#361 |
Postovi: 506
Fraps Evo i crysis bench. 1680x1050, FULL, 4xAA TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s !TimeDemo Run 0 Finished. Play Time: 115.58s, Average FPS: 17.30 Min FPS: 9.47 at frame 276, Max FPS: 20.69 at frame 1761 Average Tri/Sec: -15794874, Tri/Frame: -912816 Recorded/Played Tris ratio: -1.00 !TimeDemo Run 1 Finished. Play Time: 108.80s, Average FPS: 18.38 Min FPS: 9.47 at frame 276, Max FPS: 20.72 at frame 1763 Average Tri/Sec: -16579325, Tri/Frame: -901918 Recorded/Played Tris ratio: -1.02 !TimeDemo Run 2 Finished. Play Time: 108.62s, Average FPS: 18.41 Min FPS: 9.47 at frame 276, Max FPS: 20.72 at frame 1763 Average Tri/Sec: -16593732, Tri/Frame: -901237 Recorded/Played Tris ratio: -1.02 !TimeDemo Run 3 Finished. Play Time: 108.44s, Average FPS: 18.44 Min FPS: 9.47 at frame 276, Max FPS: 20.72 at frame 1763 Average Tri/Sec: -16619749, Tri/Frame: -901099 Recorded/Played Tris ratio: -1.02 TimeDemo Play Ended, (4 Runs Performed) Zadnje izmijenjeno od: lajchi. 22.11.2007. u 23:32. |
#362 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ma, kaj se gnjaviš sa 4xAA u Crysisu...trebao si samo izvrtit bez... Ta reza me baš i zanima koliko daje na srednjim a koliko na high postavkama. Da mogu usporedit sa mojom krampinom ![]()
#363 | |
Postovi: 506
![]() 1680x1050 sve HIGH bez AA TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s) ============================================================== TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s) !TimeDemo Run 0 Finished. Play Time: 76.23s, Average FPS: 26.24 Min FPS: 15.44 at frame 152, Max FPS: 30.85 at frame 1782 Average Tri/Sec: -24762692, Tri/Frame: -943784 Recorded/Played Tris ratio: -0.97 !TimeDemo Run 1 Finished. Play Time: 72.15s, Average FPS: 27.72 Min FPS: 15.44 at frame 152, Max FPS: 32.34 at frame 991 Average Tri/Sec: -25877656, Tri/Frame: -933586 Recorded/Played Tris ratio: -0.98 !TimeDemo Run 2 Finished. Play Time: 72.07s, Average FPS: 27.75 Min FPS: 15.44 at frame 152, Max FPS: 32.34 at frame 991 Average Tri/Sec: -25905582, Tri/Frame: -933522 Recorded/Played Tris ratio: -0.98 !TimeDemo Run 3 Finished. Play Time: 72.08s, Average FPS: 27.75 Min FPS: 15.44 at frame 152, Max FPS: 32.34 at frame 991 Average Tri/Sec: -25933684, Tri/Frame: -934655 Recorded/Played Tris ratio: -0.98 TimeDemo Play Ended, (4 Runs Performed) 1680x1050 sve MEDIUM bez AA TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s) !TimeDemo Run 0 Finished. Play Time: 37.46s, Average FPS: 53.38 Min FPS: 40.81 at frame 145, Max FPS: 61.87 at frame 907 Average Tri/Sec: 46854300, Tri/Frame: 877672 Recorded/Played Tris ratio: 1.04 !TimeDemo Run 1 Finished. Play Time: 33.41s, Average FPS: 59.86 Min FPS: 40.81 at frame 145, Max FPS: 71.36 at frame 83 Average Tri/Sec: 52965616, Tri/Frame: 884833 Recorded/Played Tris ratio: 1.04 !TimeDemo Run 2 Finished. Play Time: 33.39s, Average FPS: 59.89 Min FPS: 40.81 at frame 145, Max FPS: 71.36 at frame 83 Average Tri/Sec: 53019396, Tri/Frame: 885219 Recorded/Played Tris ratio: 1.04 !TimeDemo Run 3 Finished. Play Time: 33.40s, Average FPS: 59.88 Min FPS: 40.81 at frame 145, Max FPS: 71.36 at frame 83 Average Tri/Sec: 53033272, Tri/Frame: 885669 Recorded/Played Tris ratio: 1.03 TimeDemo Play Ended, (4 Runs Performed) Zadnje izmijenjeno od: lajchi. 23.11.2007. u 08:40. |
#365 |
herr Flick
Postovi: 2,085
KGB super moderator, sve znas Da mi je samo znati kako ? Neciji prstici su jos tu umijesani, imas neku vezu u Umagu ? ![]() Krepala je mrcina ne radeci nis, mozda je to i sreca, ko zna. Da je to bilo u radu mozda bi mi bilo skurilo i komp brrrrrrrrr, ne smijem ni pomisliti Ali bio je pod garancijom, i zahvaljujuci pomoci debelog kempera Mitzeka dosao sam do http://www.chieftec.eu/index.php?opt...id=268&Itemid= sada 2900 Pro ima svoje odvojene 6 i 8 pinske konektore za napajanje i radi ko pupica. Sa HR-03 R600 najvise temperature poslije 2 sata Crysisa su joj : CPU 53, VRM 65 Ko zna bi li isao na 3870 i na koliko bi je ohladio ? Mozda zaledio ? ![]()
.:S:T:A:L:K:E:R:. . :2 u ocekivanju ![]() nema vise zippacha ...... |
#367 |
Super Moderators
Postovi: 17,485
#368 |
Postovi: 2,651
Ma da dobro izgleda.... Izvrsno izgleda! ![]() A najavljuje se i pad cijena 38xx serije kroz tjedan dva, kud ćeš bolje (Eto zašto ne treba odmah kupiti nove stvarčice )
#369 |
Postovi: 506
#370 |
Postovi: 11,642
Pad cijena jest najavljen, samo nekako sumnjam da će se to kod nas ''osjetiti'', ali nada umire posljednja ![]() |
#372 |
Super Moderators
Postovi: 17,485
Nekaj se LAcy u zadnje vrijeme često zatekne na ATI podforumu-nije vrag da bude prešao na ATI??? ![]()
#373 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,541
Misliš da pređem u crveni tabor? Odnosno zeleni? nVidia je zelena i AMD je zelen, baš su ga zapetljali ![]() Ja imam namjeru mijenjati grafičku. Sad pratim i gledam što bih, čekam do 03.12. kada bi trebal izaći nova GTS. Nakon toga datuma odvagnem i uz konzultaciju kolega sa foruma odlučim što. Imao sam kratko vrijeme ATI u kompu i ugodno me iznenadio. Pamtim ga kao proizvod sa iznimno mušićavim driverima ali sad mi se čini da je situacija obrnuta.
#375 |
Postovi: 2,651
Nekako se i meni čini da jenjava ''8800gt opsesija'' ![]() Što se cijena tiče, mislim da bi one išle dolje i bez ove najave. Trgovci kod nas uvijek po dolasku ovakve robe stave malo višu cijenu za prvi ulov, a za relativno kratko vrijeme to padne na neku razumniju cijenu. Naravno, ne treba očekivati 3850 ispo 1000kn za dva tjedna ![]()
#376 |
Premium moderator
Postovi: 4,600
Pad cijena, na koliko bi pale?
__________________ |
#377 |
Postovi: 2,651
#378 |
Lokacija: Vz - Zg
Postovi: 2,930
hmm.. ako envidija i a(md)ti uspiju proizvesti do bozica neku enormnu kolicini 38x0 i 8800 g92 kartica koje ce se sve razgrabit ma kako bilo moglo bi se desit da napokon proizvodaci igara pocnu optimizirat te igre pa da se malo duze mozemo igrat posto ce to prakticki bit jedini cipovi u opticaju ![]()
#379 |
Postovi: 7,568
TSMC i UMC su za AMD već sad proizveli (u usporedbi s 8800GT zalihom) enormnu količinu kartica. nVidia šuti o daljnoj raspoloživosti G92 čipova, a priča se da bude 8800GTS G92 128SPa stigel u manjim količinama nego kaj je to bil slučaj s 8800GT. |
#381 |
Postovi: 7,568
AMD more preplavit tržište (ne baš s 5x većom količinom, ali more). S tim da daljnim rezanjem cijena HD 3800 serije i nVidia mora stavit kakav popust, ako hoće prodat svoje kartice. Jeftinija izrada čipova za HD 3800 seriju, brutalni zahtjevi (od strane Della i HPa) za G80 modelima, rokovi za nove kartice i mjesec dana uranjen izlazak 8800GT su glavni razlozi za slabu dobavljivost i (pre)visoke cijene 8800GT kartica. |
#383 |
Postovi: 7,568
IMHO ~1.300 kn za HD 3850 i ~1.700 kn za HD 3870 su i više nego pristojne cijene za ono kaj kartice nude. Naravno da je bolje da budu još jeftinije, ali ako su ljudi (kad je još bila nova) pokupovali 8800GTS 320 koja je bila debelo iznad 2.000 kn, nema sumnje da bude i HD 3800 serija našla sretne vlasnike. Još ako u međuvremenu (spominje se 29.11 pa nadalje) cijene padnu za koju kunu - di ćeš bolje. ![]() |
#384 |
Lokacija: sisak
Postovi: 19
Gdje kupiti hd3850 bez čekanja
Dakle, jel zna tko gdje bi se to sutra moglo kupiti? Većina ovih sa nabave, nemaju i moraju naručivati, pa me zanima dali ima neka trgovina u kojoj je ta kartica raspoloživa odmah. |
#386 |
Super Moderators
Postovi: 17,485
#387 |
In the ghetto
Postovi: 1,943
U vemilu je 3870 po cjeni od 1621kn - jako dobra kupnja
#389 |
herr Flick
Postovi: 2,085
#390 |
Lokacija: Ispod zvijezda
Postovi: 95
