Postovi: 12,429
Kako nebi svaki drugi thread imao za temu ovo pitanje evo jedan odličan kalkulator pa provjerite što vama treba! http://web.aanet.com.au/SnooP/psucalc.php npr moja konfa (vidi SIG) ima ove zahtjeve Typical max sustained total power consumption while gaming (watts): 186 w Typical 12V combined amps while gaming: 13.4 A Recommended PSU wattage for generic brand PSU: 523 w Recommended 12V combined amps for generic brand PSU: 26.1 A Recommended PSU wattage for decent brand PSU: 299 w Recommended 12V combined amps for decent brand PSU: 20.5 A dakle trošim 186W i treba mi 13,4A na +12v preporuka je kvalitetno napajanje nazivne snage 299W i 20,5A na +12V P.S. molio bi da se ovo zakači ko sticky da ekipa ne traži ovo po podforumu ![]()
''Of all the things I've lost I miss my mind the most'' Mark Twain Zadnje izmijenjeno od: Wolverine. 20.03.2007. u 19:01. |
nautic expert
Lokacija: Rijeka-Opatija, negdje između
Postovi: 1,386
Typical max sustained total power consumption while gaming (watts):222 w Typical 12V combined amps while gaming:17.0 A Recommended PSU wattage for decent brand PSU: 342 w Recommended 12V combined amps for decent brand PSU: 24.5 A taman. ![]() dobar kalkulator. hvala. |
Postovi: 2,114
Typical max sustained total power consumption while gaming (watts) - 154 W Typical 12V combined amps while gaming - 11.2 A Recommended PSU wattage for decent brand PSU: 260 W Recommended 12V combined amps for decent brand PSU: 17.9 A |
Postovi: 436
zanimljivo-hvala
Recommended PSU wattage for generic brand PSU: 504 w Recommended 12V combined amps for generic brand PSU: 25.8 A Recommended PSU wattage for decent brand PSU: 287 w Recommended 12V combined amps for decent brand PSU: 20.1 A to je za konfig koj prikupljam a ne iz siga i bez overclockiranja: 8800gts, E6300, 2x1GM ddr2,1xhdd vrlo zanimljivo, baš ću vidjet da li će "spomena vrijedno napajanje" Enermax vrijedan tek 250kn napajati sve to; izgleda hoće ali...BFG 8800gts zahtjeva 28A@12V, a Enermax daje 23A. kad doznam javim ak može ovdje... nije sve tako jasno dok se ne proba... nije jasno ni tko je kriv ako izgori napajanje... i da li ću dobiti novo ako je pod garancijom... predlažem i da ovakve specifikacije ovdje dajemo i komentiramo koja kombinacija radi...
Postovi: 12,429
Neće ti se skurit napajanje nego ako je preslabo jednostavno će ti se komp gasiti ili će se sistem rušiti.
Postovi: 18,908
Za proc klokan na 4 GHz i grafu na taktove kao X1900XT kaže da mi treba 600 W decent brand napajanje, a meni radi na 380 W? Dobro, mema na grafi ne može raditi brzo kao na XT, ali GPU može. |
al se nekad dobro jelo...
Postovi: 3,312
Recommended PSU wattage for decent brand PSU: 210 w Vjerovatno bi radilo i na 150W, ali ne mogu naci tako slabo ;(
Zenfone 9 | Zephyrus M16 | HP Chromebook X2 | Tesla Model Y LR |
Postovi: 12,429
#10 | |
Premium moderator
Postovi: 4,600
![]() Za mog kaže sljedeće: Generic PSU 698 w Decent brand PSU 404 w A usprkos svemu, Ener snage 370W sve gura bez problema. Računica ovom kalkulatoru ne štima potpuno ![]() |
Postovi: 12,429
Kod njega je bad to kaj kalkulator izračuna samo potrošnju njegovog proca na preko 200W
Postovi: 1,606
još jedan PSU calculator: http://www.extreme.outervision.com/psucalculator.jsp |
Postovi: 18,908
I taj kaže da mi treba 600 W napajanje... Svi ti kalkulatori su malo glupi... ![]() |
Lokacija: Varaždin-Zagreb
Postovi: 76
a sve je u redu s tim kalkulatorima,ali realnost je sasvim nešto drugo... isto kao i sa 3dmarkom,ti izračuni su dobri samo za orijentaciju, ne treba bježat od kvalitetnog napajanja,no sve opet ovisi o izboru komponenti i za što je komp namijenjen,al većinom gledamo da izvučemo maximum a preduvjet za to je,naravno dobro napajanje, koje uvijek ima u rezervi barem 100w! |
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
ma sta ti radis da mi je znat, za ovaj prvi nisam siguran jer sam ga danas prvi put vidio ali s ovim drugim sam se prije dosta igrao i nikad nije pokazao 600W ni za kakvu bolesnu konfiguraciju koju sam slozio a kamoli za nesto tipa tvoje kante inace za moj prvi 207 W, drugi 247W. ovaj drugi vise vjerovatno zato sto sam Capacitor Aging stavio na 25%, ipak napajanje vec dugo moze legano kupovati alkohol ![]() |
#16 |
Postovi: 18,908
Računao sam i klokanje proca, a i grafe, bez toga nigdje... ![]() |
#17 |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,465
oho, vidi i greg je tu... pa pozdrav ![]() meni kaže oko 380... po mome fortronu, to je recimo istinito, jer siroti fortron puše jako vruće van ![]() |
#18 |
Postovi: 62
imam jedno pitanje a valjda spada pod ovu temu... pitanje je više teoretsko ali sve jedno... koja je najjača grafa koju bi mogao potjerat fortron 350 w pnf, ostatak konfiguracije asrock dual sata2, venice 3000, 2x 512 ddr 400, 1xhdd ibm 60gb, audigy se, skystar2, kworld dvb-t,1x dvd prža? jedino kroz neko vrijeme bi umjesto venice 3000 možda uzeo neki 3800x2 ako bi našao povoljno...dakle koja najjača grafa bi išla na to napajanje??? |
#19 | |
Postovi: 4,398
neg ti meni reci, jel tebi to rdae DVB-T i DVB-S u istom kompu? |
#20 | |
Postovi: 62
da, dvb-t i dvb-s rade najnormalnije, problem predstavlja kad uzmeš od techisata airstar (dvb-t) i skystar (dvb-s) kartice koje imaju iste drivere pa se kolju međusobno ali mislim da ima na netu i modificiranih drivera tako da se i to da srediti |
#21 |
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Potrošnja po calculatoru
Recommended PSU wattage for generic brand PSU:587W Recommended 12V combined amps for generic brand PSU:29.8A Recommended PSU wattage for decent brand PSU: 337W Recommended 12V combined amps for decent brand PSU:24.4A Ovo je na defaultnim postavkama bez clocka a kada namjestim da radi na 2.6 GHz onda je sljedeće: Recommended PSU wattage for generic brand PSU: 604W Recommended 12V combined amps for generic brand PSU:30.7A Recommended PSU wattage for decent brand PSU: 348W Recommended 12V combined amps for decent brand PSU:24.4A E sada me zanima po tome napajanje koje imam nije dostatno Fortron BS 500Wili nešto neštima ili moram promjeniti navedeno. Zanima me da li nešto nije uredu li moje napajanje nije dostatno da sve to opskrbi i napoji Fortron BS 500W jer ako nije moram uzeti nešto kvalitetnije.Već 2-3 dana komp mi se zna sam ugasiti bez nekog vidljivog razloga ništa neradim (samo net i malo igranje i odjednom kraššš) nakon 2-3 min upalim i sve normalno.Primjetio sam pad napona na mreži jer i sijalica zažmirka i komp se ugasi ali bi htjeo otkloniti mogučnost da je od napajanja komp je iz siga plus 2x120 ventilatora na kučištu. Molim savijet i prijedlog, hvala i pozdrav. Zadnje izmijenjeno od: ECHO. 04.05.2007. u 11:22. |
#22 |
Postovi: 12,429
daj malo uredi taj post ![]() pa sve si krivo odijelio Čuj za onu konfu bi nazivno BS500 trebao biti dosta no opet moraš znat da je on dosta slab na +12V rail-u tj ima samo 285W (cca 24A) dok ostala poštena 500W napajanja imaju i po 40A Tvoj Fortron bi to trebao moći gurati ali bi se dosta naprezao - to je zato kaj ti grafa puno struje ždere ![]()
#23 |
prcknedl
Postovi: 3,131
Nisam skuzio, dok si na kompu onda zazmirka lampica iz cista mira i komp se resetira? Taj fortron (kao ni ostali bluestormovi) nije toliko kvalitetan ko recimo PNF serija, no dovoljan je da ganja tvoju konfu. EDIT: Vidim iz osijeka si, mislim da rusenje ima veze s ovim... ![]() http://forum.pcekspert.com/showthread.php?t=68369 |
#24 |
Postovi: 2,354
Savijet oko napajanja
Sorry što je tako ispalo sve sam računao sa calculatorom i copy-paste tako da nisam ni gledao kako slažem samo sam pazio da brojke dobro upišem.Meni nije ništa zatreperilo ili nisam vidio jer kučište je pored stola i ima vrata.Rijetko gledam dolje samo kada koristim pržilice.Moguče da je to problem ali htjeo bi otkloniti mogučnost da je do napajanja jer sam nedavno promjenio grafu .Nadam se samo da sam dobro spojio.Komp se samo ugasio,palio sam ručno nakon par min. Izgleda da če biti potrebno kvalitetnije napajanje uzeti, poslao sam upit koje uzeti pronašao sam par pa ču vidjeti savijete 500-600 Kn malo je problem što u Osijeku i nema neki izbor, ali nije problem naručiti poštarina cca 50KN Pozdrav i hvala na savjetima. |
#25 |
She`s back...
Postovi: 983
Odličan topic, ne kužim zašto nije sticky... Imam par pitanja... Što znači ovaj boldani dio: Typical Gaming 12V1 draw If this exceeds 18A, a dual 12V rail psu probably won’t work - psu will shut down while gaming. The only solution is to buy a non dual 12V rail psu*. Zar su napajanja sa jednim railom opet "in"? A drugo pitanje je, ima li moj Hiper 480W Type R dovoljno soka za ganjanje x2 proca i 8800 GTS/GTX grafulje(nije da ih planiram kupiti te grafe, ali čisto informativno, možda jednom poludim)? Kako se dobije kombinirana snaga dva +12V raila? Može li se to izračunati ili je to poseban podatak koji bi trebao pribaviti proizvođač napajanja? Moji su, npr. 18A i 16A, a ispod njih piše 350W... |
#26 |
Ex-Gastarbajter
Postovi: 5,465
18A * 12V = 216W 16A * 12V = 192W a otkud su oni izvukli 350W ne zna ni dragi bog ![]() |
#27 |
prcknedl
Postovi: 3,131
Gle, jedan rail moze dati 18A ako je drugi slabo ili nikako opterecen. Drugi rail moze dat 16A ako bas i nema opterecenja na prvom. A kad opteretis oba dva, max sto ih mozes opteretit skupa je 350W. |
#28 | |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
)Ako piše da na +12V1 i +12V2 ima 18A odnosno 16A, a da ukupni +12V (znači +12V1 + 12V2) daju 350W onda kombiniranu jakost struje na +12V rail-ovima dobiješ preko: 350W / 12V = ~29.17A E sad se tih 29A može raspodijeliti na max. 18A na prvom rail-u i ostatak na drugom ili max. 16A na drugom, a sve ostalo na pravom ili neka sredina (14A i 15A po rail-u npr.). Standard kaže da nesmije biti preko 18A po rail-u, zato se rade napajanja sa više rail-ova etc. No, ovo boldano što si napisao bi značilo da kada bi npr. grafa vukla preko 18A (a da je grafa sama na rail-u ili čak gore, s nečime još skupa) da bi se onda napajanje gasilo (jer prelazi tih max. 18A po rail-u propisano standardom) te je tu onda preporuka da se kupi napajanje sa samo jednim rail-om koje daje npr. 40A na +12V. Kada gledaš, današnja najjača napajanja (tipa 1kW) - dosta njih ima jedan rail (sa ogromnih npr. 72A koje daju na +12V) (Primjer) |
#29 |
Postovi: 383
Typical max sustained total power consumption while gaming (watts) 290W Typical 12V combined amps while gaming 11.2 A Recommended PSU wattage for decent brand PSU: 424W Recommended 12V combined amps for decent brand PSU: 29.9 A a ja mislio da treba puno vise ![]()
#30 |
Postovi: 12,429
Ajde pročitajte ovo pa će sve bit jasnije ![]() http://forum.pcekspert.com/showthread.php?t=48485 btw taj standard koji Vuco spominje nije 18A već 20A tj 240VA, no Intel je (prvo započeo sa tim) a sad opet odkantao tu max 240VA normu tako da opet imamo napajanja sa jednim stravično jakim railom.
