#421 | |
upgrading...
Lokacija: Zagreb->G.Dubrava
Postovi: 438
dakle razlike su GDDR3 i 4, odnosno 'kvaliteta' iste vrste chipa, citaj ovaj iz 3870 ce se najvjerojatnije bolje clockat od ovog iz 3850, pod uvjetom da rade na istom naponu, sto mislim (nisam siguran) da 3850 radi na malo manje voltaze, ne znam, meni je to itekako vrijedi tih para ![]() |
#423 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
#424 |
Postovi: 963
Catalyst 7.11 beta ATI has posted an update to the display driver that solves some issues when HD3800 / HD2000 is used to play CRYSIS. It updates the following : DirectX 10: Fixes texture flickering in bushes, clouds, trees Performance improvements DirectX 9: Fixes Anti-Aliasing corruption seen on the ATI Radeon 2900 Series Anti-Aliasing performance enhancements Crossfire performance improvements Fixes random graphics corruption during game play Download it from http://support.ati.com/ics/support/d...asp?deptID=894 (xp/vista) izvor : http://my.ocworkbench.com/bbs/showthread.php?p=423520 ATI Catalyst 7.11 Highly anticipated catalyst driver is here at last. It Solved these issues and more. Resolved Issues for the Windows Vista Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
http://game.amd.com/us-en/drivers_catalyst.aspx izvor : http://my.ocworkbench.com/bbs/showthread.php?t=69001 Zadnje izmijenjeno od: xPsycho. 24.11.2007. u 13:27. |
#425 |
Super Moderators
Postovi: 17,485
O čemu mi sad pričamo za Crysis? O ovom hotfixu: http://forum.pcekspert.com/showthread.php?t=87938 Ili o službenim 7.11?
#427 |
Postovi: 1,807
666 million transistors on 55nm fabrication process-Izgleda da je ati ovog puta odlučio okušat sreću sa tkz. vražijim brojem tranzistora. Meni stvarno nije jasno zašto ljudi nerjetko petljaju dotičnog tamo gdje mu nije mjesto.. Meni nema druge nego kupit nevidiju.. |
#428 |
Super Moderators
Postovi: 17,485
Koji su driveri izašli znam, samo mi nije bistro ovo sa 3870 i GT...mislio sam da netko ima link na test ili neki drugi info.
#429 | |
Postovi: 963
#430 |
Postovi: 159
vidio sam jedan review e sad cu probat ga opet nac preko googla uglavnom u novim driverima za 8800gt gubi 8-10% u craysisu na performansama jer sad renda sve efekte, dok catalyst 7.11 donosi poboljšanje atijevim karticama. Gledao sam samo craysis a ostale igre nisam ***iga evo idem nac link pa ga postam... |
#432 | |
Postovi: 109
#433 |
Lokacija: NA
Postovi: 2,620
gdje je gt 1800 kn? |
#434 | |
Postovi: 506
Evo vam brzi testić starih i novih drivera 1680x1050 sve na High bez AA. Prvi test su stari driveri, drugi test su novi. 24.11.2007 16:02:52 - XP Beginning Run #1 on Map-island, Demo-benchmark_gpu DX9 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen Demo Loops=3, Time Of Day= 9 Global Game Quality: High ============================================================== TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s) !TimeDemo Run 0 Finished. Play Time: 76.79s, Average FPS: 26.04 Min FPS: 18.84 at frame 154, Max FPS: 32.13 at frame 934 Average Tri/Sec: -25426880, Tri/Frame: -976309 Recorded/Played Tris ratio: -0.94 !TimeDemo Run 1 Finished. Play Time: 69.72s, Average FPS: 28.68 Min FPS: 18.84 at frame 154, Max FPS: 32.58 at frame 977 Average Tri/Sec: -27686782, Tri/Frame: -965216 Recorded/Played Tris ratio: -0.95 !TimeDemo Run 2 Finished. Play Time: 69.67s, Average FPS: 28.71 Min FPS: 18.84 at frame 154, Max FPS: 33.15 at frame 993 Average Tri/Sec: -27706424, Tri/Frame: -965129 Recorded/Played Tris ratio: -0.95 TimeDemo Play Ended, (3 Runs Performed) ============================================================== Completed All Tests <><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><> 24.11.2007 16:02:52 - XP Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 2869,5 24.11.2007 16:13:55 - XP Beginning Run #1 on Map-island, Demo-benchmark_gpu DX9 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen Demo Loops=3, Time Of Day= 9 Global Game Quality: High ============================================================== TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s) !TimeDemo Run 0 Finished. Play Time: 77.59s, Average FPS: 25.78 Min FPS: 13.40 at frame 144, Max FPS: 32.84 at frame 985 Average Tri/Sec: -25200344, Tri/Frame: -977678 Recorded/Played Tris ratio: -0.94 !TimeDemo Run 1 Finished. Play Time: 69.77s, Average FPS: 28.66 Min FPS: 13.40 at frame 144, Max FPS: 32.84 at frame 985 Average Tri/Sec: -27693826, Tri/Frame: -966146 Recorded/Played Tris ratio: -0.95 !TimeDemo Run 2 Finished. Play Time: 69.68s, Average FPS: 28.70 Min FPS: 13.40 at frame 144, Max FPS: 32.84 at frame 985 Average Tri/Sec: -27704284, Tri/Frame: -965241 Recorded/Played Tris ratio: -0.95 TimeDemo Play Ended, (3 Runs Performed) ============================================================== Completed All Tests <><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><> 24.11.2007 16:13:55 - XP Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 2868 |
#435 |
Postovi: 963
DaNiJ3L : bila je u ADM-u na pocetku 1850kn .....a poslje nisam nigdje vidio ispod 2000kn .....ali zato u varazdinu u ZIT-u xfx 8800gt 1900kn ![]() lajchi : pa po ovome sta ja vidim i nema bas neke razlike s tim driverima ..ili ne kuzim ovo ![]() |
#437 |
Postovi: 963
ma vec sam lud ....u ovih nekoliko dana procitao sam 10000 reviewa i na kraju sam zakljucio da sam sad jos vise zbunjen nego sta sam bio ![]() |
#438 |
Postovi: 1,264
Psycho, posto nisi neki zahtjevan gejmer ;P na tvom mjestu bi uzeo jednu 3850 s finim hladjenjem (Powercolorka sa zerothermom kakva je na testu pada na pamet, pa se netrebas zahebavati s dodatnim hladjenjem), ak ti sfali snage clockas ju na frekve 3870 i ustedis kakvih 700-800 Kn ![]() |
#441 |
Postovi: 3,777
http://www.guru3d.com/article/Videocards/472/13/ sad po ovome je 8800GT osjetno jaca od 3870. mislio sam nabaviti 3870 ali me ovo razocaralo... ![]() |
#443 |
localhost
Postovi: 711
Evo još jednog usporednog testa: http://www.hardwarecanucks.com/forum...e-preview.html |
#444 | |
Postovi: 506
Baš suprotno. Na toj kartici je vent stalno na 30%, i digne se za 10% u igrama. Ali za dobro hlađenje treba biti na 55-60%. |
#446 |
Postovi: 506
Pa buka na 55% je podnošljiva, a temperatura ide max nekih 60c +-5 s naklokanom karticom. Ako se kartica nebi klokala (što bi bilo šteta ![]() |
#448 |
Sir Paški
Postovi: 356
lajchi, nekako sam bia pod dojmom da imaš PowerColor sa stock hlađenjem, jer je stef mislia na PowerColor PCS kartice sa Zerotherm hlađenjem koje se stvarno vrti na 100% i ne može se zasad podesit koliko ja znam. Kod stock hlađenja temperature 80 C su prihvatljive jer ih lipo hladnjak puše van. I još nešto, mislim da je 3850 dobra kartica koja je u rangu s 1950XTX (bar prema anandtechu) ali ako je 3870 skuplja samo 300 kn i ima duplo više memorije (gledam vemil) onda je stvarno bačena u drugi plan. Nego, kad dolazi 3870 u vemil jel itko zna? |
#449 |
[CTN]Mr.Ti
Lokacija: Zg, Novi Zg
Postovi: 563
Digi tech je stavio u cjenik GeCube hd 3870 X turbo edition, nesto neznatno oc, ali drugi cooler po slici, drugaciji vent i heatpipe, ali i postena cijena: http://www.gecube.com/products-detai...&prod_id=69097
CPU: Ryzen 7 5700G / Noctua D15S; MBO: MSI B550 Tomahawk; RAM:Corsair Vengeance 2x16 3200MHz; GPU: XFX Merc 319 RX 6900 XT; HDD: 1. Samsung 970EVO 256 GB; 2. Crucial P2 500GB; PSU: EVGA Supernova G2 750; CASE: NZXT H440 White; MONITOR: Asus MG279Q; KEYBOARD: Roccat Vulcan 100; MOUSE: Razer ViperMini @ SteelSeries QCK mass; HEADPHONES: Kingston HyperX Cloud (I) - Superlux HD-681 EVO |
#450 | |
upgrading...
Postovi: 438
dobio sam odgovor od lost-a: Citiraj:
