#211 | |
the luda ribetna
Postovi: 3,952
tebi se svida sve sto je u plocastom obliku sjajne boje dimenzijama < od 300mm^2 ![]() ma pocelo je opet klokanje...sad vise nije ram,grafa,cpu...(to je postalo uobicajno) sada su u modi chipseti |
#212 |
nautic expert
Lokacija: Rijeka-Opatija, negdje između
Postovi: 1,386
sve je to fino i lijepo, ali "in real life" ovaj p4 630 kojeg ja imam je još uvijek dovoljno brz, osim u testovima... ili ako netko puno radi audio-video obradu... neki dan sam uboo e2160, nisam niti digao windowse, odmah sam ga digao na 3ghz, sa defaultnih 1.8... probao igranje, izvrtio par benchmarka. nije me oduševio po ničemu, osim po nezagrijavanju. gad na 3 gige u idleu stoji na 22°, nakon 2 sata igranja nekih dođe na 35° pod bt vx@1200 okrtaja... |
#213 |
Postovi: 7,568
DFI i Gigabyte X38 ploče na Computexu
DFI will be showcasing their LANPARTY X38-T2R board over at Computex next week along with their LP RD790-M2R board. Both boards are the fruit of labor of two dedicated and top-notch DFI engineers; Oskar and Jarry. The X38 chipset will be able to support DDR2 as well although Intel did not list that down officially on their roadmap. Amid sky high prices of the DDR3 memories currently, it seems it is a logical choice to stick to the much cheaper DDR2 memories. Of course, the LANPARTY X38-T3R board that supports DDR3 memories will come later. LANPARTY X38-T2R/T3R board supports 1333FSB Core 2 Duo and Quad processors, two x16 PCIe slots for dual graphics + one x4 for physical, 8-Phase Digital PWM, special heatpipe cooling for PWM, MCH and ICH. ![]() EDIT: Gigabyte GA-X38T-DQ6 ![]() Izvor: VR-Zone i OCWorkbench Zadnje izmijenjeno od: McG. 04.06.2007. u 16:09. |
#214 | |
Lokacija: n/a
Postovi: 6,128
#216 |
Lokacija: n/a
Postovi: 6,128
#217 |
Postovi: 11,642
Al zato je tu još good ol' floppy konektor ![]() Hm, malo glupo pitanje, pa nije valjda da će NB i SB dolaziti bez pasivaca na sebi ![]() EDIT: skužih da će dolaziti sa heatpipe hlađenjem ![]() |
#218 |
Lokacija: Varaždin/Zagreb
Postovi: 1,846
#221 |
Lokacija: PcEkspert forum
Postovi: 554
Intel će pokušati skrenuti pažnju sa najavom Core 2 Duo/Quad 6850 i ostalim FSB 333 CPU-ovima. Najaviće ih danas a ploče koje ih podržavaju su već izašle. Ovime će se dobiti nešto dodatnih performansi unutar računara ali to je sve. U isto vrijeme Intel će sniziti cijene X6800 i X6700 koje podržavaju samo FSB266. Buka počinje od danas!
Bez linkova u sigu... |
#222 | |
Postovi: 7,568
X38 ploče na Computexu i demonstracija Penryn procesora
The majority of the big players had X38 boards on display – not all were complete as the actual launch is not till September. Abit, Asus, Foxconn i MSI ploče bazirane na X38 chipsetu ![]() ![]() ![]() ![]() EDIT: This morning at Computex, Intel held a very small and private tech session that was aimed at showing off what a pair of their upcoming 45nm Penryn processors could do in their famed V8 test system that we first showed you back at the Consumer Electronics Show earlier this year. Just a couple months ago at the Beijing Intel Developers Forum, Intel let the media benchmark a single 3.33GHz Penryn processor and we found it to be a monster. It seems that Intel was trying to bury the hatchet firmly in AMD's back and they might have succeeded in their mission this morning. Citiraj:
![]() ![]() Izvor: TweakTown i Legit Reviews Zadnje izmijenjeno od: McG. 07.06.2007. u 17:51. Razlog: Nadopuna posta |
#223 | |
Postovi: 7,568
Detalji i specifikacije novih SiS chipseta
SiS plans to unleash a new family of single-chip and dual-chip chipsets for Intel Penryn dual and quad-core processors next year. The single-chip family consists of the SiS 680-series, in five different variants. SiS plans to cater the 680-series towards performance, mainstream and entry-level market segments. Citiraj:
Izvor: DailyTech |
#224 |
Postovi: 7,568
Cijene su iz Ve-mila, nisam videl da ih ima i ostalim dućanima, a nabava baca nebuloze za laptope. |
#225 |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,765
#226 |
Lokacija: Mostar
Postovi: 68
Ma preseravaju sa ovim c2d procesorima ali et samo da im je zaradit na jadnom narodu ![]() |
#227 |
Spiderpig
Postovi: 2,043
vjerovatno zarađuju dosta love ali mislim da imaju malo previše procesora koji se slabo uzimaju. Recimo sada 6400,6300,E4400,E2140(20-30 jeftini od E2160),E6700 i sad još kad izađu E6x50.... imat će dosta toga viška |
#228 |
Lokacija: Vz - Zg
Postovi: 2,930
pa da, ali bi 6x00 vjerojatno trebali otici u povjest uskoro, a ovo ostalo je ok da ostane, 2 varijante low end dc procesora i 2 varijante high end proceva + celeron. situacija je slicna kao sa pentiumom 5xy, 6xy, 8xy i 9xy, a u isto vrijeme i celici su se prodavali s 256 i 512kb cache-a, znaci 6 vrsta procesora je cak bilo u intelovoj ponudi do nedavno..
#230 |
Postovi: 7,568
Quad-Core Yorkfield i E4600 dodani na roadmap
Izvor: DailyTech |
#231 |
Postovi: 7,568
Novi desktop i mobile procesori i nove cijene
Intel plans to continue the cheap Core 2 E4000 series with a higher speed E4600 (2.4Ghz) processor in Q4 this year while its counterparts, E4500 (2.2Ghz) and E4400 (2.0Ghz) will be launched on Jul 22nd with a price tag of $133 and $113 respectively. E4600 will take over the E4500 pricing in Q4 while the latter will have a price cut to $113. Intel plans to lower the mobile processors pricing and introduce some new processors on Sept 2nd. On this date, 7 new processors will be launched and they are X7900, T7800, T7250, L7700, U2200, U2100, 550. ![]() ![]() Izvor: VR-Zone |
#232 |
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Novosti od Intela
Kraj za postojeće Core 2 procesore ![]() Neki proizvođači matičnih ploča za Intelove LGA775 procesore su najavili da Intel planira do kraja godine prestati proizvoditi većinu svojih sadašnjih Core 2 procesora, tj. zamijeniti ih nadolazećima. Naime, kako će za točno mjesec dana Intel na tržište plasirati svoje prve procesore koji će raditi na taktu FSB-a od 1333 MHz, oni bi trebali iz prodaje istisnuti sadašnje procesore koji rade na taktu FSB-a od 1066 MHz. Procesori koji će se pojaviti 22. srpnja su E6850 frekvencije 3 GHz, E6750 (2.66 GHz) i E6550 (2.33 GHz). Nešto poslije Intel će plasirati i četverojezgreni QX6850. Svi navedeni procesori će podržavati postojeće Intelove tehnologije Virtualisation, SpeedStep i EM64. Procesorima E6300, E6320, E6420, E6600 i E6700 koji rade na taktu FSB-a od 1066 MHz će Intel na isti dan spustiti cijenu, a planira ih u potpunosti prestati proizvoditi do kraja godine. To će također biti kraj za trenutnu Intelovu desktop perjanicu Core 2 Extreme X6800 kao i za Pentium D procesore. Osim ovih procesora, Intel će također već u kolovozu prestati proizvoditi preostale, sad već prilično zastarjele, Pentium 4 procesore, dok će rujan biti kraj za QX6700. Nadam se da nisam pogrješio ovo sam pročitao na stranici BUG-a i mislim da je vrlo interesantno za buduče korisnike i kupce Intela ako postoji več ovakva informacija na PCE molim moderatore da obrišu i još se jednom ispričavam. |
#236 |
Postovi: 7,568
#237 |
Lokacija: n/a
Postovi: 6,128
#238 |
Spiderpig
Postovi: 2,043
#239 |
Postovi: 11,642
#240 |
Postovi: 993
ak neki bude oko 1.5k moj je ![]() |
