Staro 26.03.2004., 11:34   #1
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
CoolerMaster
CM Stacker is a new computer chassis from Cooler Master with extremely powerful functions. The innovative design supports Extend ATX, BTX and dual power supply, making for easy upgrading. Besides its unique cross-flow fan, the CM Stacker supports up to eight regular fans, giving it unmatched cooling performance. Built from 1.0 mm thick steel plate, the CM Stacker is immensely strong, with a high-quality anti-vibration stand providing extra protection for the system. Designed for maximum extensibility and allowing the user the utmost flexibility in the utilization of space, the CM Stacker makes upgrading incredibly easy, and can be configured to meet your own personal needs with minimum hassle.
-Specification
-- Supports up to 11 5.25” drives
-- Moveable front control panel with 6 USB 2.0 connections
-- Maximum upgradeability; supports E-ATX and the upcoming BTX
-- Dual power positioning design
-Cooling
-CM Stacker supports up to 8 fans
-- Front – Full mesh screen provides superior air flow; support up to three 12 cm fans
-- Top - Ultra silent 8cm Fan * 1 (exhaust)
-- Side – Mesh screen on side panels provides the maximum air ventilation
-- Rear – Ultra Silent 12cm Fan * 1 + 8 cm Fan * 2 (intake)
-- Motherboard – 300mm cross flow fan; provides superior air flow for key PC components (CPU, VGA etc.)
-Assembly
-- Tool-free installation; Supports the use of screws for permanent installation
-- Maximum flexibility in space utilization for self-assembly
-Structural
-- Aluminum alloy motherboard tray frame
-- Strengthened with 1.00mm steel plates
-- Superior mechanical design for greater stability
__
Dimension 584 mm x 227 mm x 536 mm (D x W x H)
Material Aluminum Bezel , SECC Chassis
M/B Type EXTEND ATX (12" x 13") ; BTX
Power Supply Form Factor Standard ATX PS2
5.25 7 (Exposed)
3.5 1 (Exposed), 3 (Hidden)
Ventilation One 120 x 120 x 25 mm Front Fan (intake)
One 120 x 120 x 25 mm Rear Fan (exhaust)
One 80 x 80 x 25 mm Top Fan (intake)
Optional Component Aerogate II x 1
Additional USB 2.0 x 6; MIC x 1; Earphone jack x 1; IEEE 1394 (FireWire) x 1
Hmm...
Intel P4 1.8 Mhz
ASUS P4S533-E SiS 645DX
2 x 256MB DDR333 Samsung
HERCULES ATI Radeon 9800SE AIW 128 MB
HDD Seagate Barracuda 60 & 80 GB
NEC DVD RW+/-ND-2500
PSU Aopen 300W
Monitor EIZO 19" Flexscan
Microsoft IntelliMouse Optical
CoolerMaster Aerogate II
CoolerMaster Cool Drive 3
CoolerMaster 2 x 80mm vent LED Blue
Papst 120mm vent
SkyStar 2
Case InWin X710 Black
Zadnje izmijenjeno od: LuX.23. 27.03.2004. u 00:38.
LuX.23 je offline   Reply With Quote
Staro 26.03.2004., 12:10   #2
Stormeye
Billy lives forever
Stormeye's Avatar
Datum registracije: Dec 2001
Lokacija: Hrvatska,Split
Postovi: 756
koliko krznenih?
Dobro izgleda
FS Amilo M
Stormeye je offline   Reply With Quote
Staro 26.03.2004., 12:22   #3
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
Ma to još neće kod nas kolko mi se ćini!
Intel P4 1.8 Mhz
PSU Aopen 300W
Papst 120mm vent
SkyStar 2
Staro 26.03.2004., 13:14   #4
Hrwoye
Hrwoye's Avatar
Postovi: 245
OMG
fakat opako izgleda! ako saznaš još neke detalje vezano uz cijenu i mjesto nabave javi! ali imam osjećaj da će biti u rangu LianLi-a (mislim što se cijene tiče)
Hrwoye je offline   Reply With Quote
Staro 26.03.2004., 13:15   #5
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
Ej, kanta dobro zgleda, može se modat(iako je to grijeh ovome radit), možeš potrpat svu silu stvari unutra... ah...
Kolko to para, alo vi sa PCX dajte nabavite jedno za review
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 26.03.2004., 13:21   #6
Rivi
Ovo ispod nisam ja! :)
Rivi's Avatar
Datum registracije: Sep 2002
Postovi: 1,692
Pas mater, oću jedno ovo. 11 5.25 komada. A taman mi pofalilo mjesta. Oću jedno.
Potpisujem!
Rivi je offline   Reply With Quote
Staro 26.03.2004., 17:47   #7
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
Ma nemaš kaj tu rezati imaš samp staviti katodu možda ventova da diodicama i wire sleevs i to je to!
Ma kućište je stvarno prejebeno!
Intel P4 1.8 Mhz
PSU Aopen 300W
Papst 120mm vent
SkyStar 2
Staro 26.03.2004., 23:49   #8
Bart
PC maher
Bart's Avatar
Datum registracije: Feb 2004
Lokacija: N.Gradiska
Postovi: 272
Kućište je stvarno prva liga, zaista bih poželio jedno za sebe, međutim moram vam reći da se uz malo truda može doći do krasnog kućišta. Ja sam nabavio polovno BigTower kućište (bez napajanja) stavio unutra 400W napajanje (već su bila unutra dva PAPST venta 80mm (nečujni), stvar ima ladicu za najveće matične koje možete kupiti (normalno sa ladicom idu skupa sve kartice koje su ubodene u matičnu) , tako da je probavanje i rastavljanje vrlo jednostavno i zahvalno, i naravno za kućište sam dao svega 100 kunića, 5 kom. 5,25" i 6 kom. 3,5" što je meni dovoljno (bar za sada).
Naravno ovo Cooler Masterovo kućište je zaista koma i tko ga ne bi poželio.
Bart je offline   Reply With Quote
Staro 27.03.2004., 00:13   #9
ozren
PC Ekspert
ozren's Avatar
Datum registracije: Sep 2000
Lokacija: Zagreb, Hrvatska
Postovi: 1,214
Ne brinite se, bit ce test. Samo da stignu Stackeri
Nissan GT-R Black Edition
ozren je offline   Reply With Quote
Staro 27.03.2004., 15:45   #10
Jozha
Jozha's Avatar
Datum registracije: Oct 2001
Lokacija: Sesvete/Soblinec
Postovi: 773
Fala tetki da je netko napokon skužio da treba pometat 12cm ventove u kućište. Sam kaj bu cijena za ovu kantu opako opaka!
Jozha je offline   Reply With Quote
Staro 27.03.2004., 20:20   #11
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
Pa u moju kantu ide 12 cm vent
InWin
Intel P4 1.8 Mhz
PSU Aopen 300W
Papst 120mm vent
SkyStar 2
Staro 27.03.2004., 20:29   #12
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Lijepo izgleda .
Staro 28.03.2004., 00:23   #13
maky-st
hmhm...zzz svima...
maky-st's Avatar
Lokacija: 21000 Split
Postovi: 1,070
odlično izgleda samo koja je lova u pitanju
Staro 28.03.2004., 03:58   #14
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
Pa sigurno neće biti ispod 1500 kunića
Intel P4 1.8 Mhz
PSU Aopen 300W
Papst 120mm vent
SkyStar 2
Staro 28.03.2004., 10:54   #15
miato
(°_°)
miato's Avatar
Postovi: 3,249
... bez napajanja, naravno
Staro 28.03.2004., 12:09   #16
maky-st
hmhm...zzz svima...
maky-st's Avatar
Postovi: 1,070
ma daj moraju stavit napajanje nemože bez toga
Staro 28.03.2004., 12:25   #17
miato
(°_°)
miato's Avatar
Postovi: 3,249
imas pravo, jednog 300W jnca bi trebali stavit
Staro 28.03.2004., 13:33   #18
maky-st
hmhm...zzz svima...
maky-st's Avatar
Postovi: 1,070
uptavo tako netriba biti ništa posebnoe
Staro 28.03.2004., 14:09   #19
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
Ma da 300 W ćist ok!
Imam 300W Aopen što sam dobio sa kućištem i testirano na 360W i to stabilno!
Miato misliš da neće biti napajanje tranu?
Intel P4 1.8 Mhz
PSU Aopen 300W
Papst 120mm vent
SkyStar 2
Staro 28.03.2004., 14:23   #20
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Znajući Coolermaster --- nema šanse
Staro 28.03.2004., 14:26   #21
maky-st
hmhm...zzz svima...
maky-st's Avatar
Postovi: 1,070
ma daj sranje
Staro 28.03.2004., 15:17   #22
miato
(°_°)
miato's Avatar
Postovi: 3,249
bas tako
Staro 14.04.2004., 14:17   #23
Jozha
Jozha's Avatar
Postovi: 773
Eto može ga se kupit vani za 180 baksa.Znači da kod nas nema šamse da bude jeftinije od 1500kn. I to bez napajanja narafski!
Staro 14.04.2004., 15:56   #24
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Paaa...naši trgovci već tradicionalno računaju $x10
Ono kaj je vani 100$, kod nas je u pravilu soma krznatih.
