Staro 19.10.2007., 18:48   #31
Postovi: 23,542
Autor pi3r Pregled postova
Jos jedan od problema sa ovim modemom....
Kad otvorim IE ili FF i upisem u adress: http:\\192.168.1.1 , nece da mi "otvori router"...
Kada idem preko D-LINK-ovog instalacijskog CD-a, pita me administratorsku sifru. Probao sam "0000" i "admin" al ne uspijeva..
Kad idem preko T-com-ovog famoznog instalacijskog CD-a "instaliraj i surfaj" (mos mislit), onda mi na zadnjem koraku kaze da router nije prikljucen na racunalo.... Prijedlog, please?
Pročitaj Sticky - ADSL Biblija
Postavi fiksnu IP adresu, Gateway i DNS - ove na računalu i moći češ "otvoriri" web konfig routera.
Ostali potrebni info već postoji tu na forumu, potraži malo.
Također x puta već rečeno da ti install / konfig cd - ovi zezaju, treba konfig odradit "pješke" (cca 5 min.) i sve će biti ok.
Staro 19.10.2007., 19:02   #32
Postovi: 23,542
Autor Serafian Pregled postova
dns serveri od t-coma su inače 195.29.150.3 i 195.29.150.4
Alternative:
Od ovog ljeta isto od T-Come: 195.29.150.204 i 195.29.150.205
OpenDNS: 208.67.222.222 i 208.67.220.220
Evo Ping test report:
Pinging 195.29.150.3 with 32 bytes of data:
Reply from 195.29.150.3: bytes=32 time=18ms TTL=249
Reply from 195.29.150.3: bytes=32 time=17ms TTL=249
Ping statistics for 195.29.150.3:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 17ms, Maximum = 18ms, Average = 17ms
Pinging 195.29.150.4 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 195.29.150.4:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Ovaj je očito van funkcije
Pinging 195.29.150.204 with 32 bytes of data:
Reply from 195.29.150.204: bytes=32 time=17ms TTL=58
Ping statistics for 195.29.150.204:
Minimum = 17ms, Maximum = 17ms, Average = 17ms
Pinging 195.29.150.205 with 32 bytes of data:
Reply from 195.29.150.205: bytes=32 time=18ms TTL=58
Reply from 195.29.150.205: bytes=32 time=17ms TTL=58
Ping statistics for 195.29.150.205:
Pinging 208.67.222.222 with 32 bytes of data:
Reply from 208.67.222.222: bytes=32 time=55ms TTL=46
Reply from 208.67.222.222: bytes=32 time=53ms TTL=46
Reply from 208.67.222.222: bytes=32 time=56ms TTL=46
Ping statistics for 208.67.222.222:
Minimum = 53ms, Maximum = 56ms, Average = 54ms
Pinging 208.67.220.220 with 32 bytes of data:
Reply from 208.67.220.220: bytes=32 time=56ms TTL=47
Reply from 208.67.220.220: bytes=32 time=54ms TTL=47
Reply from 208.67.220.220: bytes=32 time=57ms TTL=47
Ping statistics for 208.67.220.220:
Minimum = 54ms, Maximum = 57ms, Average = 55ms
Zadnje izmijenjeno od: Nikky. 19.10.2007. u 19:14. Razlog: Nadopuna
Staro 20.10.2007., 00:44   #33
Serafian
D&D
Serafian's Avatar
Lokacija: Zagreb - Jastrebarsko
Postovi: 156
hm zanimljivo
Serafian je offline   Reply With Quote
Staro 20.10.2007., 08:37   #34
Nammoth
Nammoth's Avatar
Lokacija: Zagreb, Trešnjevka
Postovi: 215
danas pogledam propertiese konekcije: Domain Name Server 195.29.149.197, 195.29.149.196
Nammoth je offline   Reply With Quote
Staro 20.10.2007., 15:02   #35
pi3r
Postovi: 35
Autor Nikky Pregled postova
Ma procitao sam ADSL bibliju nekoliko puta i u njoj ne pise nista sta vec i sam ne znam...Postavio sam fixnu IP adresu odmah u pocetku, al svejedno ne otvara web konfig routera. Probao sam i sa resetiranjem, al nista.
Ne znam sta cu vise napravit...Jedino mi nije jeasno ovo sa ovim dijelom tvog posta u kojem pise "konfig treba odraditi pjeske"!?Moze li malo pojasnjenje jer na forumu nisam uspio nac nista vezano za to.
Hvala na odgovoru!
P4 (prescott) 3GHz @ 3.3GHz (ST + 120mm TT)
Gigabyte DS3
2*1024 Kingmax DDR2 800 @ 900
ATI X700 pro @ 500/1000 -- Arctic cooling S2
Maxtor 200GB
pi3r je offline   Reply With Quote
Staro 20.10.2007., 15:59   #36
Serafian
D&D
Serafian's Avatar
Postovi: 156
mora ti prolaziti ping do routera, ako prolazi onda moraš napraviti delete cookies i files te postaviti securyti na defoult na internet opcijama, isključiti sve antivirusne i firewallove, ako ni tak ne ulazi onda ti nešto nije u redu s modemom. ako si ga uzeo u t-comovom paketu onda ljepo 08009000 i prijavit će ti smetnju te će ti neko zamjeniti (ako ti traje ugovorna obveza)
Staro 20.10.2007., 16:00   #37
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
identični problem imam ko pi3r sa frendovim 584T... već sam lagano lud...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 20.10.2007., 16:00   #38
Serafian
D&D
Serafian's Avatar
Postovi: 156
e da možda ti nevalja internet explorer, pa probaj i s mozillom i obrnuto
Staro 20.10.2007., 17:01   #39
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
dio problema sam riješio kroz postakve u internet options, ali sad me ***e što nikako da uspostavi vezu. dakle username i password su tu, ali me zanimaju oni VCI i VPI (?) brojevi, u papirima piše 8 i 35, ali mi se čini da to nije točno...
Staro 20.10.2007., 21:12   #40
Serafian
D&D
Serafian's Avatar
Postovi: 156
ne vpi = o
vci = 33
Staro 20.10.2007., 21:19   #41
Serafian
D&D
Serafian's Avatar
Postovi: 156
sofija waršava zagreb --> next --> zadnje bridge mode
vpi = 0, vci = 33, 1483 bridge ip llc, next, restart
napravite novu konekciju i to tak mora raditi
inače taj modem bi trebao raditi u bridge modu iako ga mnogi stavljaju u routing mode,
za bridge mode:
upišite u adress bar 192.168.1.1
user name: admin
pasword: 0000
kliknete run wizard
next --> sofija waršava zagreb --> next --> zadnje bridge mode
Staro 21.10.2007., 19:44   #42
pi3r
Postovi: 35
Ma probao sam sve sve sve.....i nista!Vjerojatno je problem u modemu. Jos cu ga samo pokusat u sebe na linuxu testirat tako da budem 100% siguran da je modem u kvaru!
Hvala na ulozenom trudu za odgovore. Pozdrav!
Gigabyte DS3
Maxtor 200GB
Staro 22.10.2007., 13:29   #43
Postovi: 23,542
inače taj modem bi trebao raditi u bridge modu iako ga mnogi stavljaju u routing mode, . . .
Da? A zašto? Zato jer je T-Coma tako rekla?
Sam proizvođač ovaj uređaj zove i klasificira u grupu ADSL2+ Router - a (vidi prvu stranicu manuala). O razlozima zašto T-Coma forsira Bridge mode rada i na uređajima koji su nativno routeri sada ne bih jer bi bio off sa ponekim "povišenim" tonom . . .
Netko je pitao poviše, što znači "konfiguracija pješke"?.
To znači da se ne koristi wizzard (čarobnjak) nego se svi koraci konfiguriranja odrade manualno (pješke), a razlog je jer se dešava da čarobnjak svoj posao ne odradi kako treba i konekcija ne funkcionira.
Evo još jednom, premda isto postoji u Bibliji i još xyz postova, kako pješke podesiti ovaj uređaj u nativni Router mode rada.
Ukoliko imate više računala u mreži privremeno ih isključite (mislim na mrežni priključak) osim jednog sa kojeg vršite konfiguriranje uređaja.
Na računalu sa kojeg vršite konfiguriranje uređaja:
- izbrišite Cache IE browsera (delete cookies and files)
- podesite postavke mreže sa fiksnim IP - om i to:
IP=192.168.5
Subnet=255.255.255.0
Gateway=192.168.1.1
DNS1=195.29.150.3
DNS2=195.29.150.204
Otvorite web konfig routera kroz IE kucajući u URL polje: http://192.168.1.1 + Enter
Sada se treba otvoriti dialog box za unos pristupnog User - a i odgovarajuči Password.
Ako je uređaj originalno isporućen od D-Link - a onda su User/Pass: admin/admin
Ako je uređaj isporućen od T-Com - a onda su User/Pass: admin/0000
Nakon ulaska u web konfig možete "odraditi" wizzard da vam kasnije bude lakše:
- Odaberite vremensku zonu (GMT+1) + Next
- Odaberite PPPoE/PPPoA + Next
- Unesite vaš User name (nezaboravite ga unjeti cijelog sa @htnet-dsl završetkom tj. treba izgledati xxxxxxx@htnet-dsl)
- Unesite Password (oboje ste dobili na papiru od ugovora)
- VPI=0
- VCI=33
- Connection Type=PPPoE LLC + Next
- Pritisnite Restart i router će spremiti promjene i napraviti reboot.
Kada uređaj ponovo izađe na režim (ADSL led svjetli konstatno) ponovo otvorite web konfig. Sada odaberite (otvorite) Home - WAN karticu.
Tu se nalaze svi parametri vezani uz vašu internet vezu. Predlažem da sva polja u koja se parametar direktno unosi (npr. VPI) selektirate i doslovno prekucate potrebni parametar. Sada ću još jednom navesti ispravne parametre za Router mode:
- PVC: Pvc0 (najčešći izbor, a radi se o izboru br. virtuelne "konekcije"). Jedna napomena: Uređaj omogućuje do 8 (Pvc7) različitih "konekcija" pa tako možete u Pvc1 postaviti konfiguraciju za Bridge mode i uređaj će raditi sa oba tipa konekcije ali naravno ne u isto vrijeme jer ste sa Pvc0 već ulogirani kod provajdera. Ako napravite disconect kroz web konfig onda će PPPoE Dial-Up sa računala a preko ispravno konfiguriranog Pvc1 ostvariti konekciju.
- VPI=0
- VCI=33
- Virtual Circuit=Enabled
- WAN Setting=PPPoE/PPPoA
- User name i Password vidi poviše
- MTU=Ostavite default 1400
- MRU=Ostavite default 1492
- Default Route=Enabled
- NAT=Enabled
- Firewall=Enabled
- IP Control=Dynamic IP
- Način konektiranja
a) Always On - ako želite biti stalno konektirani
b) Connection on Demand - ako se želite spajati po potrebi tj. kada neki program zatraži spoj sa Internetom isti će biti ostvaren. Sa ovom opcijom se postavlja i vrijeme neaktivnosti nakon kojeg će se router sam zatvoriti konekciju (vidi polje do), preporuka 30
- Service Category=UBR
Na kraju ovog niza pritisnite Apply. Da bi router zapamtio vaše postavke (a to je ono šta wizzard ne odradi kako treba) sada otvorite Tools - System karticu
Tu pritisnite botun Save and Reboot
Sada će se uređaj ponovo restartat i kada izađe na režim možete isprobati da li Internet funkcionira ok. Sada otvorite web konfig i provjerite / podesite:
- Tools - Time kartica - Odaberite način kako će router vršiti sinhronizaciju datuma / sata. Predlažem Automatic ili manualan unos url - a SNTP servera + Apply
- Home - DNS kartica - Unesite za Preferred DNS Server=195.29.150.3 i Alternative DNS Server=195.29.150.204 + Apply
- Home - DHCP - Uključite DHCP Server ako želite na računalima imati mrežne postavke po idiot automatic principu. Čak i tada u nekim slučajevima na računalima treba unjeti Gateway i DNS.
Na ovoj stranici ujedno određujete raspoloživ opseg IP adresa.
Iza svega nezaboravite ponovo Save and Reboot botun na Tools - System kartici.
Staro 22.10.2007., 16:32   #44
Serafian
D&D
Serafian's Avatar
Postovi: 156
ja nisam nikad reko da se neda složiti u routing modu, osobno mislim da je glupo postavljat ga u bridge, ja sam samo reko t-comovu preporuku,
oni kažu da su ga kao testirali u routing načinu rada ali da nije radio kako treba pa ga zato i prodaju kao modem a ne kao router i zato ne drže podršku za d-linka u routing modu
e da, dobro objašnjenje
Staro 16.11.2007., 04:31   #45
zobla13
Lokacija: Zagreb, Hrvatska
Postovi: 7
sve sam napravio kako je nikky napisala u uputama
i kad se idem spojit jkavlja mi gresku "Connecting through WAN Miniport (PPPOE) ..."
"Greska 678: The remote computer did not respond."
sta bi trebao sad napreavit
zobla13 je offline   Reply With Quote
Staro 16.11.2007., 09:53   #46
Postovi: 23,542
Autor zobla13 Pregled postova
Još nisam postao (la) ona ili bi trebao, nisam sasvim siguran
kad se idem spojit jkavlja mi gresku "Connecting through WAN Miniport (PPPOE) ...", "Greska 678: The remote computer did not respond.", sta bi trebao sad napreavit
Provjeri:
- dali je router linija ok spojena (vidi sliku u Sticky - ju),
- na routeru ADSL led svijetli stalno (ne da trepće stalno),
- u postavkama routera ispravno unešane (VPI, VCI, . . .),
- u postavkama routera ispravno unešani user name i password (xxxxxxx@htnet-dsl / pasword - vidi ugovor).
Za kraj napomena, kada po opisanom postupku podesiš router onda se više ne koristi PPPoE Dial-Up na računalu jer taj posao router odrađuje sam, samo pokreneš IE ili FF i trebaš imati pristup internetu.
Staro 30.12.2007., 14:52   #47
danvari
danvari's Avatar
Lokacija: Pregrada, Hr. Zagorje
Postovi: 54
Provjeri:
Instalirao sam ovaj router, cijelo vrijeme mi lampica od ADSL-a trepće. Di je problem?
HP Pavilion dv6-6057ef; dv2
danvari je offline   Reply With Quote
Staro 30.12.2007., 15:12   #48
Joke
N00B
Joke's Avatar
Postovi: 3,886
Autor danvari Pregled postova
Je li downloadas nesto s neta?
Staro 30.12.2007., 19:49   #49
danvari
danvari's Avatar
Postovi: 54
Autor Olymp Pregled postova
Ne, nije uopce problem bio u tome. Optički kabel do kuće u kojoj sam to radil dug je 7800 metara, a na toj udaljenosti adsl ne funkcionira.
Staro 31.12.2007., 08:08   #50
Xan
networking wannabe guru
Xan's Avatar
Datum registracije: Sep 2002
Postovi: 1,001
e da, od nedavno T-Com i službeno podržava D-Linka u router modeu, znaci mozete dobit tehničku podršku oko toga ako nazovete njihovu SZK
Quotation from the Bhagavad Gita famously quoted by J. Robert Oppenheimer upon witnessing the detonation of the first atomic bomb.
Also quoted numerous times by overly melodramatic players of Unreal Tournament upon detonation of the Redeemer weapon.
"Now I have become death, the destroyer of worlds who has come to annihilate everyone."
Xan je offline   Reply With Quote
Staro 30.07.2008., 12:59   #51
Rakun
Lokacija: Varazdin
Postovi: 3
Pozdrav. Postavio sam d-link u roter mod po uputama koje sam ovdje procitao i internet radi. Ali... konstantno mi puca veza, vec nakon nekoliko minuta. Kad stavim repair connection windows popravi vezu i net dalje radi. Modem je prije radio u bridge modu i veza nije pucala. Zbog cega mi puca veza??!
Btw. radio sam po ovom tutorijalu:
1. U internet explorer upsiati http://192.168.1.1, ako se ne pojavi kućica za prijavu otići na network connections - local area connection properties - Internet protocol(TPC/IP) properties i namjestiti da se automatski obtaina IP adresa.
2. Nakon što se pojavi kučica za prijavu pod username upisati: admin, a pod lozinku: 0000. Nakon što se pojavi glavni izbornik ići na Run wizard - Next - Odabrati vremesku zonu - Odabrati PPPoE/ konfiguraciju - Upisati username i lozinku koju ste dobili od T-coma ili nekog drugog internet providera, u polje VPI upisati 0, a u polje VCI upisati 33, connection type je PPPoELLC. Nakon toga otići na restart. Nakon što se restartira otići pod Tools - System - Save and rebot.
3. U glavnom izborniku izabrati Home - WAN - provjeriti sva polja, za connection setting izabrati always on, ako želite da vam računalo bude stalno na netu čim ga upalite.
4. Otići pod DHCP - DHCP server (starting IP 192.168.1.2 - Ending IP 192.168.1.254)
5. Otići pod DNS - DNS selection - Use user discovered DNS server only, user configuration:
Prefered DNS server: 192.29.150.205
Alternate DNS server: 192.29.150.204
6. Otići pod Advanced - uPnP - omogući uPnP - Pvc0
7. Na kraju podešavanja još jedamput otići na Tools - System - Save and rebot.
8. Otići pod network connections - Local area connection properties - Internet protocol(TPC/IP) properties - Upisati slijedeće:
IP: izaberi od 192.168.1.2 - 192.168.1.254
Subnet mask: 255.255.255.0
Default Gateway: 192.168.1.1
Preferd DNS server: 195.29.150.3
Alternate DNS server: 195.29.150.4
OK
Rakun je offline   Reply With Quote
Staro 30.07.2008., 13:30   #52
Postovi: 23,542
Jedina promjena u međuvremenu je vezana za DNS - ove. 195.29.150.3 još uvjek radi a kao Alternativu postavi 195.29.149.196 i na kompu i u routeru.
Ovo nije "glavni" razlog pucanja veze. Ako koristiš p2p programe tu leži razlog pucanja.
Pretraži stare odgovore kako to rješit.
Staro 30.07.2008., 13:40   #53
Rakun
Lokacija: Varazdin
Postovi: 3
Moguce je da je problem u dns-u jer kad windows popravlja vezu ponovo se spaja na dns server. I prije sam koristio p2p, ali veza nije pucala tako da mislim da nije to.
Staro 01.08.2008., 15:43   #54
sarma
Datum registracije: Aug 2008
Lokacija: mars
Postovi: 1
Autor Rakun Pregled postova
Mislim da nije stvar u DNSu. Imam identičnu situaciju. Nakon "rušenja" windowsa,prebacio sam modem (D-Link DSL 584T) u router mode(iz bridge moda koji mi je složio serviser iz T-Coma).
Postavke sam uspoređivao s ovima na forumu i identične su. Isprobao sam sa starim T-comovim DNSovima(195.29.150.3 i 195.29.150.4) i novima(195.29.150.205 i 195.29.150.204)... Sa starim DNSovima mi je veza pucala svakih 15 minuta i jedino sam mogao ući u setup od modema i u statusu prekinuti vezu i ponovno se spojiti. Ista je stvar i sa novijim DNSom, al s njim veza pukne nakon 25 minuta-pol sata(a ponekad zna i dulje)...
Napominjem da su mi Windowsi XP skroz friško instalirani i jedina stvar koju sam promjenio je u LAN postavkama; u TCP/IP Properties sam umjesto Obtain IP i DNS upisao slijedeće parametre:
IP address: 192.168.1.2
Default gateway: 192.168.1.1
ZA DNS server:
primarni: 195.29.150.205
alternativni: 195.29.150.204
E sad, internet stvarno fino šljaka... al samo kratko, a na ovaj način se reconnectirati je stvarno gnjavaža!
Molim vas pomozite, jer ću poludit
sarma je offline   Reply With Quote
Staro 01.08.2008., 16:12   #55
Joke
N00B
Joke's Avatar
Postovi: 3,886
Receno je vec dosta puta 584-T od t-coma ne sljaka dobro inace s njihovim FW..A njabolje ga je drzati u bridge mode!
IE6
Linux is Not Windows
Staro 01.08.2008., 23:04   #56
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ja apsolutno nikakvih problema s njim nisam primjetio, isto mogu reći za ozloglašenu Kasdu koju sam imao (osim kaj je krepala nakon oko 2g ali to je sad manje bitno) prema tome možda je problem u korisnicima ili mreži a ne routerima...
Have a nice day...
Staro 02.08.2008., 14:43   #57
d0X
Kostolomac
d0X's Avatar
Postovi: 1,519
e zanima me nešto... ako ja koristim firewall program jel mogu onda isključit firewall u routeru?
d0X je online   Reply With Quote
Staro 02.08.2008., 15:42   #58
yedwy
yedwy's Avatar
Postovi: 6,956
Naravno da možeš, zapravo nigdje nepiše da moraš uopće i imati fw a ako pitaš koji je bolji to ovisi o tome što je na kompu instalirano...
Have a nice day...
Staro 02.08.2008., 18:39   #59
d0X
Kostolomac
d0X's Avatar
Postovi: 1,519
ma koristim od servera 2008 firewall, ne treba mi bolji. kad već nisam mogao neke funkcije iščupat pomoću vlitea, onda ću ih iskoristit
thnx
Staro 09.08.2008., 17:51   #60
_)K1lleR(_
_)K1lleR(_'s Avatar
Lokacija: earth
Postovi: 49
problem
D-link 584T je do jucer radio u router modu i nije bilo nikakvih problema. na njega imam spojen pc, laptop i maxtv. od jucer laptop opce vise ne moze na net ni ne vidim ga u mrezi, a maxtv ne radi(samo sa pc-om mogu na net sad). kad spojim laptop na router ona ledica se ugasi, a kad nije spojen ona svijetli. tak isto je i za maxtv. kad se s pc-om spojim na net router se svaki cas restarta i vec mi lagano ide na zivce. u cemu bi mogao biti problem??
_)K1lleR(_ je offline   Reply With Quote
