Spužva Bob Skockani.. :XD
Postovi: 1,685
DVD format - Video_ts -->zvuk 'van u mp3
Dakle kako čim jednostavnije dobiti zvuk iz Video_Ts formata. Koji konverter/dekonverter koristiti i šta/kako napraviti,valjda nije komplicirano..? ![]() Zanima me jer koncert želim prebaciti na običan cd,dakle .wav ili .mp3... ![]() Hvala. ![]()
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm Gigabyte GA-MA78G-DS3H @F4 Mushkin Redline @1000Mhz 5-5-5 XFX 9600GSO @680/1700 || 2000Mhz Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD |
Postovi: 1,685
Dakle jel ima netko ideju kako se iz *.vob vadi zvuk van i baca u mp3... ![]() Ako nema nitko ideje,recite fino neznamo ili to se ne može,a ne mi ovako sabotirati thread nepisanjem... ![]() ![]() ![]() Eh da,ako je problem oko bilo čega - a nebi smjeo biti - koncert je originalan,dobar je,i nadasve je legalan... ![]()
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm Gigabyte GA-MA78G-DS3H @F4 Mushkin Redline @1000Mhz 5-5-5 XFX 9600GSO @680/1700 || 2000Mhz Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD Zadnje izmijenjeno od: Ozy. 09.05.2007. u 17:32. |
Prečupavi mod
Postovi: 9,107
DVDdecrypter - za ripanje DVD2AVI - audio->wav RazorLame+Lame - wav->mp3 BeSweet - ac3->mp3 (ako imas AC3)
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
Datum registracije: Aug 2003
Postovi: 3,193
Strpljenja malo ![]() Vidi koliko ih ima. Koji god uzmeš, bit će dobar: http://www.google.com/search?q=dvd+a...ient=firefox-a Ako ti je bitno samo izbaciti zvuk u komadu (obično specijalizirani programi imaju opciju dijeljenja prema chapterima) onda možeš koristiti i DVD Decrypter: http://www.doom9.org/dvddec.htm (kod ripanja odabereš samo audio i kao mod staviš stream processing - demux)
Postovi: 1,685
Ma koristim i nače Dvd Decrypter te za kompresiju ddv2one i sl. programe. Ovaj put mi treba kako si i naveo sam da je po chapterima;odnosno da imam odjeljene sve trake toga koncerta,a ne da je sve u komadu. ![]() Dečki fala vam obojici;mislim da će i to dostajati jer nadam se da nisam totalni amater sa tim,ipak sam 'vadio filmove,a sad treba samo muziku,pa valjda će onda ići i to bez problema;naravno uz još puno brže ripanje kad slike nema i ne treba ni biti... ![]() ![]()
Postovi: 1,685
@Costa skida mi AC3 audio...e sad;kako to staviti na cd da "normalno" svira;odnosno baciti to u mp3... ![]() @SU: Ako ne uspijem pa idem preko ovog Dvd2Avi,valja i njega isprobat... ![]()
Postovi: 3,193
S ovim programom možeš pretvoriti ac3 u mp3 ili bolje u wav tako da ne izgubiš dodatno na kvaliteti kad već ideš raditi audio CD: http://dspguru.notrace.dk/ Ovaj program sam jednom koristio i pokazao se odličnim. U par klikova ripaš zvuk s DVD-a u koji god format želiš: http://www.castudio.org/dvdaudioextr...creenshots.php
Postovi: 1,685
Hvala,probat ću malo kasnije... ![]() SU - ovaj Dvd2Avi mi ne leži nikako;on radi i sliku i zvuk;a samo zvuk neznam sa njim skinut jer nisam stručan,a neda mi se 3 dana zujat po njemu da ga skužim... ![]() ![]() EDIT: SuperUnknown kolega,hvala i tebi na preporuci prijašnjoj za BeSweet,nisam odmah ni skontao da si mi ga već preporučio. ![]() Hvala još jednom i Costa-i. ![]()
Postovi: 1,685
@Costa - ovaj prvi program nema grafičko sučelje za korisnike,tako da komadne linije def. otpadaju... ![]() Sad skidam sa BeSweet i bacam omah u Mp3 jer mi kaže da za nekomprimirani PCM Wav treba 3300-injak MB... ![]() Pa ćemo vidjeti kako će ispasti.. ![]() Jedino šta nema mogućnosti cd-texta direktno da upisuje,ali nema ga otkuda ni upisati pa dobro,nisam to ni očekivao... No to ću ja ili ručno ili će ostati Track 1/2/3... ![]() EDIT : Ma i ovaj BeSweet nema konstantan bitrate...koliko zahebancije oko jednog dvd-a... ![]()
Postovi: 3,193
Link koji sam ti dao vodi do BeSweeta. Na stranici imaš i GUI za skinut. Ovdje imaš jednostavniji GUI od onog službenog: http://www.free-codecs.com/download/BeLight.htm Konstantni bitrate za mp3? Naravno da ima: http://www.imagesforme.com/images/9575besweet.png
Postovi: 1,685
Lame 1 i CBR-ka 128... ![]() Khmm,javim se kad nađem to u opcijama,ja imam onaj...aha,pa sad sam skužaj - ja koristim ovaj Dvd Audio Extractor v4.2.1 - on mi nema konstantan bitrate... Nisam se zezao sa BeSweet-om,vidio sam da ima GUI za skinut,ali nije mi se dalo ni to;ja ko' ljenivac samo gledam di može što jednostavnije i bezbolnije... ![]()
Postovi: 3,193
Morat ćeš duboko udahnuti prije nego nastaviš s ovim. Odluči se koji program koristiš i pogledaj ga malo bolje. CBR u DVD Audio Extractoru (v4.2.1): http://www.imagesforme.com/images/5709dvdae.png 1. Izabereš Custom settings 2. Isključiš Use VBR 3. Biraš bitrate CBR-a
Postovi: 1,685
Napravi'to sve... ![]() ![]() Ovaj mi nekako najjednostavniji jer sve sam napravi,jest da dugo traje,ali bar ne moram 2-3 programa koristiti... ![]()
