Staro 21.12.2007., 19:05   #1
swatfreak
Postovi: 40
mjesecna potronja adsl
koliko Gb mjesecno ulovite surfanjem,p2p i ostalim
swatfreak je offline   Reply With Quote
Staro 21.12.2007., 19:14   #2
domis
Lokacija: Hrvatistan
Postovi: 4,165
oko 40 giga
Staro 21.12.2007., 19:34   #3
marq20
marq20's Avatar
Postovi: 620
svaki mjesec drugačije, u ovom mjesecu imam 50gb za sada
marq20 je offline   Reply With Quote
Staro 21.12.2007., 20:20   #4
Postovi: 34,032
oko 100Gb
Staro 21.12.2007., 21:55   #5
swatfreak
Postovi: 40
rekord 353 gb
Staro 21.12.2007., 21:56   #6
Crni_007
Crni_007's Avatar
Lokacija: Koprivnica
Postovi: 302
5gb
Crni_007 je offline   Reply With Quote
Staro 21.12.2007., 22:10   #7
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
obicno malo manje od 100gb
od toga je ~60gb upload ~30gb download
najvise 80gb upload i 70gb download
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment.
-It`s what Jesus would do.
B3mt1 je offline   Reply With Quote
Staro 21.12.2007., 22:23   #8
brentaal
Postovi: 298
Cca. 200GB, od toga tek 30GB uploada...
brentaal je offline   Reply With Quote
Staro 21.12.2007., 22:36   #9
DannyHR
Nub azz pwnzor!
DannyHR's Avatar
Postovi: 97
Oko 150GB... :-)
'Cause we hunt you down without mercy
Hunt you down all nightmare long
Feel us breathe upon your face
Feel us shift, every move we trace
DannyHR je offline   Reply With Quote
Staro 21.12.2007., 22:38   #10
jonyb
jonyb's Avatar
Datum registracije: Apr 2004
Postovi: 887
490gb rekord, prosječno 200-300
jonyb je offline   Reply With Quote
Staro 21.12.2007., 22:39   #11
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
oko 5-6gb, nema me preko tjedna kod kuce pa trosim skolski net xD
Staro 21.12.2007., 23:37   #12
Router
Hejter
Postovi: 6,521
oko 100gb svaki mjesec otkad imam flat ...
Router je online   Reply With Quote
Staro 22.12.2007., 01:31   #13
h3lld
Disturbed
h3lld's Avatar
Lokacija: Bogu Iza Nogu
Postovi: 1,420
od 50 do 150gb, ovisi kako kada ...
-potpis-
h3lld je offline   Reply With Quote
Staro 22.12.2007., 01:52   #14
nikola8
RiDe Or DiE-O.G.
nikola8's Avatar
Lokacija: cakovec
Postovi: 319
oko 100gb
nikola8 je offline   Reply With Quote
Staro 22.12.2007., 01:59   #15
tech
Postovi: 1,687
110-130gb...
Staro 22.12.2007., 02:18   #16
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
140 Gb
Staro 22.12.2007., 02:20   #17
atha
atha's Avatar
Postovi: 9,067
Imam Flat 8mbit, ali sam skrban. Trosim do 10gb max, najvise sam potrosio 30gb i to jos pred 3 i pol godine na 384/64.
___________
Just atha
x
Staro 22.12.2007., 03:35   #18
tech
Postovi: 1,687
Autor atha Pregled postova
Ti nisi normalan...ovak sa 2mbit-a skidam cijeli net...a kaj bi tek sa 8mbit....jooooj...
Staro 22.12.2007., 03:43   #19
morph
morph's Avatar
Postovi: 1,530
Autor tech Pregled postova
Prema ovome sto si napisao trenutno iskoristavas oko 1/4 2mbit veze
morph je offline   Reply With Quote
Staro 22.12.2007., 04:07   #20
tech
Postovi: 1,687
Gle sa 2mbit-a picim torrent po torrent..dok bi sa 8mbit to malo kombinirao...a ako još ukljucis buraza sa kojim sam u LAN-u....tako da se to iskoristi....
Staro 22.12.2007., 04:50   #21
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
što imate skidati preko 100gb mjesečno, meni nije jasno...
imam flat već dugo, no stvarno ne znam što bih skidao..
Staro 22.12.2007., 10:06   #22
Router
Hejter
Postovi: 6,521
Autor Gabre Pregled postova
tak sam i ja mislio , a onda sam otkrio neke nove svijetove multimedije koje dotad nisam ni znao da postoje na netu
Staro 22.12.2007., 11:32   #23
tech
Postovi: 1,687
Gle skidam cca 50GB setova, u osobnoj videoteci imam 2TB filmova...a kad se ufuraš u trackere nemreš stat...
Staro 22.12.2007., 11:55   #24
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
A od toga ti treba mozda 1% i preslusas i pregledas tek mozda 10% toga sta skines. To je ono, "daj samo da skidam da nabijam promet, bmk sta skidam ionako mi to nikad nece trebati, vazno je da ja imam najnoviji film, serije, mjuzu, programe..."
Staro 22.12.2007., 12:12   #25
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
e pa to i ja mislim, da se skida bez veze, i onda stoji u Tb diskova okolo po kući.
Staro 22.12.2007., 12:17   #26
tech
Postovi: 1,687
Kod mene nije tako...svaki film znam di je, i svaki sam pregledao...kod mene ide skidaj>gledaj>pa opet skidaj(a pola filmova je iz lokalne videoteka tako da su barem jednom pregledani), tako da se to pregleda...ali cemu uopce flat ako nista ne skidate...osim ako imate dublji džep...
Staro 22.12.2007., 12:32   #27
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Koja glupost...
Pa nije flat zato da se skida sve sto se skinuti da, nego zato da mozes bezbrizno biti na netu, a da se ne treses oko prometa. Ok skinut stvar tu i tamo, pa cak i svaki dan... al 24/7 skidanje je glupost.
Istina je, svi kad smo presli na flat smo imali maniju par dana, al Bože moj
Nakraju imas u folderu downloads 300gb gluposti koje neces nikada pogledati, a samo ti smetaju.
I da sam ja provider uveo bi sankcije za leechere tog kalibra.
I da moja mjesecna potrosnja je od 60-100gb. Cak i manje zadnje vrijeme....
Staro 22.12.2007., 12:32   #28
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Mislim da nikad nisam više od cca 50-70GB
Lud76 je offline   Reply With Quote
Staro 22.12.2007., 12:56   #29
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
kad sam dobil DSL prije 3 mjeseca, imal sa FLAT 2 mjeseca za 1kunu, i prvi mjesec sam imo 80GB a drugi 70GB.. tu sam si skinuo što mi treba i dalje imam 5GB paket.. ali mi je ipak malo premali taj paket.. a jesu to stavili, ono 1GB, 5GB i flat.. da je barem osnovni paket 5GB, ovaj drugo 15-20GB i FLAT.... jer puno igram COD4 i skidam live setove + kupljene mp3ce s beatporta.. i evo, već sam danas na 6GB... a gdi je još kraj mjeseca.. ili da smanje cijenu Flata na paket od 5GB i onda bi bilo oK...
T0mB1ll je offline   Reply With Quote
Staro 22.12.2007., 13:13   #30
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
imam paket 5 gb,od nove godine flat...
inace trosim do 5,ali mi fali skinuti filmic,igru,novije albume itd...
znam da ce me i ta ludost proci za tjedan dva (kao i ostale)...
