RAID na tu ploču jer s obzirom na isplativost i konačnu cijenu proizvoda on bi bio loš"...al tu dolazimo do krute istine-svima se njima lijepo j*** za sve nas i tretiraju nas kao što je Bubba i opisao-naivne kupce koji vjeruju svemu što marketing kaže...a to nas opet dovodi do klinaca koji sebe nazivaju hakerima,overklokerima i gejmerima koji kupuju iste proizvode da bi ostali bili zavidni na njih jer oni to imaju a oni ne (čast izuzecima)...to što se nezanju koristiti istima-ma koga šiša,glavno da on/ona to ima...a to prodavači vole jer znaju da će na taj način se ta "bolest" proširiti na većinu ljudi i oni će dobit svoj mali trgovački raj (prodaja muda pod bubrege)...Ako još niste shvatili,živimo u kapitalističkom društvu gdje je centar svijeta novac i trgovina i u čemu ne vidim ništa loše dok god ne dođe do prodaje na štetu ljudskih vrijednosti.... |
#27 |
Super Moderators
Postovi: 17,485
#28 | ||
Postovi: 6,956
![]() Citiraj:
![]() Ajd živio mi i sretno sa zamjenom iste zanešto bolje...
#29 |
ono ispred konpjuktora
Datum registracije: Apr 2003
Postovi: 3,659
potpisujem bubino. "ova kumica mora prestat prodavat sir, jer ona kumica do nje ima finiji sir". iako su oba sira zdrava i po svim standardima, itd. kupi i jedi kaj ti odgovara, al nemreš kumici reći da mora prestati prodavati sir zato kaj ova do nje po istoj cijeni ima sir koji je tebi finiji. možda ja volim baš sir koji je tebi manje fin, zato kaj mi je malo manje bitno da bude fini odmah kad ga kupim i jedem s friškim kruhom i mladim lukom, nego kad ga napravim sa tijestom. get my point?
#30 |
Super Moderators
Postovi: 17,485
Nja, nja, nja... Svi nekaj potpisuju, pričaju o standardima, IT-u... Stvar je jednostavna: Usrali su motku sa chipsetom prije (obećavali brda i doline a pomaka nije bilo) Zajebali korisnike (poznata fora o špinčenju sa RAID-om koji je po njihovom infu trebao bit malo tvrđi a ispao je žmefki ![]() Zanimljivo je da to nije nitko ni spomenuo a svi kao prate... I najvažnije kaj se tiče standarda-nije to Nevidia napravila i bacila na tržište bez testiranja i blagoslova od strane Intela ![]() Ne ide to baš tak kao neki misle... Molim lijepo-spike o pločama za ozbiljan rad ostavite po strani, pričamo o najačoj ploči za "vulgaris" korisnike. Najskupljoj ploči za taj segment tržišta. Ploči reklamiranoj i na kraju krajeva i predviđenoj za overclock ili igranje...na šarenoj kutiji će pisati da možete staviti svoje dvije-tri 9800 GX2, ubost najači Quad, DDR3 memu, to sve clockati i biti najača manga u kvartu ![]() Neka mi netko od poštovatelja standarda pošalje PDF od Tyanice u kojem dotična firma vabi kupce na tu spiku...gdje će kupac te ploče dobiti soft-RAID a da to nije napomenuto u specifikacijama, gdje će vam obećavati mrak perfomanse, Tri-SLI i clockanje vašeg najnovijeg Quada do neslućenih granica...i sve to u kompi sa DDR3 memom? ![]() Ne, naravno da Tyan neće navlačiti svoje kupce na takav način-to je firma koja je poznata po pločama za ozbiljnije stvari. Nema apsolutno ništa loše da netko kupi ploču za gejmanje ili overclock, najbolju i najskuplju na tržištu. Fakat ne kužim zakaj kad se spomene opaki bug na takvoj ploči prvi skaču u obranu lika i djela ljudi koji nit gejmaju, nit clockaju...niti bi kupili takvu ploču taman da dobiju na lotu ![]()
