Staro 08.10.2007., 21:26   #241
Razer
Razer's Avatar
Postovi: 11,642
Autor TomRi Pregled postova
tamo nam sada slovenci žare i pale
Zasad
Staro 10.10.2007., 21:18   #242
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Kolika je razlika u buci između PLUS i obične?
Te, koja je razlika između: EK-FC8800 GTS - Ponikljan
Te
EK-FC8800 GTS - Acetal, te obične...???
MC
Staro 11.10.2007., 00:09   #243
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
plus je jača verzija od 18w dok je obična 10w. e sad dal je glasnija ja neznam. na netu su rekli da je, pa dal im vjerovati ili ne, neznam. običana se da modati u plus jednostavnim spojem dva kontakta(lemljenje). Tom ima navodno plus verziju i veli da je tiha tak da, nek ti on još to potvrdi.
Ponikljan ti je samo presvučen niklom ili je napravljen od nikla. Jedino različiti materjal.
Acetal to ti je umjesto pleksi pokrova na bloku nekakav crni polimer, zamjena je za metal. Evo na eng. pa čitajte.
Acetal, also known as polyacetal, polyoxymethylene (POM), or polyformaldehyde, is a high performance engineering polymer. Because of its high strength, modulus, and resistance to impact and fatigue, it is used as a weight-saving metal replacement. Acetal is subject to degradation in acid and base solutions and is not readily available in a flame-retardant grade. Acetal, first developed in the late 1950s, is available as a homopolymer (such as DuPont Delrin®) or copolymer (such as Ticona's Celcon®).
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 11.10.2007., 00:22   #244
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
uzmi obicnu pumpu, lako ju moddas u ovu Plus, a i ušparaš
ja sam bezveze uzeo tu i platio cca25€ vise kada je samo razlika u jednoj maloj žici
link: http://forum.pcekspert.com/showthrea...1&i#post812541
jos je najbolje staviti tu prekidac, pa ako clockas, onda da radi spoj i vrti na 18W,
a ako je na stock vratis prekidac na nulu, i onda da pumpa radi na 10W.
one razlike u blokovima: nickel i slicno su samo razlike u presvlaci (kao kada nesto pocincas recimo, ali ispod je jos uvijek bakar, kao i kod obicnoga bloka...)
a pokrov, delrin/acetal i to..
neki vele da je cvrsci od plexia, a i da ne dolazi do pucanja(crack) ako prejako zategnes.
jedini minus je taj sto nije proziran, pa ne mozes vidjeti stanje bloka, jel protok ok ili imas nekog smeca unutra...
a sada ti odluci jel cesto mijenjas nesto pa da te brine to da mozda plexi moze napuknuti...
ja sam par puta preslagivao sustav i nista nije bilo, iako je bio od plexia.
ma to valjda za one amere sto nemaju feelinga pa zatezu dokle ide, njima treba delrin, tako je bar Edvard rekao, oni to najvise kupuju
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 11.10.2007., 09:52   #245
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
TomRI, znaš šta bih ja volio...
Volio bih sjest s tobom na čevape ili cugu
Uzet olovku i papir u ruke (laptop - whatever)... i zapisati što mi sve treba u detalje, jer bi cijelo vodeno promjenio, a jedino ostavio hladnjak od Kandalfa.
Uzeo bih ama baš SVE novo, i to od ovog EKW... Pa da složimo detaljan popis, kako bih mogao ga stavit na temu (za nabavu, ak treba i ja bi rado išao z Vama po to).
Uz dijelove za Vodeno, promjenio bih SVIH 5kom 120mm ventilatora, kupio bih neke JAČE, a TIŠE, nije me briga za cijenu, samo da imaju veći ili isti protok, a da su tiši!
Palim se na tišinu, a hladnoću
To bi bila neka cifra od cca 2500kn, al bi barem bio sretan i miran
(btw: brijem da je moje vodeno procurilo jer sam prejako zategnul CPU blok, koji je od plexija)
MC
Staro 11.10.2007., 15:05   #246
TomRi
TomRi's Avatar
Postovi: 2,073
gle, nemoj ostavljati taj radijator od kandalfa kada vec sve mijenjas.
vidio si da ti mijenja boju tekucine(ono kada si otvorio topic 'antifriz' u ovome podforumu)
ako ides mijenjati komponente, ne trebas nista dalje traziti
imas slike i opis svega sto ti treba da si slozis u case u ovome topicu, od bloka,pumpe,rezervoara,radijatora...
i sve pase kao i originalno(radijator recimo, pogotovo za kandalfa, jer ima ona vratasca napred),
a to puno znaci, da sve imas u kucistu a ne okolo po podu/stolu...
Water cooled PC
Moj najveci MOD
Staro 11.10.2007., 20:53   #247
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
OK.
Original TTov je sljedećih dimenzija: Dimension of radiator : H 407 x W 120 x D 35 mm
Dali da uzmem:
Magicool Xtreme III - Dimensions: (L x W x H): 415 x 120 x 46mm
Magicool Pro III - Dimensions: (L x W x H): 393x 120 x 30mm
Mislim, oće li stat ovaj veći?
MC
Staro 11.10.2007., 21:06   #248
TomRi
TomRi's Avatar
Postovi: 2,073
nece, zato sam ja i uzeo onaj Pro3.
rekoh, tu imas popis svega sto ti treba, znas di toga ima za kupiti, provjereno radi, pa jednostavno ne mozes fulati...
Water cooled PC
Moj najveci MOD
Staro 12.10.2007., 11:00   #249
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Možete mi samo objasniti razliku, odnosno evo primjer:
Pumpa ima 2x 3/8 izlaz, a kad uzimam CPU block, radijator, i ostalo, dali moram kliknuti na 3/8 ID ili 8/10 screw in?
Šta je to?
MC
Staro 12.10.2007., 12:07   #250
TomRi
TomRi's Avatar
Postovi: 2,073
Autor Sa_Stilom Pregled postova
Šta je to?
1 inch = 2.54 centimeters
3/8 inch = najblize 10mm(9.52mm), unutarnji promjer cijevi,
dakle 10/12, 10/13, 10/14 (ove druge brojke su vanjski promjer i neka te ne brinu)
dakle nikako 8/10 jer to znaci da ti je unutarnji promjer 8mm
Water cooled PC
Moj najveci MOD
Staro 12.10.2007., 12:10   #251
Uber Gosu
FORD Fix Or Repair Daily
Uber Gosu's Avatar
Postovi: 872
3/8 incha = 10mm unutarnji promjer cijevi
?!? , mozda 20mm
@EDIT
aha 8/10 je u [mm], a losi su ti trgovci, prvo pretvore cole u inche (col je inch u opsegu dok je inch ravninska mjera), pa sad i mm mjesaju, njubare.
Uber Gosu je offline   Reply With Quote
Staro 12.10.2007., 12:13   #252
TomRi
TomRi's Avatar
Postovi: 2,073
Autor Uber Gosu Pregled postova
?!? , mozda 20mm
sto zelis reci?
da je 3/8 inch = 20mm ?
ili da je 8/10= 20mm, jer 8/10 znaci 8mm/10mm, a ne 8 desetina incha
jer mislis da zaista netko ima 2 cm unutarnji promjer crijeva u kompu?
pa vanjski jos 3mm po stijenci, i dodjes do 2.6 cm debelog crijeva.
bilo bi zanimljivo to zamotati, ne?
Water cooled PC
Moj najveci MOD
Staro 12.10.2007., 13:15   #253
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Po tome znači da ona moja košarica što sam ti slao na PM nije dobra? ili je?
To znači da trebam uzet sljedeće:
1. EK-Wave LGA775
- Colour Copper
- Fittings 3/8" ID
2. EK-FC8800 GTS - Nickel-Plated
- Fittings 3/8" ID
3. Magicool Pro III
- Fittings 3/8" ID
4. Laing 12V DDC-1T
- 2 x 3/8" hose connections
5. EK-Multioption RES 250 rev.2
- Fittings 3/8" ID
6. PVC tube 10?1,5mm
- PVC tube with 10mm (3/8") ID and 13mm OD.
Ako sam dobro shvatio onda bi ovo bilo to!?
MC
Staro 12.10.2007., 13:34   #254
Lord_Calidor
Extreme Air Cooler
Lord_Calidor's Avatar
Datum registracije: Sep 2004
Lokacija: Kastav & Rijeka
Postovi: 491
Fino si otvoris pejđ na slovencki i pogledas sve te cudne mjere u metrickim jedinicama (mm, kg, m3/h...).
---= The eternal mistake of mankind is to set up an attainable ideal =---
Lord_Calidor je offline   Reply With Quote
Staro 12.10.2007., 16:50   #255
TomRi
TomRi's Avatar
Postovi: 2,073
neplanski skocio do Cool-PC danas,
cura trebala nekaj uzeti u ljubljani pa poveo nju i frendicu a sebi usput uzeo par stvari za silent pc.
likovi su super, moze se dobiti racun na bilo koji iznos(umanjen 3 puta recimo) pa nema frke na granici, fino sve mozes pokazati skupa sa racunom i samo prodjes
uzeo sam onaj HR-03 ali plus verziju jer ima 6x heatpipe,
naspram obicne verzije sa 4x heatpipe koja se prodaje kod nas u hr (i to samo u jednom ducanu)
po reviewu online, to se koristi i za GTX i ultre, pa bi valjda trebalo biti dosta i za ovu....
malo sam skeptican jer nije kao EK waterblock full cover, ali vidjet cemo jel radi ok.
(ova ima prednost sto se moze montirati IZNAD graficke, pa ne zauzima PCI slotove, a i toplina prirodnije ide kroz heatpipe gore u dio sa 'rebrima')
a ova 2 kucista za diskove...
to bi trebalo vec tihog samsunga T166 dodatno utisati.
Water cooled PC
Moj najveci MOD
Staro 12.10.2007., 17:16   #256
NJUNJO_HR
NJUNJO_HR's Avatar
Postovi: 674
oče možda u EK-u napisati smanjeni račun?
i savjet na kolko da nam spusti račun dok pemo u ekspediciju Solvenija?
je 300kn ili 500kn po osobi bez da ti se upleće carina u život ?
EK-FC79 for GPU
& green tubes.
Loop:
H2O galerija
Lapping galerija
Staro 12.10.2007., 17:46   #257
TomRi
TomRi's Avatar
Postovi: 2,073
ne znam, jer sam ja ovo uzimao bez racuna (kada sam dobio popust)
No vjerojatno oni mogu napisati na racun sto zele...
A granica, carina... mislim da je oko 50€/osobi, tako je bar meni sada bio 'racun'
vjerujem da puno znaci to sto se ovaj cooler moze montirati ovako 'naopako', pa toplina fakat normalnije/lakse napusta komponentu,
a i bonus je da ostaje vise mjesta ispod grafe nego sa stock coolerom, kamoli sa nekim aftermarket...
evo novih temp, svi ventovi na oko 600-1000 rpm (silent dakle)
i to je to sto sam htio, tih i hladan PC u winsima, di i provede oko 99% vremena
CPU 20-25 C
GPU (8800!) 30-35 C
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 12.10.2007. u 20:30.
Staro 12.10.2007., 18:24   #258
Don
je gladan!
Don's Avatar
Postovi: 1,698
Kako ti se čini kučište za hdd?
Don je offline   Reply With Quote
Staro 12.10.2007., 18:48   #259
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Još uvijek čekam potvrdu, dali sam dobro shvatio 3/8 crijeva i 8/10 ...
MC
Staro 12.10.2007., 19:05   #260
TomRi
TomRi's Avatar
Postovi: 2,073
Autor Don Pregled postova
ma predobro je
tocno kako si rekao, hvala na preporuci.
hdd se ne cuje da radi uopce(a ja sam cjepidlaka po tom pitanju), a i hladjenje je adekvatno, jer ima one trake za prijenos topline, pa nije isti efekt kao da se hdd samo zatvori u neku kutiju sa spuzvom...
2 žrtve, Samsung T166 serija
dobro, vjerojatno da se unutra stavi neki prastari WD Caviar koji rošta za poludit, culo bi ga se sa 10cm blizine iako je unutra...
ali sa ovim samsung diskovima nema sanse da se ista cuje,
ma za te pare nevjerojatan ucinak
jesi, dobro si shvatio
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 16.10.2007. u 19:24.
Staro 12.10.2007., 19:11   #261
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
hmm, kažeš ove kutije za diskove rade kako treba? ne grije se disk pretjerano, a ne čuje se?
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 12.10.2007., 19:37   #262
dugixy1
Postovi: 577
tomi kolko vidim nemaš više vodeno, i druge komponente su tu,šta si sve prodao? i šta si uzeo ili misliš uzeti?
dugixy1 je offline   Reply With Quote
Staro 12.10.2007., 19:45   #263
Don
je gladan!
Don's Avatar
Postovi: 1,698
Autor Renesis Pregled postova
Grije se manje, a ne pretjerano.
Staro 12.10.2007., 19:53   #264
TomRi
TomRi's Avatar
Postovi: 2,073
Don to spomenuo u nekom topicu pa sam pitao za temp, buku i slicno..
i fakat je sve tocno, ne cuje se, a hladan disk... velim, za te pare predobro.
steta sto nema u Hr za kupiti
a isto tako nema ni onaj VGA cooler hr-03 plus, ali sto ces, za neke stvari se ocito mora ici 'van', nazalost
Autor dugixy1 Pregled postova
sve prodano u komadu, po vrlo povoljnoj cijeni (samo 4 znamenke, a to je bagatela)
Dao sam otplatu na godinu dana i to bez kamata, a to je prilika kakve nema u ducanima.
Ja i dalje vjerujem ljudima s foruma pa me valjda nece zeznuti lik.(nikada prije ga nisam ni vidio, kamoli poznavao)
A ovo sam sve novo uzeo,
imas gore sliku svih komponenti jos u kutijama. napisao sam i di sam kupio
najbolje sve novo kada se slaze, barem nema frke da nesto nece stimati(u vecini slucajeva je tako)
a mogao sam proci puno puno povoljnije da sam prodao dio komponenti na trznici i samo nadokupio ostatak za ovu konfu,
(recimo prodao sam ballistixe u konfi za sicu pa onda par dana kasnije kupio nove, a ista mema, dakle tu sam gubio,
pa onda prodao grafu rekorderku sa dodatnim waterblokom i 5 godina garom, d
a bi za iste novce par dana kasnije kupio samo stock grafu i to s 2 god gar.,
prica se nastavlja i na hdd i ostalo..pa vidis koji je to gubitak,
ali je barem gust sloziti sve novo- ravno iz kutije).
cijene vodenog da ni ne racunam, bolila bi me glava samo da se prisjetim novaca/truda koji je ulozen te koliko km sam presao da bi sve nabavio...
ali sto ces, odvojena prodaja bi mozda trajala mjesec-dva, a ovako sam sve obavio u jedan dan
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 12.10.2007. u 20:28.
Staro 12.10.2007., 19:58   #265
Don
je gladan!
Don's Avatar
Postovi: 1,698
Forum je bio štekao pa su obrisani postovi...
Staro 12.10.2007., 20:25   #266
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
TomRi, da sam znao da prodaješ, ja bi uzeo
No dobro, skupit ću par i ja malo po malo
MC
Staro 13.10.2007., 00:22   #267
Lord_Calidor
Extreme Air Cooler
Postovi: 491
Cestitke na izboru VGA coolera, ja sam svog nedavno prodao, jer nikako da skupim za grafu.
Lappaj i ispoliraj bazu HR trojke, iznenadio bis se kako je konkavna. Ovo je nakon cca. 20ak min smirglom gradacije 320:
Takodjer, nadam se da ga mislis aktivno hladiti? Pod full loadom ce se fino zaprziti, cak i u kejsu s dobrim airflowom (pogotovo u ovom tvom polozaju, iznad NBa i kraj CPU coolera).
Staro 21.10.2007., 22:09   #268
TomRi
TomRi's Avatar
Postovi: 2,073
evo opet sam malo kemijao oko typhoona, stavio drugi vent i izbrusio i polirao bazu
vidi se kako nije ravna (ima udubinu u sredini, a tamo bas treba imati najbolji kontakt sa CPU)
radio na staklu da bude potpuno ravna povrsina za brusenje...
novi G0 proc, pasta i baza typhoona________________silent eagle vents
temp na 3.6 GHz
uzeo i ovaj daljinski potenciometar i UPS
zanimljivo je da sam uspio naci neki relativno OK UPS za male pare-
(da drzi ovo napajanje/konfu skupa sa LCD-om ustekanim u UPS-inace mi nema smisla,
a ne dodje preko 1000 kn, vec samo 400- hg spot!)
probao sam vec par drugih prije ali su se odmah ugasili(overload),
a ovaj drzi 5 minuta(i previse da se komp stigne sigurno ugasiti)
mjereno pod full opterecenjem: prime na sve 4 jezgre i simultano ona rotirajuca 'kocka' u att toolsima da optereti grafu, pa eto nema sretnijega od mene.
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 22.10.2007. u 08:07.
Staro 21.10.2007., 22:16   #269
E4300
daj malo opiši ovaj proces poliranja! Kak si to radio? kojima papirom? kak si ga pričvrstio na stakloa? kolko vremenski? i to....planiram to uskoro napraviti na ST-u!
Staro 21.10.2007., 23:27   #270
TomRi
TomRi's Avatar
Postovi: 2,073
a radio sam 2h laganini uz TV...
treba dobro izravnati to da bi se preslo na poliranje uopce...
naravno, mozes i dulje od toga, ako ti se da i imas vremena
link iz nekog razloga ne radi uvijek: klik
ali evo kako doci tocno do te stranice di su upute...
evo malo raskapanja dvd prže...
krenulo odavde: klik
probat cu to upariti sa ovom stvarcicom koju sam nedavno nabavio
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 27.10.2007. u 01:36.
