Staro 16.03.2007., 08:15   #301
Bravo
Bravo's Avatar
Postovi: 1,450
Autor Smartguy Pregled postova
tako izgleda X2600 serija a ne X2800XTX
znam.pa valjda x2800xtx neće biti dvaput veća i trošit dvaput više
Staro 16.03.2007., 14:57   #302
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
Hoće
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 17.03.2007., 16:36   #303
Mailman
Mailman's Avatar
Postovi: 1,606
The 80 nanometre chip was bleeding current like a slaughtered pig bleeds blood as said quadruped heads to the Munchner Halle to be served up as a sausage or two. Squealing.
The 80nm R600 die - as it was leaked - will now come to life only in a very limited amount of chips, since AMD decided to solve its problems by pulling all resources to go 65 nano across the board, including this 720 million trannie heavy monster. This drastically reduces power consumption and lets AMD clock the R600 to 1GHz or even more. The mass production R600 will be made on a 65 nanometre process.
We have talked with several high-ranking AMD executives and confirmed this rumour. So, from March 16th at 19:59 CET - the R600 which you will buy in stores in May will be 65nm, and will consume almost one third less power than the 80 nanometre one.
http://www.theinquirer.net/default.aspx?article=38292
Mailman je offline   Reply With Quote
Staro 17.03.2007., 16:40   #304
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
ako ovo bude do nove godine bit će dobro
Smartguy je offline   Reply With Quote
Staro 17.03.2007., 17:24   #305
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,359
Vjerojatno će biti u 5. mjsecu kao što je najavljeno. 65nm je bio planiran za nasljednika R600 pa su se požurili .
Staro 17.03.2007., 19:32   #306
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
oni su sve samo ne požurili
Staro 17.03.2007., 20:41   #307
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,359
Traba ipak promijeniti 2 puta proces. Ako to uspiju izvesti, imaju prednost od jednog proizvodnog procesa u srednjoj klasi i 2 u visokoj.
Staro 18.03.2007., 12:07   #308
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Meni ta trakavica toliko ide na živce da ni ne pratim kao na početku-kad budu imali funkcionalan hardware onda budem
Dok DX10 zaživi kako treba i bude dovoljno jakih naslova već će biti jesen ako ne i Božić.
Do onda ne razmišljam o promjeni hardwarea, ni grafe ni ploče.
Staro 18.03.2007., 14:29   #309
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Autor Jelc Pregled postova
Ma normalno....
Lud76 je offline   Reply With Quote
Staro 18.03.2007., 16:38   #310
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Nepotreban trakavica, a Theo Valic i kompanija uživaju pljujući žuć.
Budalaštine. Reako sma odavno i ponoviti ću se, nemože si ni ATi ni nV dopustiti da napravi karticu koju koja se zagrijava jedno 100° više i troši oko 150-180W više.I uz to da perfomanse budu znatno slabije.
U tom slučaju dotična firma će moći zatvoriti tvronicu i ekipu poslat burzu. Budite razumni i malo mućnite glavom.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 18.03.2007., 17:35   #311
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Ma to je sve planirano da Theo i kompanija imaju o čemu pisati. U dogovoru s vrhom ATI-ja zajedno rade na reklamnoj kampanji: "Dajmo joj da pije"...
Ma stvarno su pukli svi skupa, ovo stvarno više nema smisla.
Staro 18.03.2007., 17:42   #312
Delta S4
She`s back...
Postovi: 983
Autor Isus Pregled postova
Da, baš se pitam gdje će im biti kraj što se tiče potrošnje el. energije. Cijeli svijet skviči (ili će uskoro skvičati) uslijed energetske krize, a oni rade kartice koje sišu 200W...
Delta S4 je offline   Reply With Quote
Staro 19.03.2007., 12:10   #313
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Gle glad za što jačim grafičkim pumpaju i proizvođači igara koji guraju detalje. Na koncu dobijemo igru s hrpom detalja veličine 4GB koju se pređe cijelu kolko je trebalo da prođeš tri srednje misiji u warcraftu 2. :Baad:
@tor
Grunf je moj idol!
Staro 19.03.2007., 12:23   #314
malba
schwere panzerspitze
malba's Avatar
Postovi: 313
što će bit vidjet ćemo (rekli bi u udruzi slijepih i slabovidnih osoba)
ja se još uvijek sjećam sir Valichevih "insiderskih" informacija o g80: kako neće biti native dx10 već će imati 2 jezgre :jednu za dx9 i jednu po nekim nvidijinim idejama kako bi dx10 trebao izgledati, kako ne bu bilo više od 32 pixel shadera i slično naprđivanje...
jedino što je sigurno za r600 je da će cjena biti paprena. ostalo su nagađanja na kvadrat.
malba je offline   Reply With Quote
Staro 20.03.2007., 15:12   #315
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
žalosna istina... iako se više ne bavim igricam ali pola novih hitova možeš preć u dan dva bez ikakvih problema.
Staro 21.03.2007., 03:29   #316
WeD@
Space Cadet
WeD@'s Avatar
Lokacija: Split<-->Vela Luka
Postovi: 592
e, ali zato sad ima vise igrica...
e4300@3.2, 965p-ds3 rev 3.3, (kingmax 667 ddr2 1gb)x2
9600gso 768mb, 1tb wd, 500gb wd, sb live!
fortron 500w
WeD@ je offline   Reply With Quote
Staro 21.03.2007., 08:41   #317
ZED
a.k.a. LOPOV
ZED's Avatar
Postovi: 2,022
Autor WeD@ Pregled postova
...Koje vrijede goli k......
Zabranjene reklama u sigu.
Staro 21.03.2007., 12:59   #318
Mailman
Mailman's Avatar
Postovi: 1,606
sličice r600xtx-a sa cebita:
http://www.vr-zone.com/?i=4830
Staro 21.03.2007., 15:56   #319
domy_os
domy_os's Avatar
Postovi: 18,836
Fino su je smanjili, ali je smještaj konektora za napajanje poprilično debilan...
Staro 21.03.2007., 17:03   #320
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
Autor Mailman Pregled postova
e to je ono šta se cijeni
Prave slike koje SIGURNO nisu fake
EDIT:
žalosno je to šta je 200-300 bodova jača u 3d marku(iako nije neko veliko mjerilo preformansi). Mislim da oni sa 8800gtx neće imati razloga žaliti šta su je uzeli osim šta će im cjena past masno
Staro 23.03.2007., 00:43   #321
EvilM@ster
Ev1LMa5ter
EvilM@ster's Avatar
Lokacija: Koprivnica
Postovi: 675
Evo i vodenoga hladenja od thermala za doticnu
http://www.xbitlabs.com/articles/edi...t2007-3_3.html
androidhrvatska.com
EvilM@ster je offline   Reply With Quote
Staro 23.03.2007., 10:45   #322
Angelus
A mighty pirate!
Angelus's Avatar
Postovi: 429
ako to izađe prije moje smrti,nemože čovjek povjerovat kolko mogu bit glupi,očekuju da će strgat nevidiju s jako dobrim obećanjima,pih,da to tako ide...
ATi X2800NiS(Nade i Snovi) vs. Nevidija 8800GTX
Zadnje izmijenjeno od: Angelus. 23.03.2007. u 11:02.
Angelus je offline   Reply With Quote
Staro 23.03.2007., 22:43   #323
domy_os
domy_os's Avatar
Postovi: 18,836
Autor EvilM@ster Pregled postova
Prave ražanj, a zec u šumi...
Staro 23.03.2007., 22:58   #324
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
Autor domy_os Pregled postova
predivno rečeno
Staro 23.03.2007., 23:38   #325
Angelus
A mighty pirate!
Angelus's Avatar
Postovi: 429
imaju oni naš novčanik da prave ražanj od toga
Staro 27.03.2007., 22:44   #326
Mailman
Mailman's Avatar
Postovi: 1,606
http://www.vr-zone.com/?i=4866
ovo mi izgleda elegantnije (Aavid Thermalloy vodeno)
Staro 29.03.2007., 19:43   #327
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,547
Nesluzbeni rezultati:
We managed to get some early numbers from the R600 and this baby scores 11400+ in 3Dmark06. The test bed included Quad coreQX6700 Intel CPU and 2 GB memory.
http://www.fudzilla.com/index.php?op...d=345&Itemid=1
Ipak ima nade za R600, jos da rjese duzinu kartice i zagrijavanje i bit ce to opaka kartica. Pogotovo zato sto mnogi korisnici imaju problema sa high end G80 karticama i WOW-om. Na nekim dijelovima mape ruse se G80 kartice dok slabiji modeli i ati rade bez problema.
Staro 29.03.2007., 20:09   #328
WeD@
Space Cadet
WeD@'s Avatar
Postovi: 592
Autor Bono Pregled postova
ako se ne poboljsaju performanse sa novim driverima, nvidia ce opet potuc ati...
overclockirana 88000gtx je 300 bodova sporija , sto znaci da ce 8800ultra pomest pod sa r600, ako je za vjerovat Fuadu...
p.s. tko je upoce Fuad i koga briga sa wow ?
fortron 500w
Staro 29.03.2007., 21:26   #329
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
da te čuje neki zagriženi WOWovac nebi dobro prošao
Staro 29.03.2007., 22:46   #330
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,359
Koga briga za par sto marka, važno je da već jednom izađu na tržište. Ionako će popravljati stvar sa 65 čipom kroz par mjeseci nakon predstavljanja.
