					Postovi: 18,887
				Kingmax DDR2-667 512 MB, upozorenje
			Prije nekih pola godine sam kupio dva komada Kingmaxove DDR2-667 512 MB memorije i dobio ove module... Pakiranje: Prednja strana: Stražnja strana: Naljepnica: Kingmaxov (valjda copyright) chip i par BGA memorijskih chipova: Podaci iz SPD-a: Module Name Kingmax KLCC28F-A8KB5Serial Number NoneModule Size 512 MB (1 rank, 4 banks)Module Type Unbuffered DIMMMemory Type DDR2 SDRAMMemory Speed DDR2-667 (333 MHz)Module Width 64 bitModule Voltage SSTL 1.8Error Detection Method NoneRefresh Rate Reduced (7.8 us), Self-RefreshMemory Timings: @ 333 MHz -> 5-5-5-15 (CL-RCD-RP-RAS) / 20-35-3-5-3 (RC-RFC-RRD-WR-WTR) @ 266 MHz -> 4-4-4-12 (CL-RCD-RP-RAS) / 16-28-2-4-2 (RC-RFC-RRD-WR-WTR) @ 200 MHz -> 3-3-3-9 (CL-RCD-RP-RAS) / 12-21-2-3-2 (RC-RFC-RRD-WR-WTR)Memory Module Manufacturer: Company Name: Kingmax Inc.Product Information http://www.kingmax.com/product/products.htm Međutim, prije par dana sam odlučio kupiti još 1 GB zato što je došla Windows Vista, a tu su i igre koje traže sve više memorije za gladak rad. Dakle, kupio sam 2 x 512 MB na papiru iste memorije, ali sam dobio ovo... Pakiranje: Prednja strana: Stražnja strana: Naljepnica: BGA memorijski chipovi bez onog ljubičastog chipa u sredini (!): Podaci iz SPD-a: Module Name Nanya M2Y51264TU88A4B-3CSerial Number 8E141D05h (85791886)Manufacture Date Week 7 / 2007Module Size 512 MB (1 rank, 4 banks)Module Type Unbuffered DIMMMemory Type DDR2 SDRAMMemory Speed DDR2-667 (333 MHz)Module Width 64 bitModule Voltage SSTL 1.8Error Detection Method NoneRefresh Rate Reduced (7.8 us), Self-RefreshMemory Timings: @ 333 MHz -> 5-5-5-15 (CL-RCD-RP-RAS) / 20-35-3-5-3 (RC-RFC-RRD-WR-WTR) @ 266 MHz -> 4-4-4-12 (CL-RCD-RP-RAS) / 16-28-2-4-2 (RC-RFC-RRD-WR-WTR) @ 200 MHz -> 3-3-3-9 (CL-RCD-RP-RAS) / 12-21-2-3-2 (RC-RFC-RRD-WR-WTR)Memory Module Manufacturer: Company Name: Nanya Technology Corp.Product Information http://www.nanya.com/index.aspx Totalno sam zbunjen... Kao što se vidi iz usporedbe, razlika između starih i novih modula je u tom ljubičastom Kingmax chipu, boji PCB-a, podacima u SPD-u, a možete usporediti i rubove memorijskih chipova na oba PCB-a. Na chipovima koji se nalaze na plavom PCB-u postoji kao nekakav "srh" pri rubu samih chipova. Sad ne znam da li je to neka nova verzija ili lažna Kingmax memorija? Biti ili ne biti, pitanje je sad... Na netu, a ni na službenim Kingmaxovim stranicama nisam našao nikakve podatke o tom "novom" Kingmaxu. Rebrandirana Nanya memorije ili što već? Dok se gospoda iz Kingmaxa ne javi, htio bih vas samo upozoriti na ovo.  |
					Postovi: 851
		 wtf? Ja imam ove prve sam od GB, a ovo valjda novo izdanje il kaj. A radi dobro?
			 Prečupavi mod
					Postovi: 9,120
		 Zanimljivo, znam da su svojevremeno uveli taj crveni chip bas kao neka vrst zastite protiv krivotvorenja. Ovo sto si ti dobio mi je prilicno sumnjivo    Gdje si kupio tu memoriju?
	Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11  |
			 Ex-Gastarbajter
				Lokacija: Zagreb / Rijeka
					Postovi: 5,463
		 yep, kolko sam ja čitao, svi novi kingmaxi imaju taj čipić u sredini, baš protiv krivotvorenja...  Wolv, imaš kakav info? ![]()  |
		#6 | ||
					Postovi: 18,887
					Postovi: 236
		 Ma ne znam ni ja, jer sam si jako dobar s dečkima u Linksu, pa mi je tlaka tamo biti "oštar" i tražiti neku pravdu..... a opet s druge strane, toliko sam tamo nakupovao stvari za sebe i svoju ekipu, tak da sam u nedoumici.... jer što ako nemaju s modele s čipom..... valjda će mi zamijeniti za neku drugu robu...  |
					Postovi: 131
		 Isto iskustvo ali ddr memorija i hgspot  |
			 The All Seeing Eye
					Postovi: 1,103
		 Da se ubacim! Kupovao sam memoriju 1Gb Kingmax (667MHz) MARS prije 3 tjedna ili malo više (nisam 100% ziher)! Uglavnom, dobio sam ZELENU memoriju sa LJUBIČASTIM copy right chipom ali je memorija bila PAKIRANA kao na slici sa PLAVOM memorijom, znaći bila je pakirana u PROZIRNU kutiju! Bože... Ovaj post izgleda kao da imam tikove dok pišem ![]()  |
			 Pero_Snajper
					Postovi: 649
		 Vjerojatno "rebrandirana" nanya. Evo na Kingmaxovoj stranici se spominju neki njihovi ugovori jos iz kraja 2000. http://www.kingmax.com/about/about_milestone.htm Jos malo http://www.hardware.info/en-US/news/...ed_by_Kingmax/  |
					Postovi: 18,887
		0.13-->0.11 nanometer currently, means we can package the chip size smaller. 2. Kingmax cooperate with Nanya for the new chips DDR2 667 memory, the blue one. So some timing and SPD settings are different to the Green one, even the module appearance. 3. The packing for green one is first generation to the market, now we use new packing for our memory products afterward. Both of them are KINGMAX official products with lifetime warranty. For your reference. Regards Matt  |
				Dear Domy: Good day, this is Matt, FAE from KINGMAX. First of all, sorry for confusing you caused by KINGMAX DDR2 667 memory products. Just like you said, they came with different PCB color and red BGA chip. Let me explain it to you simply: 1. They are different chip size, because memory chips technology innovate continuously, from the early 0.35 nanometer to 0.18-->0.13-->0.11 nanometer currently, means we can package the chip size smaller. 2. Kingmax cooperate with Nanya for the new chips DDR2 667 memory, the blue one. So some timing and SPD settings are different to the Green one, even the module appearance. 3. The packing for green one is first generation to the market, now we use new packing for our memory products afterward. Both of them are KINGMAX official products with lifetime warranty. For your reference. Regards Matt  |
					Postovi: 507
		 Onda se čini sve jasno! Oba su originalni kingmax moduli....  |
			 Ex-Gastarbajter
					Postovi: 5,463
		 ajd dobro, iako mi nije jasno zašto su išli micat taj copyright čip kad su na sva vrata vikali za to...  |
			 dr. sc. tech. dipl. ing.
				Lokacija: Rijeka-Opatija
					Postovi: 3,164
		 Ah..odahnuo sam...jucer sam znaci ipak dobio origigi Kingmax  ![]()
	Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code:  |
		#16 |
			 The All Seeing Eye
					Postovi: 1,103
		 Koji od ta 2 je rađen na novoj tehnologiji (0,11nm)? Znaći nema brige, ne mogu se klati ili bilo kaj takvoga predpostavljam?  Planiram ići vrlo uskoro po još 1Gb memorije jer sad koštaju 485 kuna, ali bum ipak prvo pogledao da mi daju onaj sa ljubičastim cr čipom!  |
		#17 |
			 Udaram Ljude Za Pare
				Lokacija: BEHIND YOU
					Postovi: 835
		 Ja ne kužim čemu frka oko toga svega uopće ![]() Sta (upozorenje) da ljudi ne kupuju to iako nema nikakvih problema ![]()  |
		#18 |
			 Space Cadet
				Lokacija: Split<-->Vela Luka
					Postovi: 592
		 i sad, koja je razliak izmedju zelenih i plavih kingmaxa, (osim u boji :-) tj. koji se bolje clockaju ?
		#19 |
					Postovi: 236
		 "First of all, sorry for confusing you caused by KINGMAX DDR2 667 memory products. Just like you said, they came with different PCB color and red BGA chip."  Ali moj nema nikakav BGA chip na sebi, niti crveni niti ljubičasti, tako da mi to nije jasno, jer sam u listiću koji sam dobio sa memom pročitao da mora imati ljubičasti chip koji je potvrda orginalnosti Kingmaxa, a njega nema na PCB-u  |
		#20 |
					Postovi: 2,108
		#21 |
			 Prečupavi mod
					Postovi: 9,120
		#22 |
					Postovi: 236
		 Evo ja sam danas bio u Links-u i dečki su rekli "prošlo je više od osam dana od kupnje memorije, pa ćete morati otići u tvrtku Lost jer su oni nabavljači Kingmax-a za Hrvatsku". I dobro odem ja do Lost-a, kad tamo sve sami "genijalci". Javim se tamo na ulazu, a oni me upute u svoj servis. Ne volim blatiti nikoga, a pogotvo ne ljude koji ne trebaju neke stvari znati, ali dotični gospodin onako iz visoka pita u čemu je problem. Ja mu objasnim da na memi nema ljubičatog čipa koji potvrđuje orginalnost memorije, a on kaže da nikad nisu imali memorije sa ljubičastim čipovima, već samo sa crnim. I dok sam ja njemu uspio obasniti o čemu je tu riječ, on kaže da su možda jednom imali takvu seriju, ali je to bila ddr, a ne ddr2 mema i da takvih više nema      I nakon svega kaže da ja idem to riješiti u Links gdje sam i kupio memu. Ne znam, ne smeta mi toliko taj problem oko meme, koliko sam se raspizdio kad vidim koji sve ljudi rade na kojim mjestima. Pa ako već radiš s memorijama, uzmi si jedno popodne pa ih prouči malo, a ne ko pavijan kad ti netko pita za robu s kojom bi trebao biti na ti, ti ni ne znaš o čemu netko priča ![]()  |
		#23 |
			Datum registracije: Jul 2004
					Postovi: 1,771
		#25 | |
					Postovi: 18,887
		#26 |
			 Suit up!
					Postovi: 5,970
		 Ja sam isto tako oko Prosinca kupio u HG-u 1GB 667 kingmaxa i dobio u onoj plastičnoj kutiji (neprozirnoj), a prije 1-2mj sam uzeo u Ve-mila još 1GB i došao je u tom prozirnom pakiranju bez čipa. Gleda sam u cpu-z i razlika je samo u 1 slovu u kodu imena. Inače radi super s ovim - 800mhz 4-4-4-12 @ 2.1v.  |
		#27 |
			 Prečupavi mod
					Postovi: 9,120
		 Ne ide napon nista nize?
		#29 |
			 The All Seeing Eye
					Postovi: 1,103
		 Pozdrav, da se malo pohvalim, kupio sam još 1Gb DDR2 "Kingmax" 667MHz! Zašto je "Kingmax" pod navodnicima... zato što je to u biti Nanya! Znaći, plavi modul bez CR čipeka! Evo slika iz Everesta: 1) Kingmax + Nanya --- (Kingmax screen): ![]() 2) Kingmax + Nanya --- (Nanya screen): ![]() Eto, koga zanima neka si pogleda! Obje memorije rade odlično u DC modu i nema apsolutno nikakvoga klanja! Verzija Everesta je v3.80.949 Beta! Lijep pozdrav!  |
		#30 |
					Postovi: 18,887
		 Hehe, meni isto dva plava super rade s dva zelena.  |
