Staro 24.10.2007., 15:22   #1
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Kopiranje u DOS-u?
Trebao bih jedan fajl sa diskete u DOS-u prekopirati u C:\Windows\system32, zanima me da li tko zna kako bi točno trebala glasiti naredba za kopiranje? Unaprijed zahvaljujem na odgovoru
** AMD FX-4300 @ 3.8 Ghz ** Asrock 990FX Deluxe 3 **16 GB G-Skill 1600Mhz ** Intel 545s 500 GB + 2xWD 1 TB ** MSI GTX 660 2GB ** DVD-RW LG H42N ** Corsair HX620 ** Logitech MX Master 2S ** Dell U2414 **SAMA Vulture
Babaloo je offline   Reply With Quote
Staro 24.10.2007., 15:25   #2
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,531
Loooooooooool, naredba glasi copy.
Otprilike ovako
copy a:\imefile.ext c:\windows\system32
P.S.
Eh ti današnji klinci, dijete Windowsa
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 24.10.2007., 15:25   #3
Paxton
Expert from the shadow
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
COPY [/Y|-Y] [/A][/B] [d:][path]filename [/A][/B] [d:][path][filename] [/V] ili COPY [/Y|-Y] [/A][/B] [d:][path]filename+[d:][path]filename[...] [d:][path][filename] [/V] /Y - Causes COPY to replace existing files without providing a confirmation prompt. By default, if you specify an existing file as the destination file, COPY will provide a confirmation prompt. (In previous versions of DOS, existing files were simply overwritten.) /-Y - Displays a confirmation prompt before copying over existing files. /A - Used to copy ASCII files. Applies to the filename preceding it and to all following filenames. Files will be copied until an end-of-file mark is encountered in the file being copied. If an end-of-file mark is encountered in the file, the rest of the file is not copied. DOS will append an end-of-file mark at the end of the copied file. /B - Used to copy binary files. Applies to the filename preceding it and to all following filenames. Copied files will be read by size (according to the number of bytes indicated in the file`s directory listing). An end-of-file mark is not placed at the end of the copied file. /V - Checks after the copy to assure that a file was copied correctly. If the copy cannot be verified, the program will display an error message. Using this option will result in a slower copying process.
Paxton je offline   Reply With Quote
Staro 24.10.2007., 15:27   #4
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,084
Autor Babaloo Pregled postova
1.Otvoriš dva windows eksplorera, u jednom se postaviš u C:\Windows\system32, a u drugom na a:
2.selektiraš željeni fajl sa A: i odvučeš ga mišem u windows ekplorer di si otvorio C:\Windows\system32 i pustiš miša.
:hoćuinternet:
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
Staro 24.10.2007., 15:30   #5
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,531
A jeste mu pomogli, jedan je dao c/p rezultata copy/? a drugi nije čitao da je pod DOS-om i da nema windows explorer, još jedno dijete Windowsa
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 24.10.2007., 15:31   #6
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Autor LAcy Pregled postova
Otprilike ovako
P.S.
Da da, dijete windowsa Ma znam i ja da je naredba copy, samo nisam bio siguran da li ide možda ime fajla u navodnike i ima li kakvih posebnih filozofija jer duuuuugo to nisam radio
Staro 24.10.2007., 15:33   #7
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,531
MA šalim se Napisao si DOS, on poznaje samo kratka imena.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 24.10.2007., 15:46   #8
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,084
:hoćuinternet::hoćuinternet::hoćuinternet::hoćuinternet::hoćuinternet::hoćuinternet:
Staro 24.10.2007., 20:38   #9
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Ako imaš ntfs particiju, onda moraš dignut najprije ntfs dos driver...
copy a:\file.dat c:\windows\system32\
ako ti ne radi AltGr+Q za kosu crtu onda drži lijevi Alt i utipkaj 092 na NumPadu
Nemam više lema!!!
