Datum registracije: Feb 2003
Postovi: 1,556
dobri kutevi - malo love
ASUS PW201 2080kn TFT-LCD Panel Panel Type: TFT LCD (Anti-Reflection Glare Panel) Panel Size: 20.1'' Wide Screen Max. Resolution: WSXGA+ 1680 x 1050 Pixel Pitch: 0.258mm Brightness (Max.): 350cd/? Contrast Ratio (Max.): 800:1 Viewing Angle (H/V): 176°/176° Display Colors: 16.7M Response Time: 8ms (Grey to Grey) ZBD (Zero Bright Dot): Yes Inputs Digital Input: 24-Pin DVI-D Analog Input: 15-Pin D-Sub Video Inputs: Composite x1, S-Video x1, Component x 1 Audio Input: R/L x 1 PC lin-in: 3.5mm Mini-jack Earphone Jack: 3.5mm Mini-jack Feature USB2.0 Hub:Upstream x 1, Downstream x 3 Picture in Picture (PIP) 1.3 Mega-Pixel Webcam Colors Silver + Black Speakers 3W x 2 Stereo Ergonomic Adjustment Tilt: +90° ~ -5° Swivel: +60° ~ -60° Pivot: 0° / 90° (Counterclockwise) High Adjustment: Yes Wall Mounting(VESA Standard) 100 x 100mm Security Kensington Lock Power Power LED: Blue (ON) / Amber (Stand-By) Voltage Rating: AC: 100~240V Consumption (Power-On): <80W Consumption (Stand-by): <2W Dimension (WxHxD mm) 560 mm x 496 mm x 280 mm Weight Net (Esti.): 9.7 Kg Gross (Esti.): 12.7 Kg Accessory VGA-Audio-USB 3 in 1 cable DVI cable Power adapter Power cord Support CD (User Manual, Pivot®Pro, LifeFrame) RCA cable Quick Start Guide Warranty card (optional) Regulation Approval |
#2 | |
JDM
Datum registracije: Sep 2004
Postovi: 6,137
Lokacija: Slav. Brod
Postovi: 491
Jos jedan kandidat za M&D
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3, IX::IS8 VIII:: Lorr. 155 51, AC Mle 48 PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
vjerujem da želi preporučiti ovaj ekran, a u preporuci se i ja pridružujem i odgovorno tvrdim da je ovo najbolji 20" ekran što se kod nas danas može nać na tržištu za te novce, a dođe mizernih 2000kn |
Postovi: 34,070
2.000kn za 20" monitor sa Zero Bright Dot garancijom, 1.3MPix webcamom i usb hubom? Bagatela. Jedino me malo smeta činjenica da ima ugrađene zvučnike - povećavaju dimenzije monitora, a nisu od neke koristi.
Postovi: 1,556
ne, ti si...i ona dole no**ina iz audija....dakle dužan sam objašnjenje uz prvi post (iz nekog razloga objašnjenje uz specifikacije iz prvog posta je negdje nestalo)..već su dečki ispod napisali dio odgovora a ja dodajem da se radi o monitoru sa m-pva matricom i "pravih" 16 mil boja....za malo love...dakle ovo je trebala biti dobra preporuka.. |
In the ghetto
Postovi: 1,943
Steta kaj nemaju tak nekaj u 22" za cca 2500kn. Ili mozda imaju pa sam ja noob :-)
Postovi: 1,556
ima asus 22" al je TN đubre....hebiga morali bumo se strpiti za 22"-ere sa boljim matricama (da, ima onaj famozni lenovo al je opet natrpana reza a ima i najgoru matricu za gamere...za šljaku super)... |
#9 | |
Postovi: 2,583
ako si mislio na nesto drugo osim na ghosting onda sorry |
Postovi: 602
#12 | |
Lika u mom srcu
Postovi: 9,887
i matricu koja je najbitnija u cijeloj priči. stvarno odličan monitor, ima odličnu sliku. |
#13 | |
Postovi: 1,556
prad review za asus pw210 + dobre fotke... http://www.prad.de/board/thread.php?threadid=26294 Quake3 na asusu hehe pila i pol za "šaku dukata" Zadnje izmijenjeno od: gnomisa. 21.01.2008. u 16:11. |
Postovi: 1,556
aghh sad sam našao da taj Asus ima glossy panel....našao sam u jednoj recenziji i kod jednog lika sa naših newsa..dakle bilo koje svjetlo a pogotovo upaljna lampa iza = refleksija na ekranu...šteta...uvijek neko s*anje s monitorom koji valja... @jurbas - pazi kod tog 24" della imao je onaj banding problem...potvrdili su mi u Kodeksu ukratko: http://gizmodo.com/gadgets/monitors/...nts-174098.php |
#16 |
Postovi: 2,583
cuj gledaj znam za to sad sam u dilemi izmedu della i lenova makar bi mi bila glavna primjena monitora za filmove.... cekam lenova da vidim sto ce biti .... makar planiram posjetiti mikronis i pogledat oba monitora u zivo i vidjet koji je bolji..... pa tamo presudit da vidim di ce se bolje okretat HD.ovi drugo je sporedno jedina prednost dell-a sto je 2 puta lijepsi od tog lenova.... makar mozda cak i docekam reviziju dell-a koja ce biti 1300:1 kontrast i nadam se da ce banding i ostale kerefeke popravit... |
#17 |
Lokacija: dalmacija
Postovi: 39
Kakav je ovaj asus za igre i jel moze onu foru smanjena reza a ostatak ekrana crni rubovi (hebiga kad grafičke brzo zastare, pa tko će ganjat visoku rezu)? |
#18 |
Postovi: 329
Ja sam sa svojim prezadovoljan . To mi je prvi LCD monitor nakon crt-a, slikom sam jako zadovoljan, a kvalitetom izrade i više nego iznenađen, monitor je dosta težak (samim tim djeluje robusnije i čvršče), stalak je najbolji koji sam dosad vidio sa velikim mogučnostima podešavanja. Sve u svemu odličan monitor ![]()
Abit AB9 Pro \\ INTEL E6300 1.86Ghz & CoolerMaster Gemini II + 2X Xsilence RedWing 120mm \\ G.E.I.L PC26400CL5 2GB \\ Sapphire 3870 TOXIC 512mb Seagate Barracuda 320GB 16mb SATA2 + 2x WD 500Gb, 16mb,SATA2 \\ DVD-RW SAMSUNG SH-W163A SATA & LITEON SHM-165S6S SATA LCD Asus PW201 20,1" \\ Antec P160 Aluminium \\ Enermax Liberty 500W \\ MX518 + func 1030\\ Potenciometar ZALMAN ZM-MFC1 plus, sreberni 5.25" |
#19 | |
Postovi: 1,556
btw, evo još jednog solidnog reviewa sa slikama: http://techgage.com/article/asus_pw201_20quot_lcd/ Zadnje izmijenjeno od: gnomisa. 22.01.2008. u 11:09. |
#20 |
Lokacija: Munich
Postovi: 2,222
preheben monitor za te pare,meni je jedino mal gluooopo što je ovaj "obrub" mal deblji pa neznam kak to izgleda uziwo... u svakom slucaju zanimljivo... ![]() |
#21 |
She`s back...
Postovi: 983
Ne znam je li netko primjetio, kod ovog filmića na kojem tip igra Q3 vidi se kako je donji dio ekrana povremeno prekriven nečim što bih opisao kao kvadratni filter koji taj do slike čini žućim od ostatka. Slika Je li riječ o šugavoj grafičkoj kartici, lošoj igri, ghostingu, efektu kamere ili nečemu drugome? |
#22 |
Postovi: 1,556
Zadnje izmijenjeno od: gnomisa. 22.01.2008. u 17:36. |
#23 |
Postovi: 1,556
USB hub, kamera, dizajn, m-pva matrica, 20" wide, kvalitetno kućište i postolje, štelanje po visini, pivot, 2 iljade kuna....za istu lovu ti samsung uvali chimei tn matricu...i zakelji svoj u narodu cijenjeni brand....sjajno..samo da nije It has a glossy screen - one of the most reflective we've ever seen at PC Pro - which is both its main strength and a major weakness. It adds a beautiful spark to colourful images and the sharpness of video is stunning, but even in just a reasonably lit room you'll see as much of yourself as of the action onscreen. In less harsh lighting, however, it won't be a huge issue. Zadnje izmijenjeno od: gnomisa. 22.01.2008. u 22:37. |
#25 | |
Postovi: 1,556
) i volim se igrat (pa i radit) dok je soba dosta zamračena....kakva je situacija po danu? ionak sam po danu (zimi) na poslu ali vikendom znam i po danu biti na kompu...i to uz dosta veliki prozor....btw, refleksija postoji i na CRT-u pa pretpostavljam da nije ništa gore od toga na asusu? |
#26 |
Postovi: 329
Meni je prozor s bočne strane monitora, i kad je monitor upaljen nema nikakve refleksije i može se najnormalnije raditi. A ako nemate izvor svjetlosti iza monitora ne trebate se uopće brinuti. A i ne znam kaj vas tak smeta ta refleksija, pa svaki CRT minitor ju je imao, a meni je ona samo dodatan plus monitoru, jer puno ljepše izgleda. Samo dalje prstima od nje i sve pet ![]() Btw, monitor je dimenzijama (znači širina i duljina) veći i od 22" modela, i puno ljudi se prevari misleći da je to 22" monitor, točnije svi koji su ga vidjeli su mislili da je 22" ![]()
#28 | |
Postovi: 1,556
EDIT: malo sam čitao prad-ov forum vezano za taj monitor...tamo jedan lik veli da bez obzira što ima dva velika prozora kraj stola na kojem je monitor - da nema problema sa refleksijom.... evo dole još jedan review (benchmark.co.yu)....njima je bolji stari TN samy ![]() ![]() http://www.benchmark.co.yu/modules.p...News&sid=11484 Zadnje izmijenjeno od: gnomisa. 23.01.2008. u 23:38. |
#30 | |
Lokacija: dalmacija
Postovi: 39
Test odziva je prošao zaista dobro, kašnjenja je teško primetiti, mada su ipak prisutna. |
