#31 |
Re-Registered User
Postovi: 627
#32 |
Postovi: 23
Oho, pa to je poznata WD Caviar serija diskova Htio sam poludit sa tim diskom (isto WD2000JS), temperature od 49 C pa skroz tamo do 75 C. Kad ga ni Papst n2gme nije ohladio skužio sam da neš ne štima sa senzorom, a potvrda je došla iz WD-a: "The temperature being reported is false. We are aware of the problem and are working on a solution. Our apologies for the trouble this issue is casuing. We do not know if and when a utility will be available to fix this. The drive is not defective but the temperatures that the revision of the drive you are using report to software are incorrect If possible, try (once) to open the tower and put your hand on the drive when it is reporting a high temperature to make sure the drive is not hot. The drive reports 20 to 30 degrees C above the actual temperature. It is not a defective drive. These series of drives built between October 25th, 2005 and before mid-April 2006 have this issue. There is no upgrade utility option to fix this issue in the field. A factory calibration routine anomaly causes the drive to report temperature readings that are up to 20C higher than actual. Otherwise, the drives meet all of WD’s quality, reliability and compatibility standards." Disk je i sa isključenim ventom hladan na dodir, eventualno malo mlak, tako da svima vama koji imate te diskove investicija u ventove nije potrebna. Inače svaka čast WD tehničkoj službi kojoj je trebalo 45 min da odgovori... |
#33 |
Postovi: 4,190
#35 |
Lokacija: Bjelovar
Postovi: 30
budem makno floppy, i jošp moram stavit 1 vent da upuhuje u kučište, al ak je ovo istina onda neću ništa posebno radit... |
#36 |
Postovi: 23
Ventilator neće nikako škodit, ali velim nemaš nikakve potrebe za njim. Usred ljeta SpeedFan 4.27 pokazuje 75 C, ja sam se htio objesit. Otvorim komp, isprepipavam disk, on mlak i hladniji (na dodir) od Maxtora 30 GB koji javlja 31 C, i nalazi se iznad WD-a. |
#37 |
Postovi: 33,990
WD laže. Meni stalno pokazuje 56, a mlak je kao Barica koja ima 35. Jedan ventač ispred diska ne bi škodio.
#41 |
Lokacija: Munich
Postovi: 2,222
#45 |
Lokacija: na sombra
Postovi: 1,048
30-35 hitachi ![]() ![]() |
#46 |
overpowered
Postovi: 915
@Work HP Zbook15 @Home Acer 5020 |
#47 |
Lokacija: /
Postovi: 2,053
molim lijepo ljudi...btw. nije photoshop...nego samo dobra "ventilacija"... http://www.imagesforme.com/images/9758PHISSEN 01.jpg p.s. kopirati CIJELI link.... btw. obratite pozornost na to koje su komponente : lol2 : ("malko" se inače jače griju...).... |
#48 | |
Lokacija: n/a
Postovi: 6,128
#49 | |
Postovi: 20
ali sad nabavih 250KS i vruc je dosta...a nebi rekao da su i na toj seriji lazljivi senzori... ![]() temperature su mi bile bez venta u idlu od 45 do 50, a u loadu cak do 59...sad sam stavio da mi puse 92milimetarac i sad mi je u idleu oko 40 a kad je load ide do 54... |
#50 | |
Lokacija: sarajevo
Postovi: 25
pi...n dim u mene je temperatura hardiska stizala do 58 i to sve sa novokupljenom asus P5B plocom a prije toga sa svim istim ali sa foxconn p945 temperatura je bila hard diska 40 i mislim da je to normalno. nije samo hard disk bio vreo nego i juzni mst ICH8 onda tv tuner reklamirao u trgovini gdje sam kupio, prave me budalom- sve je po njihovom normalno tek kada sam izrezao bocnu stranicu kucista i ugradio vent 12 cm temperature su spale na evo sada 26 c Citiraj:
mislim da nije . ne moze biti manja od temoerature ambijenta, sobe u kojoj je racunar Zadnje izmijenjeno od: domy_os. 12.10.2007. u 16:55. |
#53 |
Torrent freek
Postovi: 3,947
Uf teme, iz povjesti ![]() U mene su Seagate 250 i Maxtor 120 u jednom kavezu, ispred njih je 80 mm ventilator na 12V. Ljeti im je load nekih 40-45 °C, a zimi padne na 30-ak ![]()
#54 |
Lokacija: Munich
Postovi: 2,222
dosta stara tema,al da nemoram svoju novu kad vec owa postoji... skontao sam da imam spuzve i tako sam malo natrpao oko harda (nikako hladenje nisam metnuo),temp je 40 sa otvorenim cesom,racunam jos najmanje 5 c gore kad se zatvori... znam da nije dobro,a oce otapnit ako mu temp bude nesto malo manje od 45c? fala |
#55 | |
freak
Postovi: 2,688
#56 |
Premium moderator
Postovi: 4,600
__________________ |
#57 | |
Postovi: 4,069
#58 |
Lokacija: Munich
Postovi: 2,222
fortron 350pnf,vent na procu box (x2 4000),(prvom prilikom ide sonic),jedan vent na 700rpm što puše po grafulji. komp sad radi 2-3h,zatvoreno sve seagate je na 42. ![]() ove spužvice izgledaju smijesno (gore je jos jedna),ali sluze.naprijed sam puko komad sperploce i također spuzva. kontao sam okrenuti hdd od ovoga kako je sad i da jedan vent iznutra casea puse na 500 rpm po njemu(ne bi odnikuda vukao ladan zrak),neznam jel bi to sta skinulo temp? cak mislim da nema potrebe... |
#59 |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Imao taj vent ispred HDD-a friški zrak ili tjerao samo onaj unutar kučišta - HDD će biti svakako hladniji. Naravno, sa friškim zrakom bi bile malo niže temperature (ali tu govorimo o 2-3°C što je zanemarivo). Osobno imam 80mm ispred HDD-a, nema dovod friškog zraka, a HDD je opet na 32-33°C. |
#60 |
Lokacija: negdje
Postovi: 1,796
Koliku temp može podnjeti hitachi? Imam 2 kom od 160gb i penju se na 50 do 52 °C. |
