Datum registracije: Aug 2003
Postovi: 3,193
SpywareBlaster doesn't scan and clean for spyware - it prevents it from ever being installed. By setting a "kill bit" for spyware ActiveX controls, SpywareBlaster can prevent the installation of any spyware ActiveX controls from a webpage. It does this while not interfering with "friendly" ActiveX controls - so your browser can work correctly and you can have peace of mind! You won't get any more annoying "Yes/No" boxes popped up, asking you to install a spyware ActiveX control (which can increasingly be found in pop-up ads!). In fact, Internet Explorer will never even download or run the spyware ActiveX control! In addition, SpywareBlaster can prevent many of these spyware ActiveX controls from running, even if they are already installed on your system. Link ![]()
m e m b e r
Lokacija: Zagreb, Črnomerec
Postovi: 446
super programčić, imaš ![]()
#3 | |
Datum registracije: Dec 2003
Postovi: 823
Re: Spyware Blaster
manoa,akadui Active X mada mada Spyware blaster gara hazmeo otonyi oyshi dezne Active X korenna kodasai.Mada,mada Active X dezne - atamoro oshtee imass.Tu tsu gatai tai sun ga "Yes/No" dinneo midjikotowa.Dezne Active X (tosuzende sigga kinkishhadai sedes!).Watchidawa Internet Explorer akadui gyotsu noadi daikosho Active X dezne! Etendes ! Taff Spyware blaster tabe te mada mass ne.Igiri su dezne Active X konoko hakko,kasidasi tasidasi korenna kodasaii !
Ekspert iz sjene ...
Lokacija: New Eden
Postovi: 3,801
Ma krasan kurac ..... Prvo nakon instalacije mi je hijackao web browser na neku tam lijevu stranicu kao home. - ako promijeniš sruši se IE/Opera i ponovo ostaje isto. Ako probaš skinuti Ad aware ili nešto slično - sruši se IE/Opera Ako probaš na Yahoo/Google potražiti Adaware isl - sruši IE/Operu Ekipa - nemojte to stavljat, jerbo je to mene koštalo reinstala win-a ![]() |
Junior Member
Datum registracije: May 2003
Postovi: 3,205
kaj te briga, barem imas najfriskije windoze na forumu ![]()
__________________ |
Lokacija: ZaGReB
Postovi: 406
Paske pa kaj je to tebi reinstall? ![]()
Intel P4 1.8 Mhz ASUS P4S533-E SiS 645DX 2 x 256MB DDR333 Samsung HERCULES ATI Radeon 9800SE AIW 128 MB HDD Seagate Barracuda 60 & 80 GB NEC DVD RW+/-ND-2500 PSU Aopen 300W Monitor EIZO 19" Flexscan Microsoft IntelliMouse Optical CoolerMaster Aerogate II CoolerMaster Cool Drive 3 CoolerMaster 2 x 80mm vent LED Blue Papst 120mm vent SkyStar 2 Case InWin X710 Black |
#8 | |
Datum registracije: Sep 2002
Postovi: 2,721
BTW Mislim da si samo trebao skinuti sa drugog kompa Hijackthis, a ako to ne bi pomoglo, onda CWShreder |
Datum registracije: Oct 2001
Lokacija: Enterprise bridge
Postovi: 285
Ne znam kaj se vama dogodilo, ali Spywareblaster je genijalan program i ja ga koristim vec par godina bez ikakvih problema:clap:
Ubuntu 8.10 cpu Intel Q6600 @3GHz (333x9) w/Scythe MINE Rev.B - 29C idle mbo Gigabyte P35-DS3 ram 8GB Kingston DDR2 667MHz gpu Asus EN9600GT hdd 2xWD3200AAKS - RAID1 case Chieftec BX-03B-B-B psu Fortron BS 400W |
Lokacija: ZaGReB
Postovi: 406
Pa objasni narodu onda kako se upravlja! ![]()
Magister Mundi sum!
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
Kod mene isto dela normalno , nič se ne ruši ( a moji windowzi se voliju rušiti ) , home page mi je ista ostala , i sve dela normalno , a niti zone alarm nič ne prijavljuje da bi taj program dlelal nekaj treeče mjesto ovoga čemu je namjenjen
#13 | |
Postovi: 3,193
![]() Program sprecava one activex controle koje mu se nalaze u bazi, a pri tom ne mora ni raditi. Pokrenes, on banna ono kaj mu pase i to je to. OK ga je tu i tamo updateat. BTW viruse saljem samo potpunim neznancima ![]() ![]()
