Staro 16.01.2008., 23:14   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Talking Catalyst 8.1 Hotfix
Catalyst 8.1 Hotfix
The information in this article applies to the following configuration(s):
Radeon™ HD2900 series
Radeon™ HD2600 series
Radeon™ HD2400 series
Radeon™ X1950 series
Radeon™ X1900 series
Radeon™ X1800 series
Radeon™ X1650 series
Radeon™ X1600 series
Radeon™ X1550 series
Radeon™ X1300 series
Radeon™ X1050 series
Radeon™ X850 series
Radeon™ X800 series
Radeon™ X700 series
Radeon™ X600 series
Radeon™ X550 series
Radeon™ X300 series
Windows Vista 32-bit Edition
Windows Vista 64-bit Edition
Windows XP Professional
Windows XP Home Edition
Windows XP Media Center Edition
Windows XP Professional x64 Edition
This hotfix resolves the following issues:
Fix for problems with DirectX and Radeon AGP Graphics cards.
Crysis: DirectX 10 Performance optimizations using Crossfire
http://support.ati.com/ics/support/d...estionID=31625
Izgleda da su se konačno sjetili AGP-ovaca
Staro 16.01.2008., 23:27   #2
HD3850
HD3850's Avatar
Postovi: 323
meni driveri nisu bas ok...jer kada sam stavio te nove nakon 7,12...i pokrenuo crysis...stekala mi je igra na pocetku i pokazivali se artefakti...i onda me izbacilo iz igre. Sada sam vratio 7,12 i sve dobro radi
HD3850 je offline   Reply With Quote
Staro 17.01.2008., 00:10   #3
nino
nino's Avatar
Postovi: 12,599
A gdje vi tu vidite podrsku za seriju 38xx?
Edit: Sad vidim da su izasli driveri 8.1, a ovo je samo hotfix. Starim jbga
Zadnje izmijenjeno od: nino. 17.01.2008. u 00:24.
Staro 17.01.2008., 01:12   #4
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Autor nino Pregled postova
Je buni malo jer nema teme na forumu "Catalydt 8.1" il tak nest pa bi trebali modovi ovu preimenovat u "Hotfix za Catalyst 8.1" ili tak nest
Sry za ovaj
No on topic el ovo sljedeca verzija drivera nakon 7.12 ili je to samo CCC u novoj verziji jer na temi vezanoj se nije spominjala nova verzija...
Staro 17.01.2008., 01:33   #5
Jelc
Super Moderators
Postovi: 17,485
Autor ShebY Pregled postova
Kako nema, thread za "normalne 8.1" je tu:
http://forum.pcekspert.com/showthread.php?t=95279
Staro 17.01.2008., 11:21   #6
Jelc
Super Moderators
Postovi: 17,485
No dobro, kaj nema ni jednog ponosnog vlasnika sa AGP grafaom da javi da li su konačno sredili drivere ili ne???
Staro 20.01.2008., 14:41   #7
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
...šefe ako oni driverima isprave kršionu koju su izazvali..svaka im čast..ja sve manje i manje nekako sumnjam da je do drivera..makar je to logično..daj Bože...prodao sam MSI-jevu vrhunsku X1950pro nakon 2 tjedna jer sam izludio na AGP-u.....
prije da je jednostavno 6pina 2much za AGP port..pa je narodno veselje pri igranju igara..odnosno full loadu...možda je u struji problem..tko to zna..pa se sve skrši..zbrejka..
neka netko javi..ja bi rado..al sam na 3870
Staro 21.01.2008., 00:50   #8
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 6,997
Evo ja sam jako dugo imao 7.5 na AGP stroju, sad sam stavio 8.1 (bez hotfixa), i normalno je izvrtio 3dmark (stroj nije za igranje pa nisam imao nikakvu igru za isprobati)
Staro 23.01.2008., 00:30   #9
miha76
Datum registracije: Jun 2004
Lokacija: home
Postovi: 2
nevalja ti link bar meni ne radi
http://tinyurl.com/2zn9m9
ja sam puknul 8.1 obicne i naravno da D3D ne šljaka...sad bum puknul fix ba bumo vidli.
1950GT AGP na KT600 sa Bartekom 3.2K
miha76 je offline   Reply With Quote
Staro 23.01.2008., 00:54   #10
miha76
Lokacija: home
Postovi: 2
Meni ne radi taj fix...uredno sam instalirao...ista greška D3D invalid call...hrpa sranja i ne radi...
Bar rade driveri sa CDa, jedini koji mi rade 7.4
Staro 23.01.2008., 18:06   #11
Ico2005
Ico2005's Avatar
Lokacija: Slavonija ravna
Postovi: 464
Većina "ponosnih" vlasnika, uključujući i moju malenkost, lude zbog problema sa driverima na AGP-u. Ne valja 8.1 skupa sa svojim horsshitom na AGP-u...
Ico2005 je offline   Reply With Quote
Staro 28.01.2008., 07:39   #12
DevNull
Spam Witch
DevNull's Avatar
Lokacija: Belišće
Postovi: 94
Ja imam x1950pro agp sa instaliranim 8.1 i nemam nikakvih problema, 3dmark06 radi ok kao i sve ostale igre koje sad do sada instalirao, WoW, Bioshock, Loki. Uredno radi i jako sam zadovoljan. Probat cu jos par igara poinstalirati da vidim.
DevNull je offline   Reply With Quote
Staro 30.01.2008., 14:42   #13
tin1
Postovi: 102
Autor DevNull Pregled postova
Ja imam x1950pro agp sa instaliranim 8.1 i nemam nikakvih ...
Kum ima Powercolor 1950pro AGP. Stroj se ne ruši ali povremeno je slika zbrčkana u igrama(oveći kvadratići, zazeleni se na tren, krugovi koji blješte itd.). I to sa bilo kojim driverima(6.11,7.1, 7.2, 7.6, 7.12, 8.1, 8.1fix). 3dmark06 prolazi ali na Canyon flight i Deep freezu isti slučaj kao i na igrama. Jel imaš ti iste probleme? To je nekakav Dell. Napajanje je 460W pa tu ne bi smjelo biti problema. Temperature: idle-42,3dmark-60.
tin1 je offline   Reply With Quote
Staro 04.02.2008., 10:38   #14
DevNull
Spam Witch
DevNull's Avatar
Lokacija: Belišće
Postovi: 94
Ne nije mi se srusio od kad imam ovu karticu komp a i temperatura mi je puno manja, na 3dmark06 (prolazi cijeli test) mi ide o/cana na 43°, a ne o/c je u full loadu oko 38°, u windowsima (idle) mi je temperatura kartice izmedju 32-35°, nema nikakvih promjena boje ili bilo kakvih problema koje si naveo, a takodjer imam Powercolor x1950pro verziju, do sad sam je isprobao na slijedecim igrama: Loki, WoW, Overlord, Bioshock, Team Fortress 2 i sve radi za 5.
Mozda da pogledas kakva je situacija sa pastom na hladnjaku? Znam da sam ja imao problem sa 6800gs kad sam je kupio, u idlu je bila oko 75° a full load skoro 100° pa kad sam skinio pasivac imao sam sta vidit, pasta lose razmazana i djelomicno kao razvodnjena, pa sam stavio novu i skino temp za 30 tak stupnjeva.
